Projects '33 5w Build Thread
Discussion in 'The Hokey Ass Message Board' started by CTaulbert, Oct 27, 2018.
  1. JimmyD3234
    JimmyD3234
    from PA
    looking good :cool: :cool:
  2. flamingokid
    flamingokid
    For a non-metal guy, you sure are knocking it out of the park.
    loudbang and kidcampbell71 like this.
  3. Mike Colemire
    Mike Colemire
    That chop is real sweet, looks like it's running a 100 mph just sitting there.
    Woogeroo, loudbang and kidcampbell71 like this.
  4. grandet23
    grandet23
    Any updates I've been sitting at my computer for weeks.....
    brEad likes this.
  5. alchemy
    alchemy
    He's a little busy today winning the AMBR award with his old black roadster.
    brEad likes this.
  6. Pgaines
    Pgaines
  7. Tim
    Tim
    from KCMO
    Yeah... but he was in the running at that point and a lot of guys liked it. I think it was more a point of saying his cars at the AMBR at the moment, and as such has his hands full.
    That being said, If I were him I’d probably be busy getting my two running driving hot rods ready for the season and probably a trip to Texas and not doing anything worth mentioning on the project.
    I’m sure he’ll post when he’s got something to post
    brEad, ash, CTaulbert and 1 other person like this.
  8. alchemy
    alchemy
    He got my vote.
    CTaulbert, dirty old man and Tim like this.
  9. CTaulbert
    CTaulbert
    from Detroit
    I think the HAMB community is patiently awaiting your 2020 AMBR contender submission.
    HEMI32, brEad, Tim and 1 other person like this.
  10. CTaulbert
    CTaulbert
    from Detroit
    Until this past weekend, I hadn't touched the car since December. I got tied up with shortening a C10 longbed into a shortbed, designing a blower intake manifold for a friend, and getting the roadster to and from GNRS.
    I have a couple of house project to tackle in the next couple of weeks, then I'm back on finishing the chop.
    Stogy, 1lucky1, brEad and 5 others like this.
  11. CTaulbert
    CTaulbert
    from Detroit
    Haven't updated this thread for a while.....
    Between some other projects, I chipped away at the car in the background. I had to address the rear corner of the quarter windows, which were now peaked from the path of the chop. I wanted to finish it in a larger radius, to complement the other two radii of that window.
    I've never used a Pullmax before, but have access to one, and figured it would be the best route to making the new corner. I made a paper pattern of the window opening that I wanted to achieve first. With that known, I knew the radius that I needed to achieve for the new corner, and transferred that to a wood hammerform that I made. This allowed me to turn the window opening flanged after stretching the material:
    brEad, Shadow Creek, loudbang and 3 others like this.
  12. CTaulbert
    CTaulbert
    from Detroit
    I made some dies to form the detail of the window opening using some 1/2" steel. With that done, and several window corner blanks, I went to Dan's to try them on the Pullmax. It took a couple of trips, and probably a half dozen blanks, before I got a pair down that I was happy with:
    57541800_10100162580449809_1501793026521956352_o.jpg 58377250_10100162580529649_4133660655213346816_o.jpg file.jpeg
    RatPwrd, Fitnessguy, brEad and 14 others like this.
  13. CTaulbert
    CTaulbert
    from Detroit
    I didn't take photos, but I broke a return flange for the inner flange that faces the actual glass. I then stretched it to match the radius of the window opening, and joined all of the pieces together on the car:
  14. CTaulbert
    CTaulbert
    from Detroit
    With the quarter windows wrapped up, the exterior of the chop was pretty much complete. I then moved onto chopping down the interior wood to fit back into the car. With that done, I would refit the upper door opening tins too. The car came with a new rear window wood kit, so I got that cut down as well:
    With the wood cut down and temporarily installed (it will come back out to get sealed), I could move onto the garnishes. My goal is to chrome the garnishes, so the job ahead was a little intimidating. I started with what I figured was the easiest, the rear window:
    ct1932ford, brEad, Stogy and 13 others like this.
  15. CTaulbert
    CTaulbert
    from Detroit
    I assumed the door garnishes were going to be the most difficult, so I moved to the quarters next. They were pretty straight forward considering the change in the rear corner radius:
    The door garnishes turned out to be easier than I had expected, only requiring a few relief cuts to get the upper portions to match the new a-pillar angle:
    Just Gary, brEad, Stogy and 12 others like this.
  16. CTaulbert
    CTaulbert
    from Detroit
    Once the door garnishes were welded up, I went back a made new corner webs for the front lower corners to replace the original pieces that no longer had the correct radius. While I was doing that, I decided to make corner webs for the rear corners too. While they weren't there originally, I think they make the garnishes look a little more complete.
  17. catdad49
    catdad49
  18. Hot Rods Ta Hell
    Hot Rods Ta Hell
    Chop looks perfect! Workmanship is impeccable! Love it.
    That's a masterful job on the quarter window corners. (I warned you they're a Bear to dial in!)
  19. So happy, that guys like you ... still post here, Corey. You have no idea, how appreciated it is. Its bitch'n'. Thanks a bunch.
    a boner, brEad, Tim_with_a_T and 3 others like this.
  20. 1-SHOT
    1-SHOT
    from Denton
    Really like your build. Those metal working skills come from trilal and error that you pointed out when using the pulmax. Thanks for shareing that. Frank
  21. x77matt
    x77matt
    Really nice metal work Cory! Metal finished!
  22. Happydaze
    Happydaze
    Wonderful stuff :)
    Chris
  23. loudbang
    ANOTHER masterpiece in the making. :)
    Stogy likes this.
  24. mgtstumpy
    mgtstumpy
    What can I say, wow. Outstanding is an understatement. That profile is awesome! Screenshot_20191014-222342.jpeg
    Sent from my SM-T355Y using The H.A.M.B. mobile app
    RustyBullet, Smiffy, Stogy and 4 others like this.
  25. alfin32
    alfin32
    from Essex, Ma.
    Schweet!!!
  26. DOCTOR SATAN
    DOCTOR SATAN
    from okc
  27. 1-SHOT
    1-SHOT
    from Denton
    I really like the way the windshield posts are done. They don't have that look of a dog's hind leg. I would be proud to call it mine. Thanks for shareing. Frank
  28. flatheadpete
    flatheadpete
    from Burton, MI
    Looks great! When you guys get together (You and Dan) the results are always awesome!
  29. CTaulbert
    CTaulbert
    from Detroit
    After fitting the doors better (before the chop), the dovetails were in a bind. While I could've cut the stock stamped sheet metal dovetails apart and moved them, I decided to make new ones.
    I modeled a two piece design in CAD, and got them machined out of 304 stainless. I made the dovetail pivot on the base (for setup only) to ensure I had the wedge properly aligned. Once the angle was set, I welded, sanded, and polished the finished pieces:
    Jet96, Rich B., HEMI32 and 8 others like this.
