Termites and Bowties- Early Chevy Group
Discussion in 'The Hokey Ass Message Board' started by 29bowtie, Jan 7, 2009.
  1. GasserTodd
    GasserTodd
    Red one looks alright, could look great if it was dropped an inch, and with higher profile tyre out front.
    Black one sits nice but looks like the front end was cocked up and place 2 inches too far back.
    Both could be easily redeemed with 285/75/15 rear rubber and some chromies and 15 inch rubber up front
    Bowtie Coupe and Six Ball like this.
  2. nunattax
    nunattax
    from IRELAND
    id like the red one with some door handles and steel rims/hubcaps
  3. 66gmc
    66gmc
    Started test fitting the front sheetmetal on my 36 this weekend, I need to get the running boards mounted next so I can get all the gaps fine tuned to 1936 standards.
    Any suggestions on what rear end to use?. I want something with drum brakes and 6 bolt wheels. Ive been trying to find a 55-59 rearend but havent had much luck, I heard some of the Japanese minitrucks are the correct bolt pattern but I'm not sure which ones I should be looking for. Engine will be a mild 235 with a T-5 20190812_195412.jpeg 20190812_200124.jpeg
    wood remover, GuyW, 29bowtie and 11 others like this.
  4. I used a '94 Nissan 4x4 rear in a 38 chevy pickup. it fit like it was made for it and we used the original wheels. IMG_5911.JPG
    GuyW, 29bowtie, RoarsRods and 8 others like this.
  5. nunattax
    nunattax
    from IRELAND
    ted how are you holding the jerry can in place ?
  6. I Just bought a Chevy so a guess I’m into![​IMG]
    RoarsRods, TFoch, mgtstumpy and 6 others like this.
  7. 66gmc
    66gmc
    Cool truck! Thanks for the info, now I can expand my search.
    Bowtie Coupe and tb33anda3rd like this.
  8. there is a bracket bolted to the bed, which cradles the bottom of it and then has a wing nutted clamp that hooks and holds down the can. it is actually a tool box.
  9. RoarsRods
    RoarsRods
  10. RoarsRods
    RoarsRods
    Here are some of my updates on my 34 Chevy Roadster build!
    Trying so hard to get the match on the existing light blue paint so close but still not a match! Notice the front grille shell is the new light blue paint but still not happy that it matches the main body light blue color! Now seems like I will do the whole entire car over in the New Dark Blue paint that I did on all IMG_20190805_113702.jpg IMG_20190805_113754.jpg the fenders, running boards and all running lights!
    Oh also reshaped and pulled in the front bumper for a cleaner look!
    GuyW, 29bowtie, ct1932ford and 3 others like this.
  11. RoarsRods
    RoarsRods
    Here is my new 304 SST 2 1/2 inch x .062 thick wall exhaust all tacked up and IMG_1802.JPG IMG_1803.JPG IMG_1805.JPG IMG_1806.JPG tucked up in the frame!
    ct1932ford, TFoch, mgtstumpy and 6 others like this.
  12. flatmotor40
    flatmotor40
    from georgia
    Need a pic of the door hinges on the body side of a 35 Standard.Trying to get mine back on but forgot to marker frt or rear top or bottom Thanks.
  13. RoarsRods
    RoarsRods
    Change of plans! Not able to get a perfect paint match on the 40 year old Atlantic Light Blue paint! Taking the whole car apart and will be doing the complete 34 Chevy Holden Sports Roadster over with the Aussie Midnight Dark Blue paint same as all the fenders, running boards, taillights and headlights! Here is the ride height with wheels in place! Oh also doing a Cream Firewall with Medium Bronze Gloss on the Frame and ALL Parts under my car! Trying to get the 50’s look with IMG_20190815_110339.jpg IMG_20190815_110339.jpg IMG_20190815_110713 - Copyresize.jpg IMG_20190815_123357.jpg this build! Also Painting Gold on my engine and Gold Transmission!
    29bowtie, Fern 54, TFoch and 4 others like this.
  14. mgtstumpy
    mgtstumpy
  15. borntowrench
    borntowrench
    Hello all. I'm looking for a reference measurement of the front bumper mounting bolt centers on the front frame rails of a 1935 standard. I'm upgrading the front suspension, which the PO has already been into and I want to make sure the frame rails go back where they were. Thanks in advance.
    Bowtie Coupe and nunattax like this.
  16. mgtstumpy
    mgtstumpy
    34 & 35 Standards share the same measurements, just a different frame X-member
    biggeorge, Bowtie Coupe and nunattax like this.
