Technical 1959 Chevy Truck Suspension, Axle and Brake Project
Discussion in 'The Hokey Ass Message Board' started by 59Apachegail, Dec 6, 2018.
  1. brigrat
    brigrat
    from Wa.St.
    Where's their safety glasses??????????????????smileyface
    59Apachegail likes this.
  2. 59Apachegail
    59Apachegail
    from New York
    oops!! good thing I didn't have the plasma cutter out. :)
  3. 59Apachegail
    59Apachegail
    from New York
    I got my 7" wheel with an other 235/70/15 mounted. Front wheel well didn't fill up as nicely as the rear but it looks a lot better.
    A few before and after, I am pretty happy.
    leon bee and swade41 like this.
  4. 59Apachegail
    59Apachegail
    from New York
    Got one side of the axle grounded and smoothed out. Next time I'll get around to the other.
    Only two gouges from when I cut. Not too deep, I think it is good.
    swade41 likes this.
  5. 59Apachegail
    59Apachegail
    from New York
    I am going to consider this another update since it was some progress.
    Perch #2 is off and ground smooth. I have the same gouge that I made on the other side. There was probably some angle I hit since both were cut the exact same way. A nice little weld should cover them up. Next is to clean this up to weld the new perches on
  6. 59Apachegail
    59Apachegail
    from New York
    I picked up a 1/2” Torque wrench to re-torque my axle to caliper bolts. I was using a 3/8” Toque wrench with a converter for 1/2” sockets and I didn’t trust the reading. I also decided to remove the neverseeze from the bolts and nuts as well. I figured the goop was messing up my readings and I didn’t want to pop a head at 60 miles an hour. I torqued the smaller bolts to 35lbs and the larger to 50lbs. I used specs found for a 60s caliper kit on a vendor site. Seems like none of the 55-59 kit documents have torque specs. After that I test fitted a rim and pulled this thing off the bench making room in the process. After all these months of looking at that thing I still can’t get over how sexy it looks.
    41F659F9-394F-4243-AA13-E4F1235AC08B.jpeg 18CED2EE-495A-4E73-82AC-D519EA8CF1C4.jpeg 3550EF74-B3E1-4545-B2D4-21334512F28D.jpeg 1CB64628-35B5-445A-824E-2E7FC7D20731.jpeg
    swade41 and bobss396 like this.
  7. 59Apachegail
    59Apachegail
    from New York
    After two days of cleaning and throwing out stuff the garage has enough room for me to start axle work. Truck was shifted enough to have access on both sides.
    I started by laying the master cylinder and lines out using original reproduction stainless lines. Attempting to snake the new line from the front driver side to the master in the original configuration will be a pita. The lines look like they are in the correct shape but require more bending to get them to actually fit properly.
    For anyone doing this in the future... The combination valve outlets and the caliper hoses are smaller than the original size brake lines. The front outlets on the combination valve and the inlets for the caliper hoses require 3/8 inch -24 male tubing nuts on 3/16 tubing. The front original replacement brake line is 1/4 inch tubing - 7/16 inch - 24 male thread tubing nuts. After a trip down to the auto parts store with a line and a rubber hose I was able to figure this out. Info on the parts sites is not quite clear. I may have to use 1/4 - 3/16 adapters to get the line to fit. Since the stainless lines will need tweaking to make them fit.
    In case you are making your own lines, brake lines require steel fittings rather than brass ones. Everything I read is these brass fittings for brake lines are a no-no. Nicopp lines are pretty cheap and seem like they are easy to work with. My neighbor swears by them.
    Since I am staying manual discs for now, all research seems to point to larger lines (1/4”) for less pedal effort. This garnered from the many brake line threads on the hamb. I can go to 3/16” when I get the booster setup.
    I will want to drive between front and rear axle upgrades. At that point it will be disc/drum. This will require a different combination valve since discs require 2psi to engage and drums require 10psi to engage. I was going to run my disc/disc but was told the rear drums won’t engage due to lack of pressure. Since it will be disc/drum for a little while; I replaced a leaky rear wheel cylinder.
    ***I used the term combination valve as an interchange for proportioning valve. I have read that proportioning valve is an incorrect term so I opted for “combination”. It doesn’t matter what it is called for me. It is just easier than calling it the thing that sits under the new master cylinder to control line pressure to the discs.
  8. 59Apachegail
    59Apachegail
    from New York
    Some outside pictures showing hooped rims 7” and 8” respectively vs original size 5-1/2”. Tires are 235/70R-15 all around.
