Features Gear ratio rear end
Discussion in 'Traditional Hot Rods' started by 1933 pcxx, Sep 7, 2019.
  1. 1933 pcxx
    1933 pcxx
    I am trying to find out what gear ratio I need if I have 27” tires and at 70mph I would like my rpms to be about 2,000 or 2100
  2. 6sally6
    6sally6
    Over drive tranny????.........T-5??? Little mo info needed
    6sally6
  3. onetrickpony
    onetrickpony
    from Texas
  4. flatout51
    flatout51
    Boneyard51 likes this.
  5. AKGrouch
    AKGrouch
    tranny final drive ratio?
  6. fiftyv8
    fiftyv8
    from CO & WA
    Just roughly it sounds like you are going to be in the range of about 3.3 to 3.5:1 going by what my F100 with T700R4 does on 235/75/15 tires. I'm running 3.54:1 gears.
  7. i.rant
    i.rant
    1. 1940 Ford
    2100 RPM @ 70 MPH with 27” tire and w/o overdrive you would need a 2:41 gear.
  8. FWIW.
    I have a T5 with 0.86 OD, 27" rear tires and a 3.73 rear. 55mph is about 1750 rpm
    Chappy
  9. You could also look up the formula yourself.
    XXL__ likes this.
  10. 41rodderz
    41rodderz
    from Oregon
    Nope:D
