Technical Repairing a wishbone socket
Discussion in 'Traditional Hot Rods' started by RoadsterDom, Dec 18, 2019.
  1. RoadsterDom
    RoadsterDom
    I have a clean 32 k member that I’m hoping to use in an early build . However the cup / socket that the wishbone mounts into is badly damaged . I’m looking for some advice on how to repair it .
    Thanks
    Dom
  2. Flathead Youngin'
    Flathead Youngin'
    I've seen people, on here I think, use the removable cup (opposite piece) as a repair piece after they cut out the damaged one....
    clear as mud haha
    RoadsterDom and LOU WELLS like this.
  3. Boneyard51
    Boneyard51
    Maybe pictures of the damage would help?
    Bones
    Desoto291Hemi likes this.
  4. deathrowdave
    deathrowdave
    from NKy
    Find a good one , cut the old one out , cut grind , fit and weld the good one in
  5. RoadsterDom
    RoadsterDom
    You'd make a great politician .
    If I had a good one I probably wouldn't need to repair a bad one ;-) . Im also in England so shipping an entire cross member isn't the cheapest thing to do , hence wanting to repair this one.
  6. RoadsterDom
    RoadsterDom
    Thats really quite obvious not sure why I didn't think of that. Does any one know if all wishbone cups are alike or do they change though the years?
  7. alchemy
    alchemy
    Yes they change. But I'm not sure when they change, sorry.
  8. BamaMav
    BamaMav
    from Berry, AL
    Some are deeper than others. I bought one off eBay and used it as an upper to drop mine for trans pan clearance, it was 1/2” deeper than mine. Sorry, don’t remember what it was for.
  9. goldmountain
    goldmountain
  10. This is from the thread by @swissmike on his 1939 Merc build...a very good thread overall (click on the quoted section to expand with all the pictures etc.), but this section shows his repair to the wishbone socket.
    RoadsterDom likes this.
  11. goldmountain
    goldmountain
    DIYGUY and RoadsterDom like this.
  12. woodiewagon46
    woodiewagon46
    from New York
    Model A Fords use a two piece cup. You might be able to graft the Model A cup into your crossmember, plus it's a lot easier to ship.
  13. GuyW
    GuyW
    What do the repro '32 frames use??
  14. Happydaze
    Happydaze
    RoadsterDom, the roadster in your avatar looks very like the one I built and sold unpainted to Paul Hobby. Reg was YUX I think. Is that it? If so how's it going?
    Chris
  15. RoadsterDom
    RoadsterDom
    trailer hitch isn’t a bad shout
    That @swissmike tech tip is impressive
    I think a model a one is the wrong size , probably a question best asked on the ford barn but certainly using a bolt in cap is the best idea .
    Hey Chris , yep one and the same have just dropped you a message with some pics and what have you .
  16. deathrowdave
    deathrowdave
    from NKy
    I’m so sorry , I did not notice you were not on American soil . I understand now that finding a usable one could be s bit impossible . Maybe use a copper backer and weld it up and grind and polish it maybe an option . Again I’m sorry and good luck .
