Auctions
1929 Ford Model-A Roadster
Discussion in 'Cars For Sale' started by N2hotrods, Nov 26, 2019.
  1. N2hotrods
    N2hotrods
    City: Show Low
    State: Arizona
    Price: 14,000
    Hopped-up 4 Banger. Original body was a Model A Sports Coupe. Professionally converted to Roadster. Body off frame restoration & modifications. New soft vinyl interior in light tan color. New brakes, levers & hardware. Rebuilt front & rear suspension. Rebuilt 2 tooth steering box. Rebuilt rear end with all new bearings & seals. Rebuilt transmission with new bushings, bearings & anti leak kit. New clutch, pressure plate, throw out bearings & surfaced flywheel. Engine has been completely rebuilt with new Babbit bearings, rebuilt rods, new Ross pistons & Hasting rings. Valve train has been converted to late model Chevy stainless valves, springs & retainers. New Stipescam with touring grind. New lifters. New oil pump. Aluminum timing gears. Oiling system has been converted to center main & front main pressurized oiling. Head & block were surfaced for 5.6 compression ratio. Rotating assembly was balanced with the flywheel & clutch. Ignition system was upgraded to a Model B with Integral advance. Fuel system is electric fuel pump with a downdraft conversion to a Holley carburetor. Exhaust is custom built Lakester style headers. New Excellsior tires on 1935 Ford wheels. Electrical system upgraded to 12 Volt with modern generator & regulator. Great TROG car! Runs & drives excellent. Arizona Title. Might consider ATV or electric golf cart. Asking $ 14000. O.B.O.
    Contact: Marty
    928-251-2493 NO TEXTS
    [email protected]
    DRIVER SIDE FULL.jpg DRIVERSIDE BUILDING.jpg DRIVERSIDE BUILDING.jpg DSIDE 1.jpg ENGINE 1.jpg ENGINE 2.jpg ENGINE 3.jpg ENGINE 5.jpg ENGINE.jpg FRAME.jpg FRONT PASSENGER SIDE.jpg green1.jpg INTERIOR 1.jpg INTERIOR 1.jpg INTERIOR DASH.jpg INTERIOR 1.jpg INTERIOR DOOR.jpg INTERIOR DASH.jpg INTERIOR SEAT 2.jpg INTERIOR SEAT .jpg
  2. N2hotrods
    N2hotrods
    New lower price, $ 14,000. Want it to go to it's new home!
  3. N2hotrods
    N2hotrods
