1948 Ford Superior short school bus.
Discussion in 'The Antiquated' started by Kustomkid, Jan 8, 2019.
  1. atch
    atch
    OK; I'll look the next time I'm over that way. Be patient, though.
  2. Kustomkid
    Kustomkid
    from Montana
    Thank you
  3. Hemiman 426
    Hemiman 426
    from Tulsa, Ok.
    Things are coming out of the woodwork!
    adam401 and Kustomkid like this.
  4. Kustomkid
    Kustomkid
    from Montana
    Nice!
  5. Kustomkid
    Kustomkid
    from Montana
    Got the passenger side aluminum panels and the seat mount, and got a rear door handle cover and the taillight blister for inside. [​IMG] And got a line on 2 more seats. So I almost have everything for the inside. . . .
    drdave and scotts52 like this.
  6. Kustomkid
    Kustomkid
    from Montana
    Here is the interior of the bus. It’s to bad they stripped it out.
    [​IMG][​IMG][​IMG][​IMG][​IMG]
    If any one knows of a junk yard that has one of these busses with a chrome 3 piece bumper. Need to find one....
    drdave likes this.
  7. atch
    atch
  8. scotts52
    scotts52
  9. scotts52
    scotts52
    Try it now. I didn't have it right the first time
    Okie Pete likes this.
  10. Kustomkid
    Kustomkid
    from Montana
    Front suspension is swapped out with our 48 ford dump truck and I am in the process of removing the old wheels on the passenger side and cleaning up the axle to put a drum on and it should finally roll.
    drdave and charleyw like this.
  11. Kustomkid
    Kustomkid
    from Montana
    Okie Pete, RMR&C and drdave like this.
  12. Kustomkid
    Kustomkid
    from Montana
    The bus rolls! Hasn’t had a drum and 6 aired up tires on it for at least 35 years. Adjustments.JPG Adjustments.JPG 8.25x20 get the back end up in the air.
    Okie Pete, scotts52 and greaser like this.
  13. Fabber McGee
    Fabber McGee
  14. Kustomkid
    Kustomkid
    from Montana
    No old rubber. Donated from our old 48 ford dump truck. Tires and rear axle parts along with the front axle assembly to get it rolling.
  15. jimmy six
    jimmy six
    Seems like a 70-80's crewcab dually CHEV/GMC would be the perfect donor for everything Eng/trans/rear/frt suspension/etc and be a give away by someone.
    Kustomkid likes this.
  16. Kustomkid
    Kustomkid
    from Montana
    That’s what I’m thinking. The cab and chassis rearend will fit with end the body. Just not sure about the spring pads
  17. Kustomkid
    Kustomkid
    from Montana
    And it moves! Got to finish rolling it around tomorrow before the snow starts falling. Now to finish installing the roof sheetmetal. [​IMG] [​IMG][​IMG][​IMG][​IMG]
    Okie Pete, adam401, pcbart and 2 others like this.
  18. That's a cool ride
    Sent from my SM-A102U using Tapatalk
  19. Kustomkid
    Kustomkid
    from Montana
    [​IMG][​IMG][​IMG]
  20. Kustomkid
    Kustomkid
    from Montana
    R A Wrench, echo ed, drdave and 2 others like this.
  21. Kustomkid
    Kustomkid
    from Montana
  22. atch
    atch
    That thing is going to be SO much fun.
    Whatcha gonna use it for? Take a buncha buds to the races? Home built camper? Take the kiddies to school? Pull your scoot on a trailer to Sturgis?
  23. Kustomkid
    Kustomkid
    from Montana
    Take the kids to school, take it to the salt flats. To small for a camper. Would like the inside to look as original as I can. I even have the original over head storage shelves that mount over the windows. Found a early 80’s chevy 1 ton I’m hoping to pick up in March and will have the running gear for it.
  24. Kustomkid
    Kustomkid
    from Montana
  25. atch
    atch
    You gonna use the Chevy wheel size or keep the big Ford size?
    Or is it just an optical illusion that they aren't similar sizes?
  26. That is one cool ride. Is the wheel base close or are you going to need to alter it.
    I would drive the wheels off of that bus. paint it school bus yellow and write SCOOL BUS on the side
  27. atch
    atch
    Back in the 60's or 70's there was a hippiemobile around here that had painted out some of the letters so it read "COOL US"
  28. Big AL Neenyo
    Big AL Neenyo
    Rudestude, where is the Airship hanger?
  29. Kustomkid
    Kustomkid
    from Montana
    Adjustments.JPG Disassembled the buses front end and put the dump truck front end on to move everything. Got to move all the inner sheetmetal and I may be able to get it towed home so I can mess around with it with being stuck at home.
    Big AL Neenyo likes this.
  30. Kustomkid
    Kustomkid
    from Montana
    The wheel base is close. Measured it out and the rear spring pads are off by a 1/4 inch. So I think I can fudge the rear end and mount it on the original springs. (May remove a few leafs to improve the ride alittle). The front end will side in between the rails. They unbolt off the frame as a complete unit. Will just have to modify the steering mount. I install a 3/4 ton front end on a 47 coe and it worked really nice.
