Technical 1955 chevy PU suspension upgrades that made a HUGE difference
Discussion in 'The Hokey Ass Message Board' started by custom_lettering, Jun 29, 2017.
  1. squirrel
    I have an IFS and a stocker. They're both fun to drive, the IFS is smoother, but I can live with either one just fine.
  2. BJR
    BJR
    Doesn't the whole front suspension from a 70's something Chev truck bolt right in to these mid 50's trucks?
  3. custom_lettering
    custom_lettering
    from Wall, NJ
    I know the Camaro/Firebirds do. Put one under a 58 fleetside.
  4. Jim...I got a feeling your roads are a lot better than our roads in the Midwest, which mite help, correct me if I'm wrong, you've driven on em all.
  5. cal1320
    cal1320
    from Florida
    2 leaves removed. 1 1/8" sway bar. Modified a Geo tracker bar. 20170702_155249.jpg 20170702_155712.jpg
    jeffd1988 likes this.
  6. belair
    belair
    Mines clipped, but I'm looking for another one to keep the straight axel. Good info, and your truck looks great.
  7. willymakeit
    willymakeit
    Both at same time,off of a Ford bronco 2
    Sent from my K88 using The H.A.M.B. mobile app
  8. custom_lettering
    custom_lettering
    from Wall, NJ
    I drove it hard today and the slight body roll it has left was very tolerable. But I ordered a front sway bar and will install it when it comes in.
    I'll report if it's too tight or made it even better.
  9. custom_lettering
    custom_lettering
    from Wall, NJ
    **** UPDATE 7/19/17 ****
    Well I installed the new 1 1/8" front sway bar. Truck is even better. Really thought it was going to be to tight but it's not.
    If I ever get to ride in a truck with a MII front suspension I'll compare the two.
    My truck came with a dropped axle so that's why I added to that setup.
  10. Thanks for the update, and I'm glad it worked well too!
    Cosmo49 likes this.
  11. MO_JUNK
    MO_JUNK
    from Rolla, Mo.
  12. 57tailgater
    57tailgater
    from Georgia
    Any updates on the front sway bar?
  13. custom_lettering
    custom_lettering
    from Wall, NJ
    Front sway bay added even more stability. Very happy with the set up. I just sold the truck a few weeks ago and the gentleman drove it from my place in NJ to his home in Michigan and loves it.
  14. Jeff56
    Jeff56
    Did you get to compare the axle with the front sway bar to a mustang 2 suspension?
  15. custom_lettering
    custom_lettering
    from Wall, NJ
  16. Kelly Burns
    Kelly Burns
    This is perfect! Exactly what I want for my daily driver!
    X-cpe likes this.
  17. custom_lettering
    custom_lettering
    from Wall, NJ
    It was mine up to 2 weeks ago. Great truck
  18. How much was the drop in the front axle and where did the front sway bar come from ?
  19. junkyardjeff
    junkyardjeff
    Did it have the original steering box,I have a 37 with a 41-6 box that probably should be rebuilt but its not all that bad and would like to do some improvements.
  20. Joe H
    Joe H
    I am interested in the shocks you used, how did they compare to the Monroe's? Stiffer? Softer? What made them ride so much better? I run Monroe on my'37 and feel they may be to stiff.
    Joe
  21. custom_lettering
    custom_lettering
    from Wall, NJ
    smooooother they took the harshness out of the ride.
  22. chevyorange
    chevyorange
    What wheels are those? I like the stance a lot. I just bought a 51 GMC and I want to do something similar. Cool truck.
    Sent from my SM-G950U using The H.A.M.B. mobile app
  23. custom_lettering
    custom_lettering
    from Wall, NJ
  24. cageman
    cageman
  25. PanheadRon
    PanheadRon
    I took your advice on the Bilstein shocks up front from Posies. Tough shocks! Yes, I had the Monroes.. Always hit bumps hard. Seem to work on the rebound only. I don't have a rear sway bar....yet! Up front is a factory 7/8" sway bar from a Panel truck. It's just ok. I believe it was just to help the top heavy Panels. I noticed that all the aftermarket sway bars are 1" front & 7/8" rear. The Bilsteins are a big difference. The truck may be fine now. Road test will tell. Anyway, thank you for your input.
    swade41 likes this.
  26. jetnow1
    jetnow1
    from CT
    1. A-D Truckers
    Close fit on frame of 47 to 55.5 trucks,(needs a about a 1/2 inch spacer each side) not close on later series. A little wide on the 47 to 55.5 though.
  27. RyanPartridge
    RyanPartridge
    I did similar mods to my 57 and got great results, I’m fairly convinced it handles better than it did new. It’s a blast to drive.
    I had Sid drop the original axle, re-installed with 4 degree caster shims, Posies super slider springs, Bilstein shocks, and a front sway bar.
  28. dudley32
    dudley32
    Nice truck...I'm working on a "57 as well...How much drop on the axle?
  29. southcross2631
    southcross2631
    Put power steering on one and your wife will comment on how nice your truck drives after she drives it. I converting my 64 F100 and my ex drove it all the time until I sold it.
    It had 9 inch wide front tires with a slide in camper in the bed. I used a mid 70's Gm box.
  30. RyanPartridge
    RyanPartridge
    3" drop
