Technical 32 Ford 3 window trunk latch / handle install
Discussion in 'The Hokey Ass Message Board' started by greg37, Sep 21, 2019.
  1. greg37
    greg37
    from mi.
    Hey everyone, I have a 32 Ford 3 window. I want to install a trunk handle using a stock style handle , striker and latch. Can anyone here give me the measurements/ instructions or template to do it ? Also for the door handles, Templates or instructions? Thanks I really appreciate any help.
  2. deucendude
    deucendude
    from norcal
    Original body or plastic?
  3. clem
    clem
    If you’re asking, especially for the door handles, it must be a reproduction body.
    A template or other measurements probably won’t be of much help unless someone has the exact same body and door handles.
    My suggestion is lots of measuring and double checking.
    The boot latch should be centred when looking from the rear, - horizontally.
    Door handles centred on the belt line for most models except 3 windows. Just below. Need the ‘33/34 style handles which sit flush.
  4. greg37
    greg37
    from mi.
    Yes it's a glass Downs body
  5. deucendude
    deucendude
    from norcal
    I would check with Downs. I am sure they have done it by now. All of the glass bodies have different structure. I would start with a repo handle assembly and go from there.
  6. greg37
    greg37
    from mi.
    Downs is out of business !!
