Projects 1928 Model A Phaeton
Discussion in 'Traditional Hot Rods' started by Mikko_, Sep 15, 2019.
  1. Mikko_
    Mikko_
    from Sweden
    Been a long time reader on the HAMB and a while back I made a deal on a 1928 Model A Phaeton.
    It's not gonna be one of those shiny, better than new cars when done because it's in kind of a rough state to start with, haven't been on the road since 1939. :rolleyes:
    The frame has been sandblasted, painted and at the moment the car is in the sellers workshop where he is helping me put the body back together into something that can actually be called a body.
    The plan is pretty much:
    Stock A frame.
    1928 Phaeton body.
    Fenderless.
    Full hood
    28-29 radiator shell.
    18 inch wire wheels.
    Undropped front axle.
    Reversed eye spring in the front and a couple of leaves removed in the back.
    Model B 4-banger and trans.
    Mechanical brakes to start with and go hydraulics later on.
    Progress will probably be pretty slow but I'll post some pictures on how it looks today.
    Not much to show for yet than a pile of rusty parts.:D
    Baumi, kiwijeff, brEad and 10 others like this.
  2. You have all the good parts that's what counts.Love the look of a "TUB".You don't find many any more.Dont thnk they made a lot to start with.
    High test 63 likes this.
  3. Mikko_
    Mikko_
    from Sweden
    Good parts, and the seller is an experienced coachbuilder with a lot of knowledge about Model A's
    so I'm pretty convinced it will turn out ok in the end with his help :)
    kiwijeff, brEad, osage orange and 3 others like this.
  4. Mikko_
    Mikko_
    from Sweden
    Picked up the 18 inch wires I'm gonna use.
    They are nice and straight, just need some sandblasting and paint.
    New tires and tubes would probably be a good idea too :D
    35cab, High test 63, kiwijeff and 5 others like this.
  5. I believe 18"s were one year only,32. Im sure they are worth a bit of money.
    Stogy likes this.
  6. Mikko_
    Mikko_
    from Sweden
    I got them included with the car so I have no idea what they are worth.
    And yes, they are from 1932. I think 33-34 used 17 inch and 1935 16 inch.
    I like the look of a bigger rim better then the more commonly used 16 inchers.
    kiwijeff, Stogy and slv63 like this.
  7. The37Kid
    The37Kid
    Nice project, the door sills are a bit of a problem to install. Bob
    Stogy likes this.
  8. I find the '32 wire wheels to be worth about the same as the Model A wire wheels.
    Charlie Stephens
    Stogy likes this.
  9. banjorear
    banjorear
    Agreed. Many 18" wheels get swapped over to 16"
    Stogy likes this.
  10. Mikko_
    Mikko_
    from Sweden
    Thank you, I'm very excited about this since it's my first pre WW2 car.
    I'm not really into bodywork so I'll leave that part to the seller to figure out so I can focus
    on the mechanical stuff.
  11. alchemy
    alchemy
    Charlie, I've got a whole pile of A wheels I swap for your 18"ers.
    Stogy and 34 GAZ like this.
  12. Not in this neck of the woods o_O.
    jimmysweden and Stogy like this.
  13. Mikko_
    Mikko_
    from Sweden
    Took an old crooked light bar and made some headlight mounts for the frame.
    They didn't turn out like exact copies of each other but somehow the angle of the picture makes it look like
    they are way off from each other but they aren't, I promise :D
    The "bowls" are at the same height so I hope it will work out ok once mounted on the car.
    If not, I'll just heat and bend them some more :rolleyes:
    kiwijeff, Muttley, pitman and 5 others like this.
  14. Mikko_
    Mikko_
    from Sweden
    Got started on the front spring today, just needs some sandblasting and paint now.
    Hopefully it will turn out ok on the car.
  15. Kewl65
    Kewl65
    I like where this is heading, similar to my project - subscribed
    Stogy and Mikko_ like this.
  16. 340HilbornDuster
    340HilbornDuster
    Nice Find, Phaeton Brother...Subscribed!
  17. Mikko_
    Mikko_
    from Sweden
    Glad to hear you like it.
    Hopefully it will look more like a car soon, and less like a pile of parts.
    Stogy likes this.
  18. I have always liked the 28/29 Ford Phaetons and almost bought one about 20 years ago, unfortunately my knuckle dragging neanderthal frame made it impossible to squeeze in between the front seat and steering wheel.
    That said, they make great looking traditional hot rods, I'm looking forward to seeing the build. HRP
    kiwijeff, Stogy and Mikko_ like this.
  19. 340HilbornDuster
    340HilbornDuster
  20. Mikko_
    Mikko_
    from Sweden
    I'm only 5'9" and I fit fine in a stock 28-29 Model A.:)
    Stogy likes this.
  21. Mikko_
    Mikko_
    from Sweden
    Got the front spring done today.
    6 leafs total and reversed eye.
    kiwijeff, nunattax and Stogy like this.
  22. Mikko_
    Mikko_
    from Sweden
    Some progress made on the body today.
    Starting to look more like a car now. :)
    thumbnail_IMG_0889.jpg thumbnail_IMG_0886.jpg thumbnail_IMG_0890.jpg thumbnail_IMG_0892.jpg
    kiwijeff, brEad, ratrod40428 and 6 others like this.
  23. Mikko_
    Mikko_
    from Sweden
    Picked up my sandblasted wheels today, ready for some primer and paint.
    Something special about 87 year old metal that's so clean. :D
    2Blue2, Just Gary, alfin32 and 7 others like this.
  24. sloppy jalopies
    sloppy jalopies
    IMO... leave 1/2 the bent bar on each end... it will supply leverage when you bend them...
    your mounting plate's holes appear to be perpendicular to the frame …
    the lights will vibrate less if the bolt line is parallel to the frame...
    the 1/2 bars will make it a lot easier to heat the lower end of the shafts red hot and rotate the cups 90*… I ran a couple 3/8" bolts down through the h/l bar's holes and snugged them in the vice to help hold it while i bend it...
    since you have cut them flush maybe run a 3" - 1/2" nut and bolt tightened through the cup with the long end down, run another nut onto the end of the bolt, it will help keep the prybar on the bolt shaft... you can now slide a prybar between it and the shaft to twist the cup to being parallel …
    HIH.
    Atwater Mike, Stogy and Mikko_ like this.
  25. Mikko_
    Mikko_
    from Sweden
    I was thinking about mounting the lights the same they are on the car below.
    But I hear what you're saying and I will mock them up on my car and see if I need to twist them 90 degrees.
  26. sloppy jalopies
    sloppy jalopies
    I like them your way... cool
  27. Mikko_
    Mikko_
    from Sweden
    I sprayed some rust preventing primer on the wheels today.
    Soon time for the topcoat. :)
    Stogy, brEad, nunattax and 2 others like this.
  28. sodas38
    sodas38
    Looking good, nice project.
    Mikko_ likes this.
  29. Mikko_
    Mikko_
    from Sweden
    Thank you, very happy to have found an open top project at a reasonable price :)
    Stogy likes this.
  30. Mikko_
    Mikko_
    from Sweden
    First layer of topcoat on the wheels, a real hassle to get good coverage with all the spokes.
    Then I ran out of paint but it's getting there.
    Tomorrows plan is to get some more work done with the body and frame of the car. :)
    Stogy, Just Gary, brEad and 2 others like this.
