Sunday models
Discussion in 'The Antiquated' started by milo1303s, Mar 16, 2014.
  1. pigIRON63
    pigIRON63
    A couple parts box creations 20191207_112240.jpg 20191207_112240.jpg 20191207_112126.jpg 20191207_112240.jpg 20191207_112126.jpg 20191207_112133.jpg 20191207_111941.jpg 20191207_111752.jpg 20191207_111807.jpg 20191207_112240.jpg
  2. quick85
    quick85
    ^^ I'd be scared to take #22 down the strip at full speed. You definitely
    weathered that one. As for #27, someone in the "full size" discussion recently
    bemoaned all the '30s coupes that were led to their slaughter as circle track
    racers. Your model really captures that look.
    Deuces likes this.
  3. quick85
    quick85
    Painting plastic has now become a major pain in the rear for me. When I
    got back into modeling I was working at a new car dealer and one of the body
    shop painters took on the job of doing my painting and he was very good at it.
    After a while I stopped building and really only recently started up again. I don't
    have an air brush and compressor, I also don't have a spot to build and set up a
    spray booth, so I depend on spray cans and a cardboard box when I want to whip
    something out. The thing is, I don't want to just whip something out, I want my
    models to be presentable and something kool to look at. If I left everything in primer
    I'd be golden but color, orange peel and crazing are making me crazy. I won't let a
    model car defeat me so I do what I can to rectify the situation. There are no kits that
    I want to leave unpainted, and if I run across a rebuildable beater at a garage sale it
    has to be painted.
    Can any of you fellows (or gals) that spray with cans offer any solid tips? I've stayed
    with regular everyday hardware department primers and paints mainly because of
    the costs, but they've been biting me on the butt too often. If I could afford (or justify)
    buying only classic AMT screw bottom kits I'd could leave the bodies alone, assembling
    them the way I did as a kid, but there's not a plastic model car in the world worth $100
    and more just to fill my nostalgia jones. Right now I've got an older AMT '63 Galaxie
    kit that most likely won't get assembled because I'm not going to hassle with paint...
    plain white paint. Yeah, I guess I'm a quitter.
    Model 3.JPG Model 8.JPG Model 26.JPG Model 34.JPG Model 20.JPG Model 47.JPG Model 137.JPG
  4. pigIRON63
    pigIRON63
    I built number 27 as a nod to my grandfather, he raced jalopies at a dirt track in Watts Flats, Ny in from 1956 to 1960 when the track closed down.
  5. 41 coupe
    41 coupe
    from bristol pa
    Here are two more I just finished. 20191209_134321.jpg 20191209_134418.jpg 20191209_134341.jpg 20191209_134355.jpg 20191209_134531.jpg 20191209_134516.jpg 20191209_134641.jpg 20191209_134708.jpg ! 20191209_134405.jpg 20191209_134525.jpg 20191207_063203.jpg 20191207_063235.jpg 20191207_063224.jpg 20191207_063333.jpg 20191207_063433.jpg 20191207_063532.jpg 20191207_063646.jpg 20191207_063657.jpg 20191207_063516.jpg 20191207_063453.jpg 20191207_063739.jpg
  6. john worden
    john worden
    from iowa
    I feel your pain.
    I' am finding time to build models again and even with 42 years of professional painting experience the painting aspect of model building is a challenge. I'm going for perfection and i'm not there yet.
    I suggest relying on hardware store lacquer like Krylon for color only as sprayed and figure out which clear non lacquer is compatible for acceptable smoothness and gloss as sprayed.
    Different primer colors in thin coats may help achieving color with few thin coats. Try to then achieve the finished smoothness and gloss you want with non lacquer clear as sprayed. You may have to use an expensive clear on the less expensive colors.
    I could easily spray flawless high gloss smooth urethane enamel with my spray gun but all the seams and small details would be buried in clear even with a thin coat.
    I really don't want to get into a hand polishing routine but it might not be as troublesome as I imagine.
    NHRANUT likes this.
  7. NHRANUT
    NHRANUT
    from Western PA
    I agree that Krylon might best for you. It goes on great and usually requires very little rubbing out, and even the lacquer clearcoats will work on it. Downside is the lack of cool colors.
    Tamiya cans are also another great alternative. They spray 10 times better than Testors and Model Master sprays. Downside there is the cost of them.
    Lil32 likes this.
  8. quick85
    quick85
    John Worden...I've been trying my best with Krylon because of some of the colors
    available. My main problem is with the paint crazing on me. The first light coat of
    color over primer is no problem, after that all bets are off, anything can happen. No
    one on YouTube seems to be addressing the problems I'm having. You hit on the
    non-lacquer clear subject. That's my other main sticky point, find an enamel clear.
    Of course, if I can get a nice finish coat of enamel color down I wouldn't even bother
    with the clear. I appreciate your comments, thanks.