    Something I noticed when I was under it was that the tie rod ends are about 1/2” away from hitting the tires. 7” in the front and 8” in the rear is absolute max size that would fit in stock form.
  9. I love your truck. Are you going to leave the pipe rack on it? It looks so cool and vintage.
  10. 59Apachegail
    59Apachegail
    from New York
    Thanks Andy!
    Originally the ugly old work truck look was what drew me to it. I love the rough weathered look but I have a strong desire to make it a gentleman cruiser. If I ever do get to that point I will make it a fleetside with white accents. That may be years though.
    Truckdoctor Andy likes this.
  11. 59Apachegail
    59Apachegail
    from New York
    She is finally up in the air.
    It looks pretty sturdy on the 12 ton jack stands and the helper 3 tons up front. However I am still waiting on a second set of 12 ton to replace the 3s. Rather be safe than sorry here. I never noticed the passenger side upper shock mount was repaired at some point. I could leave well enough alone but why not do everything the right way. 274FCE9E-F11E-407B-A6D1-2305220FDBE6.jpeg
    Oil soaking on the nuts for now. More when the next set of jack stands come in.
  12. 59Apachegail
    59Apachegail
    from New York
    Shocks and mounts off a lot less eventful than expected. A little oil and they squeaked off.
    DFFA21F0-556F-4F63-B261-1407E44A46E4.jpeg 2C81482E-0DDE-46DB-A90D-5413C621A2D6.jpeg
    Pass side shock mount is not my favorite so I am looking for an original replacement.
    swade41 likes this.
  13. 59Apachegail
    59Apachegail
    from New York
    Draglink popped off with a little oil and my $14 tool from napa. 79242A09-AD2C-4C0B-829F-23838C5D7ECC.jpeg F522CCCB-0A1D-4C4B-876F-F9CBD32A2BCB.jpeg 4553EC7D-092E-4E33-B088-F81A0FB5743A.jpeg
    swade41 likes this.
  14. 59Apachegail
    59Apachegail
    from New York
    Rear spring bolts were packed hard with grease and they gave me fits. I scraped as much as possible then oiled. After a ton of banging the driver side nut broke free. Passenger side nut started to strip. It might need to be cut.
    27F2E770-06E0-4194-9FA6-2EF3A80EE57A.jpeg 6695EEEA-5B26-4EFE-9181-577CA525E752.jpeg
    swade41 likes this.
  15. Budget36
    Budget36
    Who's disc brake kit did you use. I re-read through and didn't see mention of it.
    Also, it's attention to detail (like fixing the shock mount) that gives you a piece of mind traveling down the road. You can never be to anal about fixing stuff;)
  16. If you're pulling the springs the rear forward cross bolt wants to hit the step before coming out enough to get the spring out, I had to jack the front of my bed up to get those bolts out.
  17. 59Apachegail
    59Apachegail
    from New York
    Thanks Budget36,
    I got the bulk of brake stuff from Performance online. I liked the fact that they had powder coated calipers with the 6 lug conversion. So far the front kit dry fitted well and they have been very helpful with the occasional questions. Details have been keeping me very busy, hopefully when this truck is done I will be doing long trips with it.
    Budget36 likes this.
  18. 59Apachegail
    59Apachegail
    from New York
    Thanks Swade41,
    Can you tell me if the front and rear mounts through the frame on the front springs need to be un-screwed or do the have to be pounded out? Passenger side is fighting hard and I am tempted just to start cutting it out with a cut off wheel. But I am concerned if it screws in I’ll make more work trying to speed the process.
    Thank you
  19. Jay59chevy
    Jay59chevy
    I believe you have to take the zerk off for you to be able to back it out
  20. Jay59chevy
    Jay59chevy
    Are you running the frame or firewall mounted booster,?
  21. 59Apachegail
    59Apachegail
    from New York
    Thanks jay59chevy,
    worst case I may need to cut the zerk then.
    It is going to be frame mount manual setup for now. When I convert over to an auto I will be forced to move the trans mount and upgrading to a power setup. My plan is to keep everything new hidden.
  22. Yes zerk comes off, then the nut on frame side of cross bolt, then there's a small wedge bolt running parallel to the frame on the outside side of spring eye that comes out, there's a flat on that cross bolt that runs through the spring eye, the wedge bolt goes against that flat and stops the cross bolt from rotating and coming out.
