Another item from my buddy's cleanout and liquidation. This is a project car, been stalled for years but always stored inside. A 1957 Morris Minor Traveller which has the following: Full 2x4 tubing frame Art Morrison complete welded IFS subframe assembly, bought as a complete snout unit, disc brakes, R&P steering, swaybar (this was their kit for '33 Willys, almost perfect match for the Morris) Narrowed S-10 rear end by JP Chassisworks, large Ford ends on axle tubes with full size car disc brakes, aftermarket street axles Stewart Warner gauges Perrelli tires Painless wiring Rebuilt '62 Buick aluminum 215 mated to rebuilt TH350 with a Kennedy adaptor, four barrel carb, Rover aluminum valve covers, Crower 276HDP cam, headers Aluminum radiator with electric fans All new wood from Morris Wood Works in the UK, all installled Master Power master cylinder Needs finishing, gas line run, weatherstripping, paint, runs now on temp fuel system, body in primer, wood in marine sealant, glass all there, receipts for everything comes with it. I have build pictures of suspension and frame, trying to get the scanned so I can post. This is a great little car at a close out price. I can answer tech questions but offers and such need to go to the owner, call Peggy at 603-234-4690.
Please PM me on the HAMB or call me at 603-520-9931 for questions. Only call Peggy if you want to discuss money. She cannot answer tech questions. This is a 90% done project woody with new wood all installed. Runs and yard drives, needs gas line run, some body gaskets installed, interior finished, rain gutter needs installation. All the receipts are with car, all engine parts from D&D in Michigan, the aluminum 215 engine specialists. Oil pan increased capacity with rear sump and Buick GN oil pickup. The original Morris design was aluminum panels in the wood frames, now it has marine plywood inserts for more of a woodie look. Even comes with surfboard for the roof Has new chrome strips for grille. BTT.
Some construction pictures, some interest already, don't miss a chance to own a neat woodie for short money.
Where are you going to find a woodie with an aluminum V8 and all new wood for this price? And all the hard work already done, all reciepts for parts come with the car, no detective work necessary. Engine is rebuilt as is trans, rear narrowed. This is a 4WDB car. BTT