    NHRANUT...As mentioned above, I'm hip to Krylon and have gotten some good finishes,
    they're just not consistent. The colors Krylon offer work for me, so I'm good there. I
    wondered about Testors and Model Master, which you touched on. I haven't used them
    in quite some time and wondered about ease of application and any drawbacks. That's
    why I posted my questions. Someone's buying and using those products, they've been in
    business for a hell of a long time. Thanks for your thoughts and comments.
    Ron Funkhouser and 509garyd like this.
  9. NHRANUT
    NHRANUT
    from Western PA
    Testors and MM spray way too heavy, as has been said. Decanting and airbrushing is the way to go with them. The lacquers are a little better because they dry faster, but even with them the paint always ends up too heavy in places, and too thin in others.
    Not sure why you're having trouble with the second coat. The only thing I might suggest is letting the first coat dry a couple days, and then lightly wet sand the paint just enough to knock off the gloss before a second coat.
    And if you get a good finish, you don't have to clear coat it, IMHO.
    Those models you posted look pretty good to me. :)
    509garyd and quick85 like this.
  10. quick85
    quick85
    ^^ Thanks for your input. That's the info I was looking for. I'll admit, I get antsy
    and want to get the color down. I've got one in the works now that I shot silver
    as a base coat for a translucent color (Testors or Model Master) but I think I'll
    change direction. Also, I appreciate the complement. Mitch
  11. john worden
    john worden
    from iowa
    quick85.... Describe your crazing in detail. What are the physical characteristics if it?
    I would say that a trouble free first coat rules out product compatibility issues. If you tend to spray heavy than an overnight dry of the first coat is a good idea. Some colors cover better than others with few coats. A short test spray will give you an idea of how well a color hides and a clue to how much will be required.
    Remember too that because lacquer dries so fast it can trap moisture and blush in humid conditions.
    Luck. John
    NHRANUT likes this.
  12. quick85
    quick85
    John, simply put, the paint rises and bunches together. Never on the model as a whole,
    but in strips or sections, and it's never a case of spraying lacquer over enamel, that's
    what grabs
    me. I've tried to vary my spraying techniques...too light and it looks like the
    paint's too dry...too heavy and the runs appear. Since I know what I want the finished
    model to look like I try to take my time and not get heavy handed, I'll have to try harder.
    Again, thanks. You guys have given me things to consider (or reconsider).
  13. I have to agree that the easiest way to get very good results are Tamiya spray cans.
    Still they have some disadvantages: 1. They are very expensive for such small cans (just enough to do 1 model). 2. They have an extremely strong chemical smell, so you need a spray booth or work in an area that is far away from where you live. 3. they offer only a limited choice of colours.
    quick85, NHRANUT and 41 coupe like this.
  14. john worden
    john worden
    from iowa
    quick85.....One more comment. I feel that your first coat is heavy in those strips and sections but is not evident until the second coat goes on at which time the first reacts because solvents are still evaporating from the heavy areas.
    Patience is key.
    quick85 and NHRANUT like this.
  15. NHRANUT
    NHRANUT
    from Western PA
    As far as spraying Krylon goes, it dries VERY fast. Rather than spraying coats a day apart or more, you can spray the second coat within 10 minutes, and then maybe a 3rd coat another 10 minutes later and be done. That way it's basically all one coat. Don't worry too much about a heavy pass, just don't make 2 in a row.
    quick85 likes this.
  16. rudestude
    rudestude
    Wow...finally hit it on a Sunday...some good looking stuff being done
    Thought I would post a few shots of the 59 Imperial build , I managed to get it lowered,dechromed and doing a little fin work , including removing the taillights then off come the top..and kind of following the magazine article that I posted earlier I managed to get it reattached with out to much of a problem, even the windshield and back glass layed back into place after a little file work , well they were until I just had to file a little more on the back one ....and it happened...so I'm letting that simmer a bit and have moved on to a taillight idea that fell into my thinking, I decided to put a taillight down into the bumper that would go full width of the insert in the bumper...so I started carving on a piece of red lexan and noticed how bright the edge that was going to be the leading edge of the light was getting just from the light it was grabbing from my desk lamp....well now the tailight is becoming a little bit more involved...Fiber optics intered the picture, so here's a prototype that I'm putting together....of course that will most likely lead to running optics to all the lights.
    And this was going to be a mostly box stock build... 20191215_020709.jpeg 20191215_020111.jpeg 20191215_020029.jpeg 20191215_020456.jpeg 6398.jpeg 6301.jpeg 6299.jpeg 6394.jpeg
    Sent from my SM-T387V using The H.A.M.B. mobile app
  17. rudestude
    rudestude
    Have any of you guys tried any of this Auto-Air Colors water based non-toxic custom automotive paint on any models?
    A friend of mine has a cabinet full of this stuff, some pretty wild colors, lots of flakes, pearls, metallics and alot of them are small fine flakes and metallics that I think would be fine for scale on models.
