Projects "Pea Green" the '29 Tudor build
Discussion in 'The Hokey Ass Message Board' started by '52 F-3, Sep 14, 2014.
  1. NashRodMan
    NashRodMan
    Question....so I see the mounting holes at the top. Will the dash rail bolt in on top of this or are you not using the dash rail?
    '52 F-3 and loudbang like this.
  2. Great work on the dash.
    How about some more pics of Rex?
    loudbang and '52 F-3 like this.
  3. '52 F-3
    '52 F-3
    Back on post #523 there is a picture with my idea. I do plan to use the stock dash rail and either cover in brown leather or paint brown and bolt over the wood.
  4. '52 F-3
    '52 F-3
    working on steering column mount. Test fits pretty good, time to round corners and polish....
  5. Fabber McGee
    Fabber McGee
    Now just hold on a second... don't go hurrying past the paisley holes and the dog bone edges. Just because it doesn't show much, doesn't mean we're not watching.
    Doctorterry, brEad, JOYFLEA and 2 others like this.
  6. '52 F-3
    '52 F-3
    Very funny and spot on; No BS, I'd already sketched and taken a picture of this but didn't post it....
    Doctorterry, brEad, Stogy and 3 others like this.
  7. '52 F-3
    '52 F-3
    Just need to drill/tap mounting holes, and figure out a mount that isn't rigid. Thinking about rubber bushing/spacers so there is no metal to metal contact somehow.
  8. Column drop looks great!
  9. 340HilbornDuster
    340HilbornDuster
    Hi Gregg
    You don't disappoint Man- Paisley Beauty!!
    What kind of tool(s) do you use for shaping?...Amazing job!
    Doctorterry likes this.
  10. Fabber McGee
    Fabber McGee
    That's better, thank you.
  11. Fabber McGee
    Fabber McGee
    Perhaps you can mount the bracket solid and cut a big O ring groove inside the bore, may be 3/8 inch or so. Just a thought.
    Doctorterry, loudbang and '52 F-3 like this.
  12. 55Deso
    55Deso
    from Wyoming
    Awesome build! Just read it from start to finish, love all the little details!
  13. 340HilbornDuster
    340HilbornDuster
    brEad, loudbang and Stogy like this.
  14. NashRodMan
    NashRodMan
    ^^^^ ditto! Your stuff is inspirational and I learn a lot of neat ideas from it. Thanks for taking the time to post this "journey" of your project!
  15. '52 F-3
    '52 F-3
    All good in Pea Greenville, just busy with house stuff.
    Pretty sure I'm taking a new job that requires a temp. (or) permanent move and preparing, cleaning etc...
    Plan to take '52 F-3 towing homemade trailer with '29 Tudor to a small show local August 15th. Will post a picture...
    Stogy, brEad, Tim_with_a_T and 2 others like this.
  16. CURSED GEARS
    CURSED GEARS
    I haven't been getting notifications. You have done a lot. Love your home built pieces. I hope its a quick move for you. (can't imagine having to pack up my garage.)
    brEad and loudbang like this.
  17. Fabber McGee
    Fabber McGee
    Notifications on this site don't work very well. I usually only get a couple notifications a day on the two dozen or more threads I'm watching. I go to the first drop down list at the top of the page and click on watched threads to see what they're not sending me notices about.
    Pea Green is such a cool car I hate to miss any updates.
    '52 F-3 likes this.
  18. '52 F-3
    '52 F-3
    No progress, but I did get out of garage and trailered to a work show. Cleaned up some and hoping this gets me a little motivated. As normal, I'm splitting time between other projects.
  19. 340HilbornDuster
    340HilbornDuster
    Nice Equipage!
    Stogy and loudbang like this.
  20. 340HilbornDuster
    340HilbornDuster
  21. 340HilbornDuster
    340HilbornDuster
  22. 19Fordy
    19Fordy
    Don't vent holes in backing plates allow water and dust to enter?
    If so, it seems like a bad idea.
    '52 F-3 likes this.
  23. Tim
    Tim
    from KCMO
    Yeah but it’s a pretty common thing to do.
    You get rid of heat related brake fade but do end up with the possibility of some water related fade If you go threw some huge puddles.
    Haven’t ever seen anyone complain about it that’s actually done this in a car they drive.
  24. Stogy
    Stogy
    Taking in the Fall Color's in 'Pea Green' @'52 F-3? I know you had some hurdles to cross but I suspect that's all filed under old news now...Just curious...Hope all is well...;)
  25. Stogy
    Stogy
    In an unintended way it may help clear out unwanted dusts Hopefully not laden with Asbestos...Thats one area as Builders/Tinkerers we have to keep that in mind with brakes...NOS Vintage Brake linings may contain nasty shit.
    But it is as said totally period related detail...
    '52 F-3, loudbang and Tim like this.
  26. 340HilbornDuster
    340HilbornDuster
    Yeah...Gregg / Rex...How You Guys Doing?
    Hope Moving and Grooving worked out for Ya?
    '52 F-3, loudbang and Stogy like this.
  27. '52 F-3
    '52 F-3
    All good with me and Rex. Time sure goes by fast.... I've bought, repaired etc... & sold 2 non-HAMB cars. Put up a carport bla bla bla... and am building a reverse trike/cycle car thing with a HD engine right now.
    Thanks for replays, I really need to back back to Pea Green.... 20190929_085157.jpeg 20190919_180515.jpeg
    Sent from my SM-G960U1 using The H.A.M.B. mobile app
  28. Fabber McGee
    Fabber McGee
    Interesting project, I assume the engine will sit out in the open, no fairing or T radiator shell in front of it. How will you steer it?
  29. '52 F-3
    '52 F-3
    You're correct sir. Plan is leave engine wide open, only run a single headlight and/or maybe 2 fog lights....
    I've got 2 ideas for steering; I have a 71/72 pinto manual rack that seems to fit pretty well, or I mid 60's Econoline steering box mounted behind dash with a long for/aft draglink, and a an old steering wheel.
    I know not very HAMP friendly, but does have a 37/38 Willys front axle and wheel hub with quarter elliptical front leaf springs :)
    brEad, 340HilbornDuster and loudbang like this.
