Technical Question for you suspension guys
Discussion in 'The Hokey Ass Message Board' started by BigO, Sep 30, 2019.
  1. I want to use regular old air shocks on the rear of my '47 Ford Coupe and add a compressor and tank , I just can't afford a bag set up. Will there be a problem with doing it this way? Thanks in advance, BigO.
    dana barlow likes this.
  2. squirrel
    you won't get much lift out of air shocks, compared to bags
    town sedan likes this.
  3. What are you trying to accomplish? Air shocks don't do much for lifting and lowering if that's your goal.
  4. 2OLD2FAST
    2OLD2FAST
    from illinois
    Air shocks are meant to be an addition to an existing suspension , not as the only means of supporting your car , if that's what you want to do ??
    BigO and rockable like this.
  5. Agreed, more info is needed.
  6. Mike VV
    Mike VV
    from SoCal
    What 2OLD2FAST said.
    Stick to real suspensions, both you and your car will be better off for it.
    Mike
    tractorguy and BigO like this.
  7. Jalopy Joker
    Jalopy Joker
    so, how is your car lowered now? so, expecting function of shocks to compare to bags? know that bag systems have shocks too?
  8. I ran air shocks and used one of the license plate holes to run the valve through, great instant access. How often are you going to be cycling it, if it is every time you park, you'll need a compressor of some type.
  9. Only looking to go up or down about 2 inches.
  10. Thanks for the comments , looks like bags is how to go, I'm more of a bodyman than a suspension man that's why I asked you guys. :)
  11. I used air shocks on the front of a A-100 Dodge van and they gave me 3" of lift, I was running 7" wide wheels at the time. HRP
    BigO likes this.
  12. one thing to keep in mind is that the upper and lower shock mount was never designed to take the weight of the car. if that is what is holding your car up, you are asking for a bent shock mount at the crossmember or a broken bolt at some point.
    pitman, irishsteve, BigO and 2 others like this.
  13. KenC
    KenC
    Yep, back in the day there were a lot of damaged trunk floors in tri-5 chevys!
    irishsteve, olscrounger and BigO like this.
  14. Looking to put them on the rear.
  15. thirtytwo
    thirtytwo
    I was thinking in the early 80s Lincoln’s, Cadillac, tornados, rivieras, all had a type of air shock with an air compressor .
    I’ve seen it done with air shocks on really light cars , while a shock wave shock is basically just a nice air shock , the old “hi-jackers” were meant to just assist and as mentioned above you would need a mount like a coil over shock , and make sure you have a bump stop Incase of air failure
    BigO likes this.
  16. 2OLD2FAST
    2OLD2FAST
    from illinois
    Pretty sure those were bags ....?
  17. dana barlow
    dana barlow
    from Miami Fla.
    1. Y-blocks
    Up 2in. will work fine,on car,as long as its not a loaded truck. Ran some for that on a wagon for years.
    BigO likes this.
  18. Will run in the down position most of the time (not bottomed out ,taildragger style) and only up to get in and out of parking lots.
    jimgoetz and dana barlow like this.
  19. As long as you have springs , I never encountered any problems with mine.
    I also used them on the back of a falcon sprint, to keep the tires from rubbing the outter fenders, remember when you used the widest tire you could find? HRP
    fordflambe, BigO and dana barlow like this.
  20. BJR
    BJR
    If all you are using it for is to get in and out of parking lots and driveways it should work fine. Just don't drive a lot with it in the raised position.
    Tim likes this.
  21. or borrow some cab air bags from a big truck and mount them to your leaf springs as helpers
  22. Yep, I run them on my '65 Fairlane in '76 and had no trouble .
  23. jimgoetz
    jimgoetz
    I'd think they would work fine for this.
    BigO likes this.
  24. It'll be in a low position most of the time and rarely go more than a 5 mile radius from my home.
    Tim likes this.
  25. Escalades and suburbans have factory air shocks you might be able to source at a wrecking yard or used online, just check the length to make sure they will work in your application.
    BigO likes this.
  26. Nova Thug
    Nova Thug
    from SG Vizzle
    I’m not sure how much you are going to save by using an air shock if you’re u are still going to have an on board air compressor and a possibly a tank. I thing you could pick up an auxiliary air bag load system for a pickup truck and install it leaving your current suspension setup as it is now. My brother inlaw had one of these on his late model pick up. The bag mounts to the axle and the frame rail..
    BigO likes this.
  27. Thanks, this is why I love you guys here on the HAMB.
  28. rusty rocket
    rusty rocket
    Oh BigO, your car is so kool get out and drive more than 5 miles from your house. Hell drive that sucker to the Black Hills of South Dakota and I'll tour you around!:):p
  29. Thanks for the invite.
  30. X-cpe
    X-cpe
    I've got an air shock off a 90's LeSabre in my show and tell stash at school. Car had an on board compressor and a ride height sensor. The rear shocks were used as automatic load levelers. We've got a mid 90's Continental with rear air spring suspension and a ride height sensor.
    BigO likes this.
