Projects 31 sedan build
Discussion in 'The Hokey Ass Message Board' started by jdcool44, Jul 25, 2019.
  1. jdcool44
    jdcool44
    I am John and this is my 31 sedan hot rod build. I got this car a few months ago and been working on it on and off in that time. 20190107_000322.jpg 20190108_012307.jpg 20190108_012311.jpg 20190108_012335.jpg 20190108_012323.jpg
    RAT "T" and AVater like this.
  2. AVater
    AVater
    1. Connecticut HAMB'ers
    John
    Welcome to the Hamb. There are many here with great knowledge and experience.
    What are your plans for your build?
  3. catdad49
    catdad49
    Welcome, John. If you fill in your profile, there may be others in your area that could lend a hand when needed. At some point you Will need help.
  4. jdcool44
    jdcool44
    I know i will need help for sure. I am trying to build a 302 hot rod split wish bones with fenders if i can find some spare money is the key right now.
  5. jdcool44
    jdcool44
    After I brought it home I removed the body engine trans and rear axle. 20190114_010049.jpg 20190115_033302.jpg 20190115_142840.jpg 20190120_221929.jpg
  6. jdcool44
    jdcool44
    I split the wish bones. Removed the front cross member and started test fitting the new cross members and wish bone mounts 20190314_140655.jpg 20190318_142734.jpg 20190323_183816.jpg
  7. jdcool44
    jdcool44
    I scored The rear hair pins off face book a few months ago. and the wheels a few weeks ago. 20190411_141635.jpg 20190704_130058.jpg
  8. jdcool44
    jdcool44
    I also started to pull the body apart so i can repair the rust damage. 20190721_022958.jpg 20190721_161555.jpg
  9. Kiwi 4d
    Kiwi 4d
    It looks like a great project.
    Please do not use those modern wheels.
  10. jdcool44
    jdcool44
    Thanks, I'm trying to get it all cleaned up . The wheels are all i have for now they will get it around and once i get it driving i will start changing things around more.
    nunattax and Kiwi 4d like this.
  11. jdcool44
    jdcool44
    This is the axle I picked up its a ford 8.8 3.73 Lsd 20190504_022119.jpg from a Ford Explorer. Has disk brakes .I think its too narrow to cut the long side and center like I wanted so it may not work like I wanted
  12. jdcool44
    jdcool44
    I did a little work on the doors today too bad I am out of wire and argon or i could have got the door bottoms tacked in 20190728_172949.jpg 20190728_173748.jpg 20190728_230903.jpg 20190728_230955.jpg
  13. jdcool44
    jdcool44
    20190809_044138.jpg 20190809_044134.jpg 20190809_044123.jpg 20190809_044113.jpg Got one of the door bottoms tacked in still got some metal to replace on the bottom of the door frame. Also welded the cracked metal shown near the window regulator.
    Stogy likes this.
  14. jdcool44
    jdcool44
    Sorry its been a while . family vacation over time at work ect. found a much nicer frame so i started over on removing the front cross member . also rust repair on the cowl and a pillar. 20191123_194454.jpg 20191128_174505.jpg
    Stogy likes this.
  15. jdcool44
    jdcool44
    20190720_234756.jpg 20190720_233232.jpg 20191013_223315.jpg 20191013_223327.jpg
    here are some pics of the rust removal from the cowl and the used replacement sub rail extensions.
  16. 41rodderz
    41rodderz
    from Oregon
    Good your keeping one more heading back to life .:)
  17. jdcool44
    jdcool44
    20191204_055356.jpg my new dash came in the mail today. Its just sitting there dont have the heart to cut it yet
    Stogy likes this.
  18. jdcool44
    jdcool44
    Got the dash fit between the a pillars today and bolted in. I will need to get a windshield frame and garnishments to finish fitting the windshield
    Stogy likes this.
  19. jdcool44
    jdcool44
  20. Kiwi 4d
    Kiwi 4d
    188A0D2C-8D3D-4918-89CB-775A986D68E2.jpeg B8AA0AA8-3030-4B5A-973F-06CE86401F01.jpeg Just remember to allow clearance for the window cranks and the dash , we did not when fitting a 36 dash to a 28 tudor. Easily solved but a head scratcher at first.
    Stogy likes this.
  21. jdcool44
    jdcool44
    How many inches away from the a pillar is your dash? I am about a 1 1/2 at the bottom .I will have to set everything together tonight and check it.
  22. jdcool44
    jdcool44
    I think I am ok
  23. nunattax
    nunattax
    from IRELAND
    is it possible to mount the winder assembly farther back in the door. away from the dash
