any one know of a sbc fuel pump that has the inlet/outlets at 9 oclock and to carb at 3 oclock. trying not to go after market adjustable if I can help it. 3/8 fittings no return
most all of your stock pumps are gonna be pointing to the front of the car, some out of the side some from underneath the pump , why no aftermarket , and also like asked by DrJ, what are you considering 12:00, Fred
yes the arm being 12 the out to carb is most often at 3 oclock..I know not always. Why you ask. In canada where after market means 3 times as much. Thanks
From Speedway Motors, Part # 91602046, (new) fuel pump can be disassembled to index the inlet/outlet area. Plus the rated output PSI is 6. Edelbrock carbs need 6 PSI, while Holley carbs need 7 PSI. I have seen this fuel pump to work correctly with either of these 4 barrel carbs, thus without the need to install a fuel pressure regulator.
