Technical 1930 ford and Volkswagen rims?
Discussion in 'The Hokey Ass Message Board' started by Jim Lato, Dec 1, 2019.
  1. Jim Lato
    Jim Lato
    I know Volkswagen is a swear word but recently I heard you can use Volkswagen 5.5 rims on early fords big 5.5 bolt pattern? Has anyone heard this before?
  2. Mr48chev
    From reading this I don't think that any one of the three VW wide patterns matches up. https://www.fordbarn.com/forum/showthread.php?t=119761
    I new a guy who used the VW hoop on some US made centers cut out of some wheels back in the 70's because he wanted to run the skinny 15's on the front of his rod with steel wheels and hubcaps and have a rim they actually fit. He had access to an industrial machine shop with a lathe that would handle something 40 inch in diameter if needed so it wasn't a big deal for him.
  3. manyolcars
    manyolcars
    I hoped to use VW hoops but they dont measure right
  4. I believe you have been mislead. HRP
  5. Jim Lato
    Jim Lato
    I think you guys are right. I would like skinny-er tires on the front of my 30 but utilizing a different rim but original hubs and bolt pattern. But I may not be able to accomplish this
  6. clem
    clem
    How skinny ?
  7. A0B20E21-805A-4041-A75A-4065F1859B0C.png There’s adapters for anything.
  8. Jim Lato
    Jim Lato
    Oh sweet. That will work perfectly. Just wanna run big and littles on the 30
  9. alchemy
    alchemy
    I think what you "heard" was the VW rims were swapped onto the old Ford centers. Not the whole wheels, just the rims. I'm not sure if the guys used to use the 15" steely centers or the 16" steely centers. Should be easy for you to measure once you have the old VW wheel in hand.
    Nowadays the old VW wheel might be worth more than the old Ford wheel. I think the ones they used to use were from the 50's, and those are the VW's that are skyrocketing in price.
    clem and 62rebel like this.
  10. treb11
    treb11
    There was a tech article in Hot Rod in the '70s about welding early Ford centers into VW hoops.
    Sent from my SM-G965U using The H.A.M.B. mobile app
    The37Kid likes this.
  11. Tim
    Tim
    from KCMO
    40-48 ford wheels are typically 4.5 inches wide and 5.5x5 bolt pattern. How skinny do you want to go that a 4.5 is to wide?
    Or are you more after the 15” diameter? I’m sure there’s something that already has the right pattern
    clem and Blues4U like this.
  12. alchemy
    alchemy
    The '40 and '41 wheels are 4" wide. Sounds skinny enough to me, but if you want to get really narrow you could source a pair of '40 Ford V8-60 wheels which are 3.5" wide.
    I think most of the 1950's F-100 wheels (the kind that accept the 40-48 caps) are 15" x 5.5" wide. There are some wider, but are harder to find.
    clem likes this.
  13. clem
    clem
    Which are quite rare, thus hard to find.
    I have 4” wide on my coupe with 450/475 x 16” and they are almost too narrow, - but look good.
    Next time I will probably go 550 x 16” for a little more road contact.
  14. Jim Lato
    Jim Lato
    Well I do have some of these old Vw rims laying around and would like a skinny 3.5” tire on the front of the 30 ford I’m goofing with. So this has struck some interest!
  15. Tim
    Tim
    from KCMO
    39 Lincoln wheels look like a 40 ford and are also 3.5 wide if we are making a list lol.
    sticking a correct center in a different/smaller hoop is pretty common. If that’s the route you wanted to go
  16. Jim Lato
    Jim Lato
    I’m gonna have to do more research on these swaps you guys are speaking of.
  17. Jim Lato
    Jim Lato
    Ya I’d like to go down a size 15” or so. I’m gonna have to do some looking
  18. Jim Lato
    Jim Lato
    Anyone have a photo of these modifications that they made back in the day? Or know where this article is? I saw there was another guy sourcing for the same thing on jalopy. No luck tho
  19. F&J
    F&J
    There is a thread on here from 2009 that I started, some text & pic below: (Link to the whole thread is below the pic.)
    2009>>>"I had some trouble getting the Ford hoop off after the rivets were removed, so I cut through the hoop to make it easy.
    Also cut the VW center up in pieces to go faster, VW center is welded in spots. (the whitewall tire/wheel is a stock 16 ford awaiting cutting)
    the dismounted wheel is the VW/Ford 15 steelie.
    I finally figured out the best way to cut the Ford center down on an AAMCO brake lathe, was to use one side of the Disc cutter.
    I got lucky and didn't cut it too small. it's a force fit with a large rubber mallet.
    Now I'll sandblast, then weld.
    Looks good to me
    F&J, Oct 7, 2009 Edit Delete !Report!"
    https://www.jalopyjournal.com/forum...e-used-with-vw-skinny-outer-rim-hoops.405351/
  20. Jim Lato
    Jim Lato
    Well I have 5 wide 5 rims for my 30 ford that I did find. Steelies. So I got my doner centers. And I got three junk Vws sitting behind the barn a 67 and 68
    Tim likes this.
  21. Jim Lato
    Jim Lato
    2 I mean. So I could make my fronts and either use the stock doner rim or find a wider ring to weld onto the centers.. I just want to have an old school look to it.
  22. Tim
    Tim
    from KCMO
    1949 and up trucks have the correct bolt pattern in a 15” rim.
    I think I’d do whatever @F&J recommends. He’s pretty good at spending more time than money to make something cool
  23. Jim Lato
    Jim Lato
    The only issue I’ll run into is turning down the vw rim to fit that 15” truck center I was talking about
  24. Jim Lato
    Jim Lato
    Don’t got a lathe. But I will probably be able to figure this out
  25. alchemy
    alchemy
    When you say "wide five" all us old Ford guys read is a 36-39 Ford wheel. The 5.5" pattern is just regular old Ford, not wide.
    Looks like the modification is to get a 4.5" wide 15" rim onto the center from a 16" rim. It should look a whole lot like the 5.5" wide 1955 Ford F-100 wheel. A lot of work for an inch of width.
    Jim Lato and King ford like this.
  26. rusty valley
    rusty valley
    i have an old ford wheel that is 14", center looks just like the 40-48's. never seen another, i'll take a pic tomorrow
  27. King ford
    King ford
    from 08302
    Part,of what is taking place here seems to be the misuse of the word RIM. many people erroneously call an entire WHEEL a RIM which an entire wheel is not. The rim is only the outer portion which is riveted or welded to the center. Use of the wrong terminology OFTEN seems to cause miscommunication when discussing WHEELS.
    TagMan likes this.
  28. stanlow69
    stanlow69
    If you want a skinny wheel, try donuts. I have a set of 5 on 5 that are 19 inchers. I thought they would look good o a 40`s style roadster. Many more styles and bolt configurations out there as well.
    Jim Lato likes this.
