Hot Rods No spark on motor
Discussion in 'The Hokey Ass Message Board' started by Bruce Fischer, Oct 8, 2019.
  1. I have no spark on a motor I am working on. I have new points, cond, new coil and new Ballast rest. and still no spark and no start.Any ideas?Thanks.
  2. Petejoe
    Petejoe
    from Zoar, Ohio
    Type of engine?
    Ran before parts change?
    Battery condition?
    Bruce Fischer likes this.
  3. F-ONE
    F-ONE
    from Alabama
    Time for the test light. Find out where the fire ends.
  4. BJR
    BJR
    First see if you have power to the coil. Or run a jumper from battery + to the coil and see if it starts. If it does you know to look backwards from coil. With the cap off does the rotor turn when cranking?
    Elcohaulic and Bruce Fischer like this.
  5. Truck64
    Truck64
    from Ioway
    Bruce, shirley you know by now all about the raft of defective el-cheapo condensers that plague our shores?
    sunbeam, 302GMC and Bruce Fischer like this.
  6. J. A. Miller
    J. A. Miller
    from Central NY
    Rotor sitting on your bench? I've done that before.
  7. 3W JOHN
    3W JOHN
    Don't call Bruce Shirley!
  8. Me too.
    Ben
  9. Flathead Dave
    Flathead Dave
    from So. Cal.
    I don't know Bruce Shirley but I see him on the HAMB.
    catdad49, Bruce Fischer and Truck64 like this.
  10. 51504bat
    51504bat
    What he says
  11. I heard that. HRP
    catdad49 and Bruce Fischer like this.
  12. BJRI have power to the coil, I tried jumper wire from the battery to the coil, and still nuttin.Yes the rotor turns.Thanks Bruce.
  13. Petejoe v-8 motor, it did run before changing parts but then quit.Brand new battery.Thanks Bruce.
  14. F-One have power to the coil and have power at the points with the key turned on.Thanks Bruce.
  15. Truck yes I know that, that's why I really didn't want to change it.I still have the old one.Thanks Bruce.
  16. greybeard360
    greybeard360
    V8..... That narrows it down a bit.
    Vague info requires vague answers.
    Your sparker is broke. Simple as that.
  17. J.A LOL.I made sure the rotor was on .Thanks Bruce.
    Truck64 likes this.
  18. 3wJohn, call me anything you want just help get it running.LOL.Bruce.
  19. Ahhh Danny, I am at that age I don't give a crap any more.JUST KIDDING.LOL.Bruce.
    Truck64 likes this.
  20. Ebbsspeed
    Ebbsspeed
    When you check for power at the points/distributor, that power should turn off and on when you crank over the engine, as the points switch the coil to ground. If that power does not go away intermittently when you crank the motor over, your points are not doing what they are supposed to. One cause of this can be a broken ground wire from the distributor body to the plate the points are mounted on. Of course misadjusted points or points with bad contacts would also be suspect if the power does not fluctuate.
  21. The power to the coil remains constant, it’s the negative side of the coil that breaks it’s circuit with the points opening. Hence breaker points :).
    Depending on where and how you attach the test light will determine the results
  22. treb11
    treb11
    is there power to the coil *when the ignition switch is cranking* ?
  23. Mimilan
    Mimilan
    At least Bruce and Shirley aren't complaining about "No Spark in their special relationship" [That can be costly]
    Try the old condenser , We had 2 faulty condensers in a row on my old Chevy. We ended up using a 2nd hand Chevy unit.
  24. Blues4U
    Blues4U
    from So Cal
    Yes
    Truckdoctor Andy likes this.
  25. BJR
    BJR
    Bruce have you checked for power when the engine is cranking? It goes through a different circuit when cranking than when running. Of coarse you said you jumped power from the battery to the coil and still got no spark. Try a different condenser.
  26. Up date on the 318 motor. A guy at work said try taking some fine sandpaper and rub it between the points. He said some of the new one are coated with a slight film to keep them from rusting while on the shelf. I did that and put them back in and cranked it over, DAMN there was a spark at the points now!. I put the cap back on and fired it up.It ran but sounds like the last guy didnt get the spark plug wires on right. I have to find a picture of the firing order for the dist cap for the wires and it should run better. Thanks to you all for your help. Bruce.
  27. BJR
    BJR
    Small Chrysler
    273, 318, 340, 360 A Engines
    Firing Order
    Cylinder Numbering
    Distributor Rotation
  28. sunbeam
    sunbeam
    I remembered the rotation being clock wise so I checked a motors manual and several web sites they all listed clockwise except the one JBR posted Big block Mopars are counter clockwise. On the years you have Number one was straight to the front but it could have been reinstalled anywhere.
