Technical Flathead generator mount
Discussion in 'Traditional Hot Rods' started by Boden, Oct 10, 2019.
  1. Boden
    Boden
    I have a 8ba with a early style weiand 2 deuce intake that doesn’t have the boss cast into the intake to mount the generator to. What can I use. I heard the head mount bracket hits the distributor. And when used on the drivers side the generator bracket is horizontal ( stupid looking ). What can I do. Pictures please!!!!!
  2. Boden
    Boden
  3. alchemy
    alchemy
    Bigger worry: what are you doing for venting that engine?
    Boden and flatford39 like this.
  4. If it was mine I'd be looking for an 8BA intake.
    flatford39 likes this.
  5. flatford39
    flatford39
    That's not an 8BA intake. Like Alchemy says how you going to vent it??? You need to find an intake for an 8BA.
    Boden likes this.
  6. Boden
    Boden
    I am going to use a 32-48 oil filler
  7. Boden
    Boden
    Many people use older intakes on 8ba’s. The older oil filler/ vent was the vent. What did the older 32-48 engine do. They didn’t have a vent besides the oil filler
  8. Boden
    Boden
    We are getting off topic. This is the intake I have and I’m not spending money on another intake. What generator mount can I use?
  9. Atwater Mike
    Atwater Mike
    Get the close-together dual intake from Speedway, for the 8BA. $200+, half price of the name brands...Generator mounts in front center, misses the front carb. Also nice valley bore (for road draft tube, use with a PCV valve, no crankcase vapors all over the intake)
    EDIT! Oops! Posted before reading "I'm not spending money on another manifold!"
    1. Sell this manifold, buy the Speedway
    2. Use this manifold, But: Forget the generator, run a magneto.
    3. Driveshaft bracket the generator, run off the (open) drive.
  10. Petejoe
    Petejoe
    from Zoar, Ohio
    Bad idea depending on a filter to vent your engine.
    I’d imagine most will stop adding help until you address this issue.
    You can still use a 59a intake but yours will not work unless you put the generator on the drivers side.
    Sell it and buy a replacement with the generator mount attached.
    I’m sure some guys would love to trade intakes even up.
  11. alchemy
    alchemy
    Wrong. They had the vent on the front corner of the pan.
  12. Petejoe
    Petejoe
    from Zoar, Ohio
    I’d advise you to take a look at how the two block designs are different in vent flow.
    That may help you understand the requirements we suggest.
    http://www.reds-headers.com/html/red_s_engine_talk_19.html
    https://www.earlyfordv8.org/forum/viewmessages.cfm?forum=18&topic=11319
  13. 19Fordy
    19Fordy
    Boden likes this.
  14. solidaxle
    solidaxle
    from Upstate,NY
    Mount it on the left side, if you have room. You need spacers made, longer head bolts and change the water outlet. Your still spending money and have no venting. 0914160726.jpg
    oliver westlund and Bandit Billy like this.
  15. Flathead Dave
    Flathead Dave
    from So. Cal.
    You might want to listen to what is being said about your intake. It is not the correct intake for an 8BA motor and it will not vent your motor.
    Because you have an intake that you want to use does not make it the correct one to use.
    But if you are insistent on using what you have, fabricate a generator mount and let us know when your motor fails so we can say "TOLD YOU SO!"
    56shoebox, alanp561 and Boden like this.
  16. Flathead Dave
    Flathead Dave
    from So. Cal.
    I have the proper intake for Boden if he wants to pay the shipping. About $70 to ship. They are heavy.
    Petejoe likes this.
  17. Boden
    Boden
    What intake is it?
  18. Flathead Dave
    Flathead Dave
    from So. Cal.
    It's the proper OE single carb for 1949- 1951 8BA intake. In what city and state do you reside?
    oliver westlund likes this.
  19. Boden
    Boden
    I would need a 2 or 3 deuce intake
  20. Boden
    Boden
    The one I have that is for the earlier engine is a 2 deuce weiand intake. I already have the original 8ba intake
  21. Flathead Dave
    Flathead Dave
    from So. Cal.
    You didn't say that you had the original intake. GEESH WHIZ! Looks like you're going to have to spend the money for an aftermarket double intake. $200-$400, depending on where you get it.
    Another route is to use your OE single intake and get a double intake for the top..."SLINGSHOT RISER". They do not cost much and my friends run it with no problems.
    Boden likes this.
  22. Boden
    Boden
    Ya. Im familiar with them
  23. Flathead Dave
    Flathead Dave
    from So. Cal.
    There is another riser that my friends use. I can't think of the name right now. It rises from the intake and holds two carbs. Does not cost much at all. I think around $75.
    This is kind of what I'm talking about. This one is about $170 at Summit.
  24. Boden
    Boden
    Yea. I’ve seen that. The only problem is the linkage. The carbs sit next to eachother.
  25. Flathead Dave
    Flathead Dave
    from So. Cal.
    They have linkage for it and my buddy's fabbed their linkage. My brother used a banjo fitting on his with a straight line rod.
  26. tubman
    tubman
    A little "eBay magic" is called for here. Early manifolds are harder to find than 8BA models. List yours, sell it for a good amount, and then go searching for a correct 8BA manifold. If you are careful and spend a little time, you will come out way ahead. Trying to use that early manifold will probably sour you on the whole project.
    You can thank me later.
    oliver westlund, Boden and alanp561 like this.
  27. Boden
    Boden
    The only problem is. Is that my grandparents lent me the money for it as a birthday present. And I feel bad selling it right away
  28. Petejoe
    Petejoe
    from Zoar, Ohio
    We all make mistakes. Just sell and find a good one. Explain later
  29. s55mercury66
    s55mercury66
    from SW Wyoming
    Or explain the issue and and ask them if it would be ok with them to do some dealing to get what you need.
  30. Boden, just add a PCV valve to the intake you have. That will take care of the venting situation if you use the early fuel pump stand as the intake for venting.
