Technical To drill or not to drill.
Discussion in 'Traditional Hot Rods' started by reekie6, Oct 17, 2019.
  1. reekie6
    reekie6
    Drilled vs. non drilled 32 ford axle. Any performance differences? Thanks
  2. chop job
    chop job
    from Wisconsin
    1. WISCONSON HAMBERS
    Drilled , better air flow.
    joel, carothersbs, Mark Grabo and 3 others like this.
  3. Budget36
    Budget36
    Ya...I mean 1 pound less will really get ya down the road. Until you're scratching for .0001...pretty sure it's for looks:)
  4. BJR
    BJR
    Non drilled, much stronger, what is your life worth?
  5. Put black dots on it, nobody will know....
  6. Budget36
    Budget36
    Silver see through paint...naw...would add weight...slow him down. Never mind.
    Hombre and VANDENPLAS like this.
  7. Mr48chev
    Any time you have to ask the opinions of others because you are undecided the answer is NO. This time no holes.
  8. Depends on the style of car really, just stick some quarters on there where you think you may want a hole then walk away from it for about 30ft, do an about face and if it hits you then do it, if first impression is nope then don't do it.
    Hombre, vtwhead and Jim Bouchard like this.
  9. I suppose it all depends on what look you're going for.........
    Stock Racer, J.Ukrop, Jibs and 16 others like this.
  10. seb fontana
    seb fontana
    from ct
    Them's a lotta holes!!
    MO54Frank likes this.
  11. Mike VV
    Mike VV
    from SoCal
    Mr48Chevy (above) has the right idea..!
    Mike
  12. bangerbob
    bangerbob
  13. reekie6
    reekie6
    Wow tough crowd. I have no intention myself to drill an axle. The question was asked on another forum what the best axle for a model A build was. A 4” dropped drilled or non drilled. I replied my favorite was a 32 heavy with no hole. And also said drilled axles flex more then a solid axle. I was then told their is no difference between drilled and non drilled. But the looks and a little lighter. So figured I’d ask this forum what they thought. And wow guys did you forget why you come to these forums?? To get away from the day to day stresses. Not add to them. I’m almost sorry I asked.
  14. Hot rods are about going fast and looking good.
    If it looks good, do it!
    Dino 64 and Muttley like this.
  15. Mongoose III
    Mongoose III
    Holes, but keep then a hole diameter apart and you still have a strong enough axel.
    joel, nunattax, clem and 4 others like this.
  16. Boden
    Boden
    Holes is the only way to go. Screams hot rod.
  17. You're in the wrong place if you didn't want the truth, no body said anything to cause you stress, you ask a question and the people answered. No harm no foul . BigO
    -Brent-, Cosmo49, abe lugo and 15 others like this.
  18. WB69
    WB69
    from Kansas
    Prefer the no hole myself. Seems like it would compromise the strength of the axle. Just my opinion though.
    bowlingball likes this.
  19. reekie6
    reekie6
    I am all about the Truth. I have no stress seems the people answering me were stressed though. Calm down let’s have fun.
  20. BigO, is plain spoken and calls them as he see's them, ask a question and the answers will be varied on the hamb ,no one is stressed just matter of fact.
    I think it depends on the build, Rocky's coupe is a ideal example of a car that looks just right with a drilled axle, it's a hiboy, it's chopped and it screams HOT ROD, on the other hand my old beater is a full fendered old car and with the front splash apron the axle is not a focal point, so it would be a moot point to drill my axle. HRP
  21. belair
    belair
    In Texas, we always say "drill."
    Jrs50, Bandit Billy, clem and 3 others like this.
  22. My standard answer:
    If you're not sure which way to go, only drill halfway, then stand back and cover one eye, then.................
  23. Hot Rods Ta Hell
    Hot Rods Ta Hell
    ^^^^ There's your answer. Read the replies, look at pics and go with your gut. It's really an aesthetic deal. Unless you drill all the holes so close together that it essentially becomes a long "slot" where fracturing could occur between the holes.
    Also, don't let the sarcasm here get you. There's a lot of (mostly) good natured joking around here that comes with a plethora of knowledge. Thick skin helps.
  24. buick bill
    buick bill
    from yreka;ca
    ten people can build the same car .should all be different , right ? I ask why people did what they did always . cause that's what THEY like . or after seeing they thought they liked !!
    Cosmo49 and Hombre like this.
  25. jimgoetz
    jimgoetz
  26. BJR
    BJR
    A drilled axle runs cooler.:D
    MO54Frank, clem, Jet96 and 9 others like this.
  27. There ya go. HRP
  28. ROADSTER1927
    ROADSTER1927
    My drill press and I like DRILLING! LOL Gary:cool::rolleyes: P1130002 (2).JPG 56.jpg
    Elcohaulic likes this.
  29. You see how "right" holes look on this one or that one when built with some attitude. 48270329-9494-489B-B344-30F47EC1BC74_zpsrv741tau.jpg 10993091_942633859080071_6606355771179638702_n.jpg 20190531_164537.jpg
    Blues4U, Jet96, akoutlaw and 2 others like this.