  17. borntowrench
    borntowrench
    28 and 1/16 it is. Thank you Sir.
    biggeorge, Bowtie Coupe and mgtstumpy like this.
  18. well this is a new build and a bowtie. i have searched threads but have not seen any 29 or 30 chev touring builds. so i figured here is better than anywhere.
    i have from the cowl back a 30 touring. i have always liked tub cars. been gathering stuff to start the project. sat down and done a first draft of how i want it to look without moving fenders up. debating on moving fenders up. will sit down and draw that too. here is some picks. anyone with info,help on touring chevs.......
    thanks paul IMG_20190831_080249~2.jpg IMG_20190820_153945.jpg IMG_20190831_080249~2.jpg IMG_20190820_153945.jpg IMG_20190820_153852.jpg IMG_20190820_153643.jpg
    cactus1, RoarsRods, TFoch and 6 others like this.
  19. Six Ball
    Six Ball
    from Nevada
    Glad to see you are keeping the Chevy springs. Too many guys Fordicate the suspension which always says to me, "I wish I had a Ford but I had to make do with a Chevy." :(
  20. paul55
    paul55
    from michigan
    Some updated pics of my barn/garage find. Runs and drives great! Put a top metal top in it and sprayed with bedliner to mimick the canvas. Used the rear 1/2 of a 2009 Impala roof...it dropped right in, no shrinking the edges or anything. Perfect compound curves to fit 33-35 Chevy coupe and others, I'm sure. DSC04973.JPG DSC04974.JPG DSC04977.JPG DSC04979.JPG DSC04980.JPG DSC04981.JPG DSC04982.JPG DSC04983.JPG DSC04985.JPG DSC04990.JPG DSC04991.JPG DSC04991.JPG DSC05000.JPG DSC05002.JPG DSC04961.JPG DSC04963.JPG DSC05002.JPG
    Jet96, 29bowtie, tractorguy and 12 others like this.
  21. 66gmc
    66gmc
    Wow that's a beautiful car, I'm jealous!
    Fern 54, biggeorge and Bowtie Coupe like this.
  22. paul55
    paul55
    from michigan
    Thank you. Freed up the brakes and adjusted them, repaired the exhaust, rebuilt the fuel pump, new tires/tubes, some good used headlight lenses, adjusted the clutch, and reinstalled all the parts they had removed. Turned out to be a better car than I org. thought.
  23. jgrohio
    jgrohio
    from NE Ohio
    Been a while since I posted but making slow progress on my chassis
    RoarsRods, Fern 54, TFoch and 5 others like this.
  24. jgrohio
    jgrohio
    from NE Ohio
  25. jgrohio
    jgrohio
    from NE Ohio
    RoarsRods, 32SEDAN, nunattax and 2 others like this.
  26. AngleDrive
    AngleDrive
    from Florida
    Cool motor mount
    Bowtie Coupe and jgrohio like this.
  27. RoarsRods
    RoarsRods
    Making headway! Got the whole 34 Chevy Holden Sports Roadster apart! Plus got several re-chromed parts back, the frame all TIG welded and now heading off for medium bronze powder coating including all suspension parts!
    This body has very clean metal for 84 years old! The rest of the body and wood is really solid, with minimal dents. It's cool to see the old primers and how well they still grab onto the steel!
    The body is now in epoxy primer and starting bodywork on the firewall and cowl!
    Also here mounted are my Swan 4 inch SST Peep side mirrors!
    Oh I also tricked out my rumble seat lid and left the handle to open as a full trunk and custom made SST hinges IMG_20190927_145901.jpg IMG_20190927_132023_1.jpg IMG_20191001_071858.jpg IMG_20191001_071909.jpg IMG_20191001_071927.jpg IMG_20191001_071944.jpg IMG_20191001_141730.jpg IMG_1263.JPG on this Sports Roadster! Rory
    Fern 54, LOU WELLS, grumpy32 and 11 others like this.
  28. 66gmc
    66gmc
    Haven't made much progress on my 36. Had to reorganize the garage before winter so I threw the stock axles and junk springs under it to make it mobile. I was still in elementary school the last time this truck was rolling, and this is the first time in over 40 years the body has been bolted to a frame with doors that open and close properly. I did manage to get the box mounted last month, I was fortunate to get original boxsides in excellent condition, but will need to save up for a new tailgate as originals are impossible to find. 20191006_194656.jpeg 20191006_161608.jpeg 20190901_195443.jpeg
    Fern 54, wood remover, GuyW and 12 others like this.
  29. nunattax
    nunattax
    from IRELAND
  30. flatmotor, sent you a conversation (PM)
    lothiandon1940 likes this.
