These are original 1939 Lincoln front brakes. The Bendix part number stamped in the plates is #42624. I have totally rebuilt them: new springs, hardware, adjusters, WC links, and 1.75" shoes. The wheel cylinders are upgraded to 1.125" dia from the original 1" ones. New zinc plated bolts and star lock washers were used to bolt the wheel cylinders on. The original shallow drip tins are included. The backing plates were blasted and are quite pitted from sitting in the dirt for years. After blasting they were primed and painted. Gloss black on the interior and semigloss black on the exterior. The anchor pins have been freed up and antisiezed. These brakes have the small 3/8 holes for the early pre 36 spindles and are the correct deep offset that will allow their use on 28-35 Ford front ends. These don't come along very often. They're ready to bolt on and bleed. I have the original finned Lincoln drums in another auction. If you're interested in those as well message me. $500 plus shipping OBO Jeremy Ebbesen
