Projects Who’s running 16” Steelies on their hotrod??
Discussion in 'Traditional Hot Rods' started by hotrod fozzie, Oct 13, 2019.
  1. 2NDCHANCE
    2NDCHANCE
    I'm running "Wheel Vintique's" 16" steel rims on my sedan. 16 x 5 on the front and 16 x 8 on the back. I know Summit sells them but you have to use their hubcaps. Stock Ford caps won't fit. They come with both Ford and Chevy bolt patterns on each rim. I have two 16 x 6 black powder coated rims I could sell but shipping would be expensive. Gary GM-2.jpg
  2. don colaps
    don colaps
    Love this car...
    Skickat från min iPhone med H.A.M.B.
    dwollam likes this.
  3. 5.50 front, 7.00 rear
    tinsled, exterminator and Stogy like this.
  4. TF 36.jpg 40 Ford 16" with 6.00 X16" Firestones
  5. krylon32
    krylon32
    from Nebraska
    1. Central Nebraska H.A.M.B.
    Not originals but Wheel Smith 16's on my deuce highboy pu. 5 inch with 500/16 Excelsior's front and 6 inch on the rear with 750/16 Excelsior's. I did have them fit the hubcaps to the rims. I'd have used original Ford wheels if I could have found some nice ones the right widths.
  6. Mart
    Mart
    I run 'em on Old Rusty. My 41pu has 'em as stock.
  7. Shutter Speed
    Shutter Speed
    Ran Coker 16's and caps after the stock A wires proved too whacked to track. Also adapters to mate to stock drums. Running 600's all around (go ahead, laugh), cause I like to rotate em, and like the way things sit with just a reversed eye in front.
    Thanks to @ark_rat on the H.A.M.B., finally scored a fine set of '35 wires, coated em black, swapped the tires, lost the spacer/adapters, NOW I'm happy.
    Oops, just checked. OP asked about ORIGINAL Steel 16's, and on the "Traditional" forum. Title only said 16" Steelies tho. Gimme the boot if you gotta.
    tinsled, Stogy, hfh and 1 other person like this.
  8. Deuce Bigalow
    Deuce Bigalow
  9. Cliff Ramsdell
    Cliff Ramsdell
    They are Firestone’s made by coker tires.
    Cliff Ramsdell
    Deuce Bigalow likes this.
  10. Dago 88
    Dago 88
  11. clem
    clem
    When the 15” rims became harder to find down here, people began using 16”.
    I would recommend your rims on the back with narrower 1940 - 16” x 4” on the front.
    If you were thinking of going to smaller 15” rims on the front, you may find it difficult to find a rim narrower than the ‘47 ford on the rear.
  12. daleeric
    daleeric
    from Omak
    I went with 16" x 4.5, with 5.50 x 16 front and 7.50 x 16 rear 20180804_103753.jpg
    bymanr, rob-redm, Stogy and 2 others like this.
  13. clem
    clem
    Loved the chrome wheels, and perfect choice of rim widths.
    Stogy likes this.
  14. I did not know that, thanks for the tip.
    Stogy likes this.
    16X4 up front with 600X16 and 16X4.5 on the rear with 750X16
  16. hardtimesainit
    hardtimesainit
    What, if anything, does this tire size difference do to caster/camber setting ? Need to be reset ??
  17. TERPU
    TERPU
    Homework:
    Google "Traditional Hot Rod"
    Post the first six pictures that come up.
    Report back to us.
    - Tim
    46international and Stogy like this.
  18. Stogy
    Stogy
    in the order of... and I added 7th, 8th...and 9th
    Now this is only an order not a contest of Best in Show...;)
    I think Steelies were addressed in a very Hamb way it appears in that search...just awesome...
    7 & 8
    Credit to Photographer's, Owner's
  19. Bursonaw
    Bursonaw
    Sent from my iPad using Tapatalk
  20. TERPU
    TERPU
    I salute you Sir, My point exactly. I saw the Chrome reverse as well when I did the search. But that is the order.
    Stogy likes this.
  21. jimgoetz
    jimgoetz
    My 27 as it was in 1953 with 16s and as it is now with 15s. I think tire size makes more of a difference in looks than wheel size. But 16s would be more traditional if that is important to you.
    1930 turbo, exterminator and Stogy like this.
  22. jim32
    jim32
    1. Hamb & Eggs
  23. bymanr
    bymanr
    My avatar has 40 16's upfront and GM in back.
  24. 1940 16" with WWW and caps
    Sorry, not a roadster...just hold your finger over the top of the picture... lol
  25. aerocolor
    aerocolor
    from dayton
  26. aerocolor
    aerocolor
    from dayton
  27. Reverse popularity is taking place on the HAMB. In the 50's in So Cal, the first thing you did was ditch wide 5's and any other 16 rims in favor of 15". The 16 thing is a nowaday HAMB thing, not OG, it's ok but not the way it was.
    pprather, F&J, jimgoetz and 1 other person like this.
  28. jimgoetz
    jimgoetz
    Right on. By the early 60s many rods were running 15s. At least where I was from in Cleveland area.
    John Lee Williamson likes this.
  29. OLSKOOL57
    OLSKOOL57
    50DropTop likes this.
  30. 4speed411
    4speed411