    I haven't sprayed any of it yet, I'm considering trying the metallic gold on the Imperial...it says they can be sprayed using a airbrush, untill you get into the larger size flakes, and most of them can be sprayed straight from the bottle, no reduction.
    I was playing around with some today , just doing some sample blobs and mixing some around.
    Anyway I was just curious of anyone has used any of itbefore. 20191215_025331.jpeg 20191215_025046.jpeg 20191215_031901.jpeg 20191215_031747.jpeg
    NHRANUT likes this.
  18. quick85
    quick85
    I really appreciate the tips and knowledge you guys have shared about painting. I'm
    taking them all into account and paying attention. Now that winter is here it's time
    to get back to work. I have to say that I've wondered if messing with model specific
    paint was a better option but it doesn't necessarily seem so, according to you fellows,
    and I dig some of the Krylon colors. Thanks again.
  19. 65pacecar
    65pacecar
    from KY, AZ
    I’m glad to hear others having trouble with testors spray paint, I thought it was just me. Expensive and doesn’t work well anymore. When I was building in the 80s I loved their spray paint, now they are horrible.
  20. NHRANUT
    NHRANUT
    from Western PA
    It's not the paint, it's the spray cans!!! Decant it and airbrush it and it's fine
  21. raymay
    raymay
  22. 65pacecar
    65pacecar
    from KY, AZ
    Thanks. How do you decant it?
  23. NHRANUT
    NHRANUT
    from Western PA
    Usually through a straw into a bottle. Testors nozzles are the hardest, but you can trim the straw to the shape of the nozzle to help contain it it into the straw.
  24. Jimbo von Cartier
    Jimbo von Cartier
  25. froghawk
    froghawk
    This very basic friction toy made by Product Miniature Corporation (PMC) was based on their more detailed dealer promotional model. While the promo was molded in warp-prone acetate plastic, this car was molded in styrene. I recently received this one from eBay for $24.50 and as soon as it arrived the friction chassis went in the trash and I started doing the necessary surgery to fit a '59 Edsel chassis underneath it. A lot of material had to be ground away from the upper rear chassis to fit under the bed floor. After the chassis was installed, a stance adjustment was in order using my favorite rolling stock, '61-vintage AMT tires with wheels from a Revell '57 Ford (the chrome ones are by Little Motor Kar Co. and were borrowed from another car for this mockup.) The body needs a lot of moldline and flash cleanup in addition to fin-tip repair. While it's mocked-up here with an AMT '59 Ford windshield, I'll ultimately use a Revell '59 Skyliner piece, which is thinner and fits better. The virtue of all the 1/25 '59 Fords from Revell, AMT, PMC is their high degree of interchangeability, much like JoHan Mopar kits. I'm hoping working on this thing will bust me out of a slump!
    Auction pix below...
    The mockup. Ultimately the front will be one or two inches lower.
    This is where it stands now.... Got the stance where I wanted it...
    Worked more on the fin tip repair. Also notched in a piece to the rear quarter panel to fix a short shot there. And got the Skyliner bumper cleaned and prepped for plating.
    There was another short shot at the lower corner of the front fender, so I notched in piece from the Skyliner to fit there...
    Finally, hacked up an AMT '59 Galaxie interior to fit. Kinda thinking I'll want to do more custom work in here, maybe bucket seats and console from a '63 Galaxie...
  26. philo426
    philo426
  27. john worden
    john worden
    from iowa
    Liz and Cosmo try out the seat and eagerly await the construction of their new Lincoln Futura. Meanwhile..........
    They obsess over what to wear while riding in the new bubbletop.
    Color is the issue. They want to know what the HAMB suggests so post away.
    Liz has chosen fab loafers, checked capri pants and a sleeveless form fitting hip length top belted at the waist.
    Cosmo sports loafers, men's hose, cuffed slacks, a sport coat with sweater vest, shirt with button down collar and an ascot.
    Liz will most likely switch hair color to auburn for the occasion and Cosmo prefers gloss black hair. 102_2958.JPG
    Of course they will visit a tanning salon before delivery day as a precaution. They are quite the couple.
    I built one of these when first issued and it has not survived well with key parts missing. I shopped Ebay recently and scored a reissue for $20 delivered.
  28.
    509garyd and greaseSlinger57 like this.
  29. john worden
    john worden
    from iowa
    Yes they do and I like their choices of a one off Lincoln Futura and an Outer Limits "T"
    Liz seems to enjoy the physical attention she is receiving from Cosmo. That rascaly rascal.
    I nominate Liz and Cosmo Honorary Hamb Hudlums.
    Did you heat Cosmos right arm to re position it?
  30. I did a little minor surgery with an x-acto and some putty.
    Lil32, Deuces, Chrisbcritter and 9 others like this.
