Projects 53 Ford Sunliner 351W install
Discussion in 'The Hokey Ass Message Board' started by Shanemade, Jun 10, 2019.
  1. Shanemade
    Shanemade
    Hello,I've been working on getting my motor in this 53'. My set up is a t5 trans out of a 2000 Mustang, a 351W out of a Crown Vic. I have bolted the two together for setting everything up. I bought the motor mounts and trans mount from Butches cool stuff. The set up works really well. I bought a new oil pan from a 250 econoline. Well I have the motor in and its sitting just how I want it. I've got four degree rake on the motor and rear end so they are parallel. I bought a set of 88400 headman header as suggested with other posts I've read on the web. I know they will work with a 302 but there is no way they are going to work with my setup, deck height being taller and overall width being wider. Passanger side is good drivers side hits the steering box. Has any one done this set up? Any suggestions on headers or manifolds?
  2. Casey Riley
    Casey Riley
    from Minnesota
    Very traditional. Jk. Looks good. I have no experience to add.
  3. s55mercury66
    s55mercury66
    from SW Wyoming
    Could you raise the motor up a little?
  4. Last edited: Jun 10, 2019
  5. Shanemade
    Shanemade
    Thanks Steve,
    I ended up ordering some similar ones from Summit Racing. Hope these will work.
    https://www.summitracing.com/int/parts/sum-g9063
  6. Shanemade
    Shanemade
    Casey there isn't much traditional about this car in the sense of it ever being stock. It was quite customized in the early 60's and ran a 283 chev engine back then. I am however keeping it all ford on this rebuild.
    Shane
    sidevalve8ba likes this.
  7. Casey Riley
    Casey Riley
    from Minnesota
    I wasn't being a jack wagon, there's a few guys that get pretty crazy about traditional around here.
    bobss396 likes this.
  8. Shanemade
    Shanemade
    Casey, No worries. Glad you took the time to read the post. Probably be some hairs on end when I roll it out of the shop with Mustang rims on it though! LOL
  9. Atwater Mike
    Atwater Mike
    Same DeSoto grille I had in my light blue '53 Vic. I tried a 302 in mine, but my shop had me too busy to find a rear sump pan!
    Ended up trading the car off, only 72K on the odo. No rust ever, no window leaks, nice car...I lowered it severely.
  10. Casey Riley
    Casey Riley
    from Minnesota
    That won't go over very well...
  11. Crayons
    Crayons
    Not quiet the same (351W/AOD in 54 Merc ) I couldn't find an exhaust manifold for the drivers side. Called Summit and the tech guy suggested the headers for a Maverick (I think) with a 351W....got them the next day and they fit perfectly. I know the frames are different, but it might work.
    JeffB2 likes this.
  12. ss34coupe
    ss34coupe
    Looking good, Shane! You are making great progress.
  13. Shanemade
    Shanemade
    Mike here is the original grill. I am however going to drive the hell out of this with the DeSoto grill for the time being.
  14. Shanemade
    Shanemade
    Steve it is coming along!
  15. Shanemade
    Shanemade
    So I have done a bit of work. Notch is all welded in and painted, oil filter works, cut out the tunnel/shifter to fit the trans( have a bit more work there). The new headers came in today so installed the starter and mocked up the headers. I am quite happy so far...I think its doable. Also I did the rear disc brake conversion a couple weeks ago, that worked out well until I tried to put on the 14" rims that came with the car (it doesn't work). So yes those are Mustang rims! They work and came off the donar = free! I'm liking the stance of the car.
  16. JeffB2
    JeffB2
    from Phoenix,AZ
  17. Shanemade
    Shanemade
    For some reason it wont let me view the page. I used Summit Racing Block Huggers Part # SUM-G9063. I don't think these would work with a 302 set up though. They would hit the starter and the motor mounts I believe.
