Vintage Sun Tune Up, Testers, Scopes, Analyzer, Distributor Thread
Discussion in 'The Hokey Ass Message Board' started by Flathead Johnny, Oct 14, 2013.
  1. Truck64
    Truck64
    from Ioway
  2. I finally found a VAT-28 with a cart locally that was reasonably priced. Needs a good cleaning (which I have started.)
    Now if I could just find a reasonably priced battery charger I think I’d be done for a while...:rolleyes:
  3. 33 Ford Sedan Delivery
    from Fl
    Looking for a Sun 506 Distributor tester and flat head ford adapter.
    Thanks
    I put it to work on my 390. Timing light works. Ordered some new vac hose as it was cracked and leaking.
    Anyone have a manual for this “late model” machine? FD843B07-AB90-4B4F-A27B-47944317B85C.jpeg
    Bowtie Coupe likes this.
  5. slack
    slack
    I got a "manual" with multiple models on DVD from a guy in Missouri (I think). I mentioned him in a post on here. I'll see if I can find his phone number tomorrow. If not, maybe I can "burn" you one.
    j-jock and Bowtie Coupe like this.
  6. Thanks!
    Bowtie Coupe and loudbang like this.
  7. Ziggster
    Ziggster
    Posted a thread on the Barn, but thought I would here as well. I picked up this Allen Syncrograph Model E-316 yesterday. I have the original manual, but I'm looking for any additional info and any adapters that will work with the Ford flathead distributors. I'm interested in restoring it, and perhaps using to test my flathead helmet distributor. It powers up and lights up, but I haven't done anything more as I read somewhere you really shouldn't as damage may result due to the age of electrical components. From some other pics on the web, it seems to be circa 1953. It also seems to be popular with hotrodders as I found a few pics of resto restored versions as well. I must say, I do like the Art Deco influenced design.
  8. WTF really
    WTF really
    Very cool looking.
    loudbang and Unique Rustorations like this.
  9. Marty Strode
    Marty Strode
    I have this one for 35 years or more, only used it a couple times, it will look good in the pseudo gas station I am putting together. IMG_3861.JPG
    j-jock, Truck64, Dog_Patch and 4 others like this.
  10. I have a 506 tester. I am in Venice FL, hopefully not far from you. Please call 734-788-8607.
    Thanks. Bob
  11. Rickel
    Rickel
    Hello To All: This is my first post on this forum and I must admit I am impressed by the wealth of knowledge here. I am more of a motorcycle gearhead than a car guy, but I do own a Aussie built 2017 Chevrolet SS. I work on older motorcycles that generally have point ignition systems. I have been searching the Internet for what seems like an eternity for someone who could repair a Sun TDT-11 Tach and Dwell meter for me. It is obviously an older meter probably from the 1960's. I hate to make my first post a question, but the knowledge base here on Sun Test Equipment is quite unbelievable. Thank you!
    Rickels
  12. Rickel
    Rickel
    Sorry if I offended anyone with my first post above. I don't like immediately asking a question on a new forum, but I was drawn here by all the chit-chat about Sun Test equipment. For the most part there isn't much out on the Internet regarding these pieces of equipment. If no one is aware of anyone that can repair the TDT-11 meter I have, does anyone know where I may be able to obtain a schematic for it? Thanks again for any help on this.
    Rickel
    tractorguy likes this.
  13. WTF really
    WTF really
    Wish I could help but unfortunately not a clue.
  14. egads
    egads
    @Rickel I don't think you offended anyone.You might try contacting Mark at paramountd.com. Great guy to talk to and might be able to help you out.
    tractorguy and loudbang like this.
