I as wondering if anybody out there has found a good wiper motor for a 36 coupe? I'm going to be having the interior done and they had the repop oval one in it which means I would have to cut a hole in the header panel. Thought maybe someone has kept up on newer items and knows of one that will fit behind the header without cutting it. I'm only doing wiper on drivers side 12 volt.
Have a look at my reply #3. If you can find one of this type you can have the motor under the dash. https://www.jalopyjournal.com/forum/posts/13357596/