    When that wedge bolt is out then you just tap the cross bolt out, heat will help get that zerk fitting out, once cross bolt is out you can put some heat on it too and the old grease will shoot out of it to make way for new grease.
  23. I went back to my X57 build thread and snagged this photo, I put a red dot in the hole the wedge bolt goes into and a red arrow where the wedge bolt rides on the cross bolt.
  24. The cross bolts on the front spring unscrew, you have to take the rear one out while on truck, the front you can remove shackle, take spring out then work on it away from the truck. You can double nut one end of cross bolt and use the nut to help unscrew it out.
    LMC has good photos showing parts breakdowns.
  25. 59Apachegail
    59Apachegail
    from New York
    Swade41,
    Thanks for all the info, much appreciated! Hopefully I’ll have the rest of the front out beginning of next week.
    bobss396 and swade41 like this.
  26. 59Apachegail
    59Apachegail
    from New York
    Originally I planned to have the swap done in two days, boy was that an over estimation. I thought I was going to have front and rear axles ready at the same time but that was also an over estimation as well.
    In case anyone else is going to follow along and do the same upgrades I’ll keep this section updated as I progress
    Performance online:
    6 lug disc brake upgrade kit Front and Rear with powder coated calipers and rubber lines
    Powder coated tie rod
    Powder coated Front and rear sway bar kit
    GM prop valve kit Disc/Drum
    Prop valve bleeder tool
    1” dual pot master
    Classicparts: (try finding alternates if you can, their tech support sucks and so far everyone on the phone but sales is rude)
    Front shackles (came powder coated)
    Front spring rear bolt
    Roller bearing upgrade kit
    Original style Stainless Brake lines
    Tie rod ends (came powder coated - however I had to clean the threads out because they were full of some yellow pollen looking stuff)
    King pin kit
    (12) Front wheel studs 7/16-20
    Original style Lug nuts
    Master cylinder adapter kit (came powder coated)
    Brake return spring
    Posies:
    Super slide springs powder coated
    Bilstein shocks F4-BE5-B494-TO
    Ebay:
    Made in USA zerk fittings
    Zerk fitting covers
    Timken Bearings for 12 bolt-
    (2) Head Bearing HM89449\ (1)Race HM89410
    (1) Tail Bearing M88048\(1) Race M88010
    (2) Axle Bearings 6408 (Extras)
    (2) Side Bearings LM603049\(2) Race LM603012
    (2) Moser Engineering Street Axle A30-65GMTK
    Amazon:
    Draglink Moog DS584
    Rear Diff Rubber brake hose - Raybestos BH4497
    Pep Boys:
    AGS BLF-23C 1/4 Female to 3/16 male tube adaptors
    Dorman Help! Copper gasket assortment 66222 for front brake block (needed 2 kits)
    1/4x 12” preflared brake line PA-412
    (2 packs) Dorman 10mm brake bleeder 13908 - extra because one man bleed ends up causing bleeders to get damaged.
    Summit Racing:
    Eaton Posi Differntials 19556-010
    Richmond Gear Ring and Pinion 49-0280-1
    Ratech Yolk Holder 18001
    (2) Yukon C-Clips YGA-33083
    (2) Yukon Bearing and seal kit YGA-10001
    (2) Moog U-Joint Fasteners MOG-329-10
    Yukon U-Joint YGA-42008
    (2 packs) Moser MSR-8060 rear Wheel stud 7/16-20
    swade41 likes this.
  27. APACHE FS
    APACHE FS
    Those front shock mounts are crap, I broke one, replaced with a stock one, broke it. I just welded it up with some re enforcement from the back. I guess I will do the other side when it snaps.
  28. 59Apachegail
    59Apachegail
    from New York
    Hey Apache FS,
    Was it hard driving, loaded heavy or it just snapped?
  29. 59Apachegail
    59Apachegail
    from New York
    I soaked this sucker down with Gibbs yesterday. I started hacking away at the nut until there was about 1/16 of metal left. I decided to try the pipe wrench and she broke free to my surprise. I went back and loosened both rear bolt hangers.
    I staked them back in temporarily to start working on the front. The front nuts broke free pretty easy.
    Now it’s time for the dollies to drag this out.
    swade41 likes this.
  30. 59Apachegail
    59Apachegail
    from New York
    All freed up
    And after it was rolled out the front looks a little empty...
    At this point I cleaned up the floor and put my little 3 jack stands up front in case of an emergency. The only things left to remove are the front through frame hanger bolts and all the grease.
    swade41 likes this.
