Ok. So here's a dumb one. So I have a 5/8 Heater hose nipple that I blocked off. Problem is I used those damn rubber caps and a hose clamp. While it looks alright, it doesn't last, starts to crack and leaks. And it doesn't seem to take verry long. Any better ideas? Something that's not big and clunky? Does any one offer a heavy duty one? Thanks fellas!
Find a brass plug with an Allen head in it. Might have to use a bushing if you can't find a plug big enough.
These are advertised as heater bypass caps, maybe they’re different/better than what you already tried?
I’ll never use the “ heater bypass caps” again. Had one blow up and caused me a roadside repair. I’ll take dumb and clunky if it works
One more of us who has had no luck with the rubber caps, so the clunky bolt-in-the-hose deal it is for me. I'm a relocated hillbilly anyway.
I looked for something like that but never found any. They should outlast the crappy rubber ones easily.
