Technical Need help identifying steering column
Discussion in 'Traditional Hot Rods' started by Ben Chirco, Oct 21, 2019.
  1. Ben Chirco
    Ben Chirco
    I just purchased a 1930 Model A. I am trying to identify all components of the car for future reference. I have no info from the previous owner on many components.
    It has a steering column that I need help determining what it is. It has tilt and cruise. The cruise does not work. And I dont care about the cruise. I do want to do want to know what the column is.
    Any help would be great.
    steer1.JPG steer1.JPG steer2.JPG steer3.JPG steer4.JPG steer5.JPG steer5.JPG steer4.JPG steer3.JPG steer2.JPG steer1.JPG
    36 Master deluxe likes this.
  2. Model A Vette
    Model A Vette
    Gm probably around 1976.
    kidcampbell71 likes this.
  3. squirrel
    I'd guess 69-76ish. GM for sure, If we could see the whole thing, then it might be easier to ID.
  4. 41fred207
    41fred207
    Yes, a couple more pics should do! Lol
  5. its 70's GM style column with that cruise switch
  6. BJR
    BJR
    Is there a shift indicator on the top? May be an AMC column, Mostly a GM column with a few changes.
  7. Here is the one out of my 76 Buick century
    late 60's style had a crescent moon style connector, I do believe about 73 GM went to the flat style connector like yours..
  8. Kind of odd to see the cruise on the tilt lever though......
    Normally on the turn signal lever
  9. BJR
    BJR
    AMC had the button for the electric overdrive on the end of the turn signal lever.
  10. squirrel
    That cruise switch is NOT factory, it's a Perfect Circle add on unit.
  11. blue 49
    blue 49
    from Iowa
    1st year of column ignition switch ('69?) didn't have the lane change feature on the turn signal switch. Might help to date it.
    Gary
  12. junkyardjeff
    junkyardjeff
    I would say late 70s.
  13. 31Apickup
    31Apickup
    It is pre 1978
  14. Ben Chirco
    Ben Chirco
    I will try to get better pictures today in the sunlight. Thanks guys. I appreciate the help.
  15. Ben Chirco
    Ben Chirco
    Here are a few more picts of the column steer7.JPG steer6.JPG . I cant find any identification letters or words
  16. Ben Chirco
    Ben Chirco
  17. choptop40
    choptop40
    To be exact you have to know the length..and splined or double D ...
  18. BJR
    BJR
    I think it's an AMC floor shift column from a Gremlin, Hornet, or Javelin. Basically a GM column, AMC sourced from GM.
  19. squirrel
    Why not from a GM car? It looks like the floor shift interlock lever at the bottom was cut off.
    Also, is it important what exactly it's from? If so, why?
  20. saltflats
    saltflats
    from Missouri
    The long shift/interlock collar makes me think Corvette.
  21. DOCTOR SATAN
    DOCTOR SATAN
    from okc
    Purple wire, must be gm...
  22. Ben Chirco
    Ben Chirco
    Thanks for the help.
    I need to find out because i need to order some parts for the horn and for the tilt wheel mechanism.
  23. gene-koning
    gene-koning
    Isn't the key upside down for a GM switch? It the lock position, the cut edge will be on top, by the way I'm looking at the picture. Mopar or AMC would be my thought, but the parts you need to order would probably be GM anyway, and that would likely be the only source you will be able to get those parts. Gene
    squirrel likes this.
  24. Budget36
    Budget36
    I vote see the column, change it out for something more suited to a Model A. ;)
  25. 427 sleeper
    427 sleeper
    Nope, the key is right, teeth down. I vote mid 70's GM.
  26. David Gersic
    David Gersic
    from DeKalb, IL
    It’s a GM column. Measure the distance between the prongs of the wiring harness connector bracket. That’ll tell you whether it’s older or newer.
  27. goldmountain
    goldmountain
    GM column from 1969 to 1978 due to the lack of column dimmer switch. What does it matter what it is from? All these columns use the same parts. Only difference being the length, bottom splines, shifter or not, and key lockout mechanism. AMC, IHC, and Chrysler use the same parts in their tilt columns of this era.
    Sent from my SM-T350 using The H.A.M.B. mobile app
  28. Ben Chirco
    Ben Chirco
    Thanks again for the help.
    I did not know that "AMC, IHC, and Chrysler use the same parts in their tilt columns of this era".
    Also, i am attaching a picture of what i think David Gersic meant by "Measure the distance between the prongs of the wiring harness connector bracket" . These pictures with the tape measure on them are taken of the column harness. Maybe that can help. Thanks again.
  29. squirrel
    The bracket is the metal part that's spot welded to the column, that that plastic connector fits into. But measuring the width of the plastic connector tells you the same thing, eh?
    Assume the column is from a 1973 Camaro, and buy your parts.
    David Gersic and 427 sleeper like this.
  30. Ben Chirco
    Ben Chirco
    Thanks so much for helping out. Really you guys are great. Here is a picture of the car. I am sure you have not heard the last from me.
    David Gersic and dudley32 like this.