  18. ss34coupe
    ss34coupe
    Talked to Shane last night and he is making real progress on his Dad's old custom. Look forward to seeing it on the road soon.
  19. Shanemade
    Shanemade
    Looking for a picture or two of the front sway bar installed on a 53 ford Sunliner/Crestline I may have the parts not sure though also has anyone done the 66 mustang fuel tank install would appreciate some input or a couple pics of the install. Done a bunch more work on my 53', drive shaft installed, brake lines and power brakes done, stripped down the steering column from auto to manual, the front brakes on and went over the rest of the steering. Been tough with the family camping and getting the Jeep fixed up for hunting season.
  20. Casey Riley
    Casey Riley
    from Minnesota
    Lookin good. I wanna put a T5 in my 51 Mercury to replace the Merc-o-matic.
  21. ss34coupe
    ss34coupe
    Good work, Shane! We are coming up your way soon to check out the progress.
  22. ss34coupe
    ss34coupe
    Went to visit Shane recently and have a look at the convertible. He is making great progress, and doing a some good work on this project. It will be up and running soon, for the first time since the early 70's!
    warbird1 and loudbang like this.
  23. Shanemade
    Shanemade
    Steve was good seeing you again. Thanks for stopping by! I have done some more work on this project... I built and installed the trans tunnel (that's a first for me!!) Installed a new fuel tank and the new pedals are in, front seats are mocked up and in. Been loving it!! Waiting for my motor parts hope they show up this weekend. I cant wait till this thing moves under it own power!! IMG_20190829_164849.jpg IMG_20190829_182924.jpg IMG_20190901_111939.jpg IMG_20190902_105418.jpg IMG_20190902_105507.jpg IMG_20190922_110902.jpg IMG_20190929_120831.jpg IMG_20190929_164533.jpg IMG_20191003_170810.jpg IMG_20191006_141302.jpg
    JeffB2, mcsfabrication and loudbang like this.
  24. Shanemade
    Shanemade
    Well this was on my door when I got home yesterday!! Time to pull it apart!
  25. ss34coupe
    ss34coupe
    Shane - great work on the trans tunnel and gas tank install! The convertible is coming along nicely, look forward to seeing it on the road.
  26. Shanemade
    Shanemade
    Been working away on this for most of the winter. Emergency brake is all set up and floor was gravel guarded and painted. Its coming along. On to the inner fender wells. The fire wall was pretty rough filled in all the holes I wasn't going to use and smoothed it the best I could. I'm no body man but it came out alright.
    IMG_20191012_195000-1.jpg IMG_20191025_190515-1.jpg IMG_20191025_190758-1.jpg IMG_20191025_190822_1-1.jpg IMG_20191230_142858-1.jpg IMG_20191231_155416-1.jpg IMG_20200229_153217-1.jpg IMG_20200304_185104-1.jpg IMG_20200305_192234-1.jpg IMG_20200305_192239-1.jpg IMG_20200305_224922-1.jpg IMG_20200307_125312-1.jpg IMG_20200307_125326-1.jpg IMG_20200307_130130-1.jpg
    JeffB2, ss34coupe and loudbang like this.
  27. Shanemade
    Shanemade
    A little work on the motor! and a re-paint. Wasn't happy with first go round. Sh$t happens!!
  28. For someone not good at body work you did real good on that firewall. Continue to take your time and ask questions, get guidance and you will have a beautiful car.
    Shanemade and loudbang like this.
  29. loudbang
    Engine looks great. :)
    Shanemade likes this.
  30. southcross2631
    southcross2631
    I am glad your headers fit. I have used the weld up header kit from Speedway several times to put small block fords in different things . Have even made them into fenderwell headers with a few extra bends.
    Nice work on the car. I have a soft spot for 53-54 Ford's .
    You might want to rethink that shift knob after you park it outside in the summer sun. Or wear a glove. Those sockets will get real hot real quick.
    JeffB2, Shanemade and loudbang like this.
