Hot Rods Rich's Coupe - a ten year odyssey
Discussion in 'The Hokey Ass Message Board' started by Rich B., Nov 10, 2019.
  1. Blues4U
    Blues4U
    from So Cal
    Rich, I'm struggling figuring out what you did there with the insert. You show 2 different types of hold down systems, right? And ended up using 1 of them, the 2nd one that has some sort of black vinyl cap that snaps down over the channel, correct? How does it retain the material? It's probably very simple but I'm just not visualizing it.
  2. Rich B.
    Rich B.
    from Portage,IN
    I used the popular 2nd system for the fabric insert
    which is available from Julianos. The first part of that
    post I tried to show alternate methods of making the hold down track look more like a 32 or later hold down track. I should have explained it better.
    The Julianos kit is what I ended up using. You pre fit
    the aluminum track, drill all the holes to hold it down. On the inside of the track you lay down 1/4”
    Foam. I stretched the fabric over that frame I made
    out of 4”x4”s I than lay it on the roof , locate the
    holes for the track, and start installing the track
    right over the stretched fabric . I use a razor blade
    to trim the excess material on the outside edge
    of the aluminum track. The track holds down the
    stretched fabric. Now just snap on the vinyl cap.
    The vinyl cap will hide the cut edge of the fabric
    insert.
    Sorry for the lack of info in the original post.
    Rich
  3. Blues4U
    Blues4U
    from So Cal
    Excellent, thanks!
    loudbang and Rich B. like this.
  4. oldiron 440
    oldiron 440
    I've got to say watching you accomplish a great deal with health issues is inspiring for the rest of us dealing with our own. No more excuses I've got work to do.:)
  5. Rich B.
    Rich B.
    from Portage,IN
    Just a little addition to the fabric insert post. I used square drive screws to hold the track
    instead of pop rivets. I like to be able to take things apart if needed. They were # 6 3/4" long
    screws. I can't remember if they were round head or bevel headed screws. McMaster carr #
    90395A152 or 93945A004. If you use screws you have to drill all holes,and then remove
    track, and drill holes larger so threads don't catch on track.
    Rich
    Tim and Blues4U like this.
  6. Rickybop
    Rickybop
    Checking on your progress.
    Getting closer!
    Your old buddy Chuck helped you put your body on 50 years ago and this time, too. Well, that's really something.
    Sent from my VS835 using The H.A.M.B. mobile app
  7. Rich B.
    Rich B.
    from Portage,IN
    Yes, Chuck is my oldest friend, and back then he
    had a 34 5 window Coupe. Now at the age of 81
    he has a 57 Chev 2dr sedan.
    This is the same garage, I’ve lived here 51 years!
    Rich
    scotty t, loudbang and kidcampbell71 like this.
  8. 32fenderless
    32fenderless
    Reminds me of the first hot rod I built. This was very early nineties. Went through several intakes from single carb tunnel ram to dual carb tunnel ram to the single carb. Ended up with red engine and wheels before I sold it.
    Vic Walter, Thor1, loudbang and 2 others like this.
  9. Rich B.
    Rich B.
    from Portage,IN
    32fenderless:
    You built your first car with a lot of attitude!
    I love that look, good stuff thanks for showing it.
    Rich
    32fenderless and loudbang like this.
  10. Rich B.
    Rich B.
    from Portage,IN
    Needed to get the wiring in before setting engine. I used American Wire to do mine.
    I made the dash removable with 2 quick connects, and pop out ignition switch.
    I made a small under dash panel as I had a lot on the dash already. IMG_1570.JPG IMG_1585.JPG IMG_1656.JPG IMG_1586.JPG
    Vic Walter, GordonC, brEad and 8 others like this.
  11. nunattax
    nunattax
    from IRELAND
  12. Redrodguy
    Redrodguy
    I really like your instrument panel and the quality of workmanship on every part, but have you considered using something besides the mill finish aluminum for the under dash panel? Either paint it black to match the main panel or use black diamond plate to match the firewall.
    Just something that caught my eye.
    Great job!
  13. Rich B.
    Rich B.
    from Portage,IN
    Redrodguy:
    All good points . I had meant to polish that piece,
    but went on to finish everything else , and never got
    Back to it. I don’t mind if it stands out. That diamond
    plate is. 1/8” rubber mat . I wanted a stark looking
    floor to go with the bead rolled panels. I’ll get some
    pics of the finished interior up pretty soon.
    Rich
    I have no idea why this is in italics!
  14. Blues4U
    Blues4U
    from So Cal
    OK, time for another stupid question. Is the mat glued down to the Dynamat, or just laying loose on top of it. Thanks!
  15. Rich B.
    Rich B.
    from Portage,IN
    Blues4U:
    I fabbed piece of 16 gauge for the firewall, and has a piece of rubber mat glued to it.
    the floor rubber mat is not glued down, and is held in place by the seat, and the trannie
    cover. No problems with it moving around. Those openings in the lower corners are
    for acess to wiring ,and are covered with painted black plates.
    loudbang, Shadow Creek, Thor1 and 2 others like this.
  16. Rich B.
    Rich B.
    from Portage,IN
    Some more pics that show the mat held down with seat, and trannie cover.
  17. Rich B.
    Rich B.
    from Portage,IN
    A few more pics:
    Vic Walter, Stock Racer, Tim and 8 others like this.
  18. Bill Rinaldi
    Bill Rinaldi
    Rich, I'm a late arrival, I was tipped off by Jim 32 with a "you gotta see this thread, the guy is Phenominal--- and he's a local guy". I absolutely agree with Jim, the car and your work is out standing! I'm in favor of your well educated approach of being able to make a lot of pieces "accsseable", so that if ever have to go back and "adjust or even replace". But what REALLY amazed me, was half way through the post, that you are severely restricted by COPD! I've got two friends our age, one, an avid hot rodder with 2 really nice cars with the same "hose" restrictions, and honestly, they've both "given up". My extreme respect, not to just your vision and your talent, but to your decision to carry on. Can't wait to see the car finished, BIll Rinaldi
    brEad, greaser, loudbang and 5 others like this.
  19. nunattax
    nunattax
    from IRELAND
    the chequered plate pattern on the rubber is great.your a class act Rich !
    Rich B. likes this.
  20. Rich B.
    Rich B.
    from Portage,IN
  21. nunattax
    nunattax
    from IRELAND
    WHERE DID YOU GET THE MIRRORS
  22. alfin32
    alfin32
    from Essex, Ma.
    Fantastic build, and color, congrats!!
    kidcampbell71 and loudbang like this.
  23. Nostrebor
    Nostrebor
    That color!:cool:
    Sitting on the edge of my seat here. Can't wait to see what happens next!
  24. Rich B.
    Rich B.
    from Portage,IN
  25. Rich B.
    Rich B.
    from Portage,IN
    Getting it together:
    brEad, Thor1, kidcampbell71 and 2 others like this.
  26. Rich B.
    Rich B.
    from Portage,IN
    Lets see if I can post a video of engie start up, I'm taking the video:
    Rich
  27. Rich B.
    Rich B.
    from Portage,IN
    More Assemly picks:
    Tim, GordonC, brEad and 6 others like this.
  28. loudbang
    Video works fine :)
  29. Rich B.
    Rich B.
    from Portage,IN
    Loubang:
    I still have trouble making it repeat. I'll check later, I have a couple more I want to post.
    Rich
  30. loudbang
    Tried it for the second time and since working fine on my PC.
    Rich B. likes this.
