Projects 1932 Jalopy Roadster Build
Discussion in 'Traditional Hot Rods' started by deluxester, Jul 20, 2019.
  1. deluxester
    deluxester
    Do you have any photos of your master cylinder set up? Does anyone have photos of a master cylinder mounted hi against the crossmember? Thanks!
  2. deluxester
    deluxester
    @Mart
    O.K,
    I think I understand. Something like this will make me much happier and I still maintain my leverage ratio high.
  3. Mart
    Mart
    This was my setup:
    In the interest of full disclosure I did this about 10 years ago and the car got torn down . I am hoping to get back working on it soon. I haven't driven it yet.
    oliver westlund, Jet96, Tim and 4 others like this.
  4. deluxester
    deluxester
    Much nicer. I think I will be making a new master cylinder bracket. Thank you for the photos. Also, where did you source that fitting and hose coming out of the rear reservoir?
  5. Mart's setup is definitely an improvement, but I would still be concerned with pedal ratio. This does depend on master cylinder bore, but an overall ratio of around 6:1 is normally desired. I have had better luck using a bellcrank arrangement to get the desired ratio.
    chryslerfan55 and deluxester like this.
  6. HellsHotRods
    HellsHotRods
    Congrats on making it on the pages with your A roadster ! Screen Shot 2019-09-22 at 7.51.01 PM.png
  7. alchemy
    alchemy
    My master cylinder bracket sets back a little like Mart's does, and the plunger is close to the bottom of the crossmember. I'm not sure what my pedal ratio is. I built an arm just like Mart that has a 180 degree around the pedal boss. That way there's no possibility for it to crack and break off.
  8. deluxester
    deluxester
    A friend helped me diagnose a misfire at cylinder six. Turned out to be a bad terminal plate in the Lincoln distributor. Fortunately, my local Lincoln supply and dismantling yard stocks NOS replacements! E91748F8-10B6-4410-93EF-73F756B1FB51.jpeg
  9. deluxester
    deluxester
    I received more welcomed help this past weekend.
  10. greaser, kidcampbell71 and deluxester like this.
  11. That’s a great pic! So fun when they want to be involved.
    deluxester likes this.
  12. deluxester
    deluxester
    I’m still playing with carburetors and timing, but it sounds great and stops excellent (and really smells like gasoline).
    WC145, Tim, Pinewood and 12 others like this.
  13. deluxester
    deluxester
    I have my mom to thank for assembling the make-shift driver’s tarp
    Vic Walter, WC145, Tim and 9 others like this.
  14. dumprat
    dumprat
    from b.c.
    Perfect! Getting the whole family involved.
    WC145 and deluxester like this.
  15. Cyclone Kevin
    Cyclone Kevin
    Alliance Vendor
    These two pix are treasures!!!!!! She’s now the official “CYCLONE Racing Spokes-kid”, in more than one way as you’re running some spokes!!!!
    Steve, tell your mom I need a tarp like that for mine as well......Great Pix!!!!!!!
  16. deluxester
    deluxester
    I like the stock plug wire looms. I did a quickie clean up on a set that was donated to me by @HellsHotRods
    Before: BF242D36-E35B-427B-9A94-F17BBC54B63C.jpeg
    After:
  17. dumprat
    dumprat
    from b.c.
    Those will make a nice addition!
  18. HellsHotRods
    HellsHotRods
    Thanks !!! Looks great !!! We supply all the best premium parts, one stop shopping for you buddy.
  19. Aaron D.
    Aaron D.
    Great job on the wire tube.
  20. deluxester
    deluxester
    Another detail scratched off the list.
    4C1530C8-1EC8-4B23-A27B-5573B2F5EF29.jpeg ED56C56D-4181-4C7C-BF24-DF40BFB75FD7.jpeg F5F07AA0-342F-4AF6-86FB-E1F4E3FB8976.jpeg
    Shadow Creek likes this.
  21. deluxester
    deluxester
    Used a n.o.s. Stewart Warner mechanical tach drive kit. I had to make a column mount bracket for the tach gauge.
    CD84151C-39ED-4157-9A80-6D36DB745105.jpeg D9AB89FC-A8F3-4A14-95E8-65B3344BF612.jpeg D5F44F93-F3C3-41DA-ABEE-004FA13E1543.jpeg
  22. deluxester
    deluxester
  23. Fortunateson
    Fortunateson
    Is that pooch your assistant? He/she looks like a Sheltie.
  24. deluxester
    deluxester
    That is Zoey. Australian shepard/border collie. I can’t grab a tool from my toolbox without having to step over her. Twice.
    1-SHOT likes this.
  25. 1-SHOT
    1-SHOT
    from Denton
    I have a dog with the same name Zoey she is a 11 year old white Schnauzer.
  26. deluxester
    deluxester
    Rear spreader bar
    58B703E2-BE8C-41E6-8829-13F43FA5409E.jpeg E93E9607-E57B-42EF-A81B-3642FB1F74A0.jpeg 5034F3AB-D80C-4BA3-B951-D2AA1653028A.jpeg
    WC145, oliver westlund, Tim and 3 others like this.
  27. deluxester
    deluxester
    Paint and hardware next... and remount the gas tank above the rails.
    WC145, oliver westlund, Stogy and 5 others like this.
  28. dumprat
    dumprat
    from b.c.
    Damn ! Ya coulda run a big old knobby spare tire on that bar like original.
    Just kidding! Looks great. I like what you are up to with this.
  29. deluxester
    deluxester
    Chopped up an old headlight bar to mount onto the frame with ‘32 headlamps. I’ll torch the base ends into shape tomorrow once I decide on a good location.
    9B557DEE-2A80-4CC2-BEDE-97B42D1DDEDB.jpeg 930236A8-1A5F-42D3-9088-FB1C95ED2655.jpeg
    WC145, oliver westlund, Tim and 6 others like this.
  30. deluxester
    deluxester
    Lightbar is almost there
    WC145, Tim, Nailhead A-V8 and 9 others like this.