  15. jbauto1955
    jbauto1955
    hi to all. new member here also. recently acquired a sun master motor tester I believe to be late 50,s since it operates on 12 volt rather than 6 volt car battery. also looking for some repair info. on the tach/dwell tester there are 2 receptacles for a battery. the lower one takes a 1.5 volt flashlight battery but the upper 1 is only 3/8 in.deep.was told it also used a 1.5 volt battery that is no longer made & has to be converted to use a 1.5 volt d cell flashlight battery. I need to know if this is correct & if so, where I can find another d cell battery holder to convert it with. also need 1 of the bake light covers for the holder & 1 knob. any info on where I can find these is appreciated. also info on anything that I need to look at or replace since I bought this unit to get it working & use it before I try it out. thanks, jbauto1
  16. egads
    egads
  17. rusty stuff
    rusty stuff
    I have a lot of old Allen, weidenhoff , test equip , I restore cosmetics,see pics! I need info, manual for the one on the left side of ad ! Anybody seen one The syncrograph 036.JPG 1935 tester 003.JPG 1935 tester 003.JPG 1935 tester 003.JPG 1935 tester 003.JPG 1935 tester 015.JPG
  18. 1953naegle
    1953naegle
    I found this Sun 200 set up 10 years ago in the loft of a closed auto repair shop. It was missing the middle two units but I found them on Ebay. My biggest issue is that there are missing or damaged leads, so I have some replacment wire and am machining the special threaded terminals to crimp onto the ends. The Voltage Ignition tester and the Vacuum/Pressure tester both work fine. The Tach/Dwell tester and the Distributor tester (like a timing light) might work once I get the right leads sorted for them.
    Also have a manual sun distributor tester
    Sun compression tester
    Sun Battery Tester. Also works fine.
  19. egads
    egads
  20. rusty stuff
    rusty stuff
    Thanks alot its all done by me and one Bud Heres some more goodies 1935 tester 017.JPG laRGE 508.JPG new arrangement on testers 021.JPG
  21. CGuidotti
    CGuidotti
    My son just pick this up a couple of weeks ago, most of the leads are crispy and need to be replaced.
    j-jock, egads, Bowtie Coupe and 4 others like this.
  22. cactus1 and loudbang like this.
  23. 3249D592-2047-47DE-9259-B40A0D8D2650.jpeg F569D05D-294A-4B3F-B371-8ABDCC9A8094.jpeg CB9754F9-4CFE-4EB3-A35A-01B65E4C559F.jpeg I have a cool old portable Allen Test Products teaching aid. A friend of mine got it working and we hooked it up to his Sun machine. It was really cool watching the results on his screen as we tried different settings. I’m sure they are out there but this is the only one I’ve ever seen.
    j-jock, egads, Bowtie Coupe and 2 others like this.
  24. 0D019139-7CC2-4FFA-88CF-A6510A4A3545.jpeg B133BEE2-22A7-426D-BEC1-DEE2F2047739.jpeg 9A624B64-72AA-4B3F-A048-B0EE997CF1B1.jpeg 70B581B0-1E7A-4140-AE1C-F89BBBE62FD6.jpeg
    Picked up two old portable testers the other day. Sorry for the bad pics of the units, those are the ones that the seller sent me. I took nice clear pictures of the tags...but no pics of the units themselves. :)
    j-jock, Bowtie Coupe, cactus1 and 2 others like this.
  25. Very cool, our auto shop teacher ( 76/77)made one of these and showed us in class
    wraymen and loudbang like this.
  26. I picked this balancer up a few weeks ago. I’ve been wanting a tire balancer to go with my old coats tire changing machine for years. I never knew Sun made one and when this one popped up I had to have it! Works a treat! 80E3816B-95C7-4277-A998-DA3ABCD3FE00.jpeg I don’t think I’ve posted this compression tester before. I got it a couple years ago. Sun made the most stylish test equipment ever IMHO! 26F6B35E-CB0A-4A84-A2FC-6B15C67106C0.jpeg 60686B75-0AD0-4C48-87EE-8571ADCB4656.jpeg
  27. By the way, if anyone is in need of a restoration project, let me know. The two portable testers I posted earlier could be made available.
  28. choppedtudor
    choppedtudor
    I had this show up at my garage yesterday...it's 100% Complete and seems fully functional, needs a little TLC and a new paint job on the base, but it's a welcome addition to my hotrod garage. IMG-0447.jpg
  29. AngleDrive
    AngleDrive
    from Florida
    I have one of those and I love it.
