Hot Rods What do you think of this build?
Discussion in 'The Hokey Ass Message Board' started by Lowbuckbuilder, Oct 20, 2019.
  1. Lowbuckbuilder
    Lowbuckbuilder
    from San Diego
    Screenshot of an article in a hot rod rag i’m reading. Thinkin’ this fits the mold of the hazy 60’s hot rod vision i had for my plymouth. (Add two extra doors and probably a hood top.)
    Here’s mine, so far. Thinkin’ a 3” chop is in my future:
  2. Rickybop
    Rickybop
    It's channeled, too.
    Don't see too many chopped and channeled full fendered hot rods.
    Sent from my VS835 using The H.A.M.B. mobile app
  3. Rickybop
    Rickybop
  4. Chopped, channeled and sectioned as well?
    scrap metal 48 likes this.
  5. rusty rocket
    rusty rocket
    Not my cup of tea. I'm not a fan of East coast style hotrods. But hey it's your car and if ya dig that style then that's what you should build.
  6. adam401
    adam401
    The article car is cool. Pulling that low pancaked look off with a car that has parallel leafs in the front is gonna be tricky. Definitely gonna have to have an eye on the proportions so it deosnt look too long. I feel like a visor would help that Plymouth too.
    Good luck looks like your starting with a nice solid car.
    Lowbuckbuilder likes this.
  7. woodiewagon46
    woodiewagon46
    from New York
    Usually when you hear, chopped, channeled and sectioned means uncomfortable to drive. Think it over before you start cutting.
    Lowbuckbuilder and jim snow like this.
  8. Lowbuckbuilder
    Lowbuckbuilder
    from San Diego
    Yup, i have the visor sitting up in storage. Gonna add it back on eventually. It’s actually pretty functional with a vertical windshield to shade the ☀️
  9. If you plan on replicating that style I hope you ain't tall, chopped/sectioned and channeled is designed for the shorter guys. HRP
  10. Fordors
    Fordors
    That car doesn’t look sectioned to me.
    lurker mick and upspirate like this.
  11. Look at how close to the body line the rear fender is.
    Now look at a stock model A. HRP
    Jalopy Joker and alfin32 like this.
  12. catdad49
    catdad49
  13. upspirate
    upspirate
    HRP, it's channeled....look at the height from the window to the bottom of the door/body. I don't think it's sectioned either
    Hnstray and kidcampbell71 like this.
  14. Fordors
    Fordors
    And I would suggest you compare the height of the running board apron on the hot rod to that of the stocker you showed. Then you can also compare the positions of the hinges to those on a stock body just to be sure.
    True, the fender is higher, but only because of the channel job.
    Hnstray, Ned Ludd and upspirate like this.
  15. I have to agree with the others
    Car is NOT sectioned.. It is channeled though and fenders brought up to fit the tires correctly.
    Look how high the front fenders are to the hood.
    Again unusual to see a full fender channeled car.
    upspirate likes this.
  16. Mr48chev
    In simple terms they left the fenders on the stock brackets and dropped the body down to them while raising the rear wheel wells to keep the fender height matching the running boards.
    If I was lowbuckbuilder there would be NO FRIGGING VISOR: the car isn't a damned lowrider bomba so it doesn't need a damned ugly ass visor tacked on it.
  17. upspirate
    upspirate
    Most Model A's came with a visor, not sure about Plymouth s', but I like the look on Model A's
    I'm even going to go so far as to say I like the header with visor on an "A" better than the header on a '32 car.Trucks of course had them
  18. Lowbuckbuilder
    Lowbuckbuilder
    from San Diego
    Here’s a 4” chopped Plymouth 30-u for reference. Bit agressive, IMO. ...makes me feel like 3” would be just right
    It’s also, channeled, 3-4”, but i honestly don’t know about my desire to channel. The chop definitely is a preference, but i kind of like the un-channeled look, too, especially with fenders.
    Might have to put together a quick photo-chop.
  19. Lowbuckbuilder
    Lowbuckbuilder
    from San Diego
    Yeah, i think i read that the rear fenderwells were mini-tubbed, too, to fit 31’s if i’m not mistaken. I feel like i could still go bigger in the rear without having to tub out and modify as much sheetmetal. [shrug]
  20. arkiehotrods
    arkiehotrods
    Neat car but doesn't look at all like a 60s hot rod to me. But it's been 50 years since I was in the 60s so maybe I forgot.
    Texas Webb and Lowbuckbuilder like this.
  21. Never2old
    Never2old
    from so cal
    If it’s not shiny it’ll be a rat rod to most people. Okay if that’s what you’re aiming at.
  22. 6sally6
    6sally6
    Chopped I understand...............channeled just how is that done? Body kinda slid-down on the chassis? Body slid-down OVER the chassis? Is the body kinda shortened too?
    How bout a tutorial in a couple pics?!
    Thanx in advance
    6sally6
  23. Rusty O'Toole
    Rusty O'Toole
    The usual way to channel a car is to cut away the floor from the body all the way around and let the body drop down over the frame then weld it back together.
  24. Lowbuckbuilder
    Lowbuckbuilder
    from San Diego
    Yup, just watched an eastwood video a couple months ago. I had the same question. Its a very distinctive look, and a lot of work. It doesn't make much sense in my case, because i’m a big guy, i have very solid floorboards and i dig the un-channeled look.
    Probably do a chop, go a bit bigger with the back tire on steelies, and see if that makes me giggle enough. :)
  25. Lowbuckbuilder
    Lowbuckbuilder
    from San Diego
    Something like this. original on top...
  26. garage2small
    garage2small
    I saw that Model A sedan up close at TROG it is very well built and has plenty of room inside,there is a four page write up about it in this months Street Rodder. 2019 trog (154).jpg
  27. Country Joe
    Country Joe
    I can't tell if its an optical illusion. But the front fenders seem to ramp up at a steeper angle towards the front tires. But i like the car.
  28. I think the same guy(s) built this coupe I saw at Jalopyrama this year.
    I like the style and from what I've seen, they do good work
    (you can see the mag feature car in the background)
    Chappy
