Customs Dragster build
Discussion in 'The Hokey Ass Message Board' started by v8 Bake, Sep 25, 2019.
  1. v8 Bake
    v8 Bake
    Some pics of the dragster I built last winter. Had a blast playing with it this summer. Hope to get it quicker next year.
    Countn'Carbs, RMR&C, Gammz and 14 others like this.
  2. Nice, and the youngster likes it too.
  3. loudbang
    Don't hold back on us what times was it running :)
    Deuces and lothiandon1940 like this.
  4. Jalopy Joker
    Jalopy Joker
    - x2
    loudbang, Deuces and lothiandon1940 like this.
  5. hrm2k
    hrm2k
    Sweet !!!!!!!
    Times Please
  6. Looks like some great fun.............and yes, times please.:D
    loudbang, hrm2k and Deuces like this.
  7. v8 Bake
    v8 Bake
    its slow. 7.35 1/8 is the best yet to date. Ran a 7.79 last week with no high gear. if part breakage was down I think 6.90s in the 1/8
    loudbang and lothiandon1940 like this.
  8. raven
    raven
    I like it. Did you design the chassis your self or did you use someone else’s design?
    I know there are some vintage designs available.
    r
  9. Jalopy Joker
    Jalopy Joker
    - if you figure this out a lot of race teams would like to know your secret
    loudbang, Hollywood-East and v8 Bake like this.
  10. partsdawg
    partsdawg
    from Minnesota
    Looks like your having fun.
  11. v8 Bake
    v8 Bake
    Yes. It’s the most fun I have had for years. I have had real race cars,hot rods and cruisers. This tops it all for fun. No plan was used. It’s all built from scratch looking at pictures from the late 50s. It’s similar to a chassis research of the era.
    swade41, catdad49, loudbang and 3 others like this.
  12. 41rodderz
    41rodderz
    from Oregon
  13. v8 Bake
    v8 Bake
    It’s a high compression 355 with a flat tappet cam Chinese aluminum heads with a sintered iron clutch and a Saginaw 3 speed. Leaving in second and slick shifted to 3rd. Sending parts to liberty gears to have it face plated Friday.
  14. Speed Gems
    Speed Gems
    I didn't think an open top like that would pass tech anymore. Looks like an old Scotty Fenn chassis.
  15. AHotRod
    AHotRod
    Fun is what it is all about !
    Very nice job on the dragster.
    v8 Bake, lothiandon1940 and loudbang like this.
  16. catdad49
    catdad49
    I think every car guy should experience this just once, but I guess you'll just have to do it for most of us! Go Fast, Have Fun, Be Safe.
    v8 Bake, loudbang and lothiandon1940 like this.
  17. v8 Bake
    v8 Bake
    It passes tech at our local track. running 1/8 mile helps too
    catdad49 and loudbang like this.
  18. v8 Bake
    v8 Bake
    my design. Just looked at pictures of old ones.
  19. fastcar1953
    fastcar1953
    Saw it at the rumble. I'm guessing that's where the pictures are from. looked like a lot of fun.
    v8 Bake and loudbang like this.
  20. Church Key
    Church Key
    Great looking car ! These old dragsters are the cheapest, most fun way to go drag racing.
    loudbang and v8 Bake like this.
  21. v8 Bake
    v8 Bake
    Yes. That is my local track. Only place its ran.
  22. Sure looks like fun
  23. rd martin
    rd martin
    from indiana
    very kool!
  24. Ah! Suddenly it's 1957 again.:)
  25. 56sedandelivery
    56sedandelivery
    First of all, what track is this at? Secondly, cool little car; 100" wheelbase? Scavenger/adjustable headers, and a Powerglide/4500 RPM stall converter, and it would MOVE!!! I think NHRA/IHRA should have a Bracket Class just for "older style" dragsters; all the safety equipment per current rules, plus some additional bracing in the drivers area, but still retain the old "look". Course, I'm just dreaming, and although MJ is legal here in Washington State, I'm NOT a user. Always liked this style dragster. Mine was a 120 inch wheelbase, Kent Fuller chassis, FED with a 3 point cage, 333 CID SBC, Powerglide/trans-brake/4500 stall converter, 57 Olds/Pont rear end with 4.10 gears; 9.23 @ 146 MPH with a stock 340 HP short block 327 .040 over using the 10.35:1 pistons, mild flat tappet cam, and the heads were heavily modified, old school, 461X castings. Still have the engine and fire-suit; the dragster's been gone since 1984 when it was rep-laced with a 210" wheelbase RED. I am Butch/56sedandelivery.
  26. v8 Bake
    v8 Bake
    It’s at thunder valley drag strip in Bethany mo. It’s 100 inch frame. I’m running a 3speed Manual running 2nd and 3rd with a sintered iron clutch. I think it will run once we get all the bugs out. Last month it blew the caps of the 9” ford. New strong center section and tore the teeth off high gear. Sent parts to libertys gears to have it faceplated.
