Projects Two tone paint 54 belair
Discussion in 'Traditional Customs' started by Seth_McK, Sep 4, 2019.
  1. Seth_McK
    Seth_McK
    Gents,
    I have a 54 belair that is currently Bermuda green with a excellent fade on the metallic. I have a tight budget right now and want to make the car two tone, green and white are everywhere... clean, but done.
    I like the idea of surf green on the roof and side spears, I also want more of that kustom look. I don’t want to make a miss step and add flake that ends up needless.
    I have poor photoshop skills but here is an attempt.
    One with B pillars and one without.
    Help greatly appreciated!
  2. 41rodderz
    41rodderz
    from Oregon
    Hello. Neat car. With the dark green pillar at first thought was a factory look but either works .
    Seth_McK likes this.
  3. 1953naegle
    1953naegle
    Love those colors! I'm using the same OEM bermuda and surf greens on my 54' 2100 too. I like the surf green b-pillar.
    Seth_McK and Hnstray like this.
  4. 53_Rusty
    53_Rusty
    from Menifee CA
  5. quick85
    quick85
    Match the pillars to the roof. It's a handsome car, please, no skirts.
    Here's a '54 I saw in Lafayette, Indiana:
    Seth_McK and 56premiere like this.
  6. low budget
    low budget
    from Central Ky
    I like the darker posts
    scotty t and Seth_McK like this.
  7. Seth_McK
    Seth_McK
    The dark green is metallic, do you think that adding a micro flake or larger to the surf green will be too much?
    I am collecting parts right now: 350 4 bolt main, 700r4, 69 Camaro 10 bolt rear end, Walton Fab is sending his manual brake firewall kit, mounts for v8 and trans, and kit for rear end. Have disc brake conversion, 23” Lokar shifter, new 18 gallon tank.
    Looking at set of dolphin gauges any feedback?
  8. little red 50
    little red 50
    I've had a set in my 54 for about six years and have not had any problems. And they are accurate.
  9. Seth_McK
    Seth_McK
    What did you use to surround the gauges in the cluster?
  10. DIYGUY
    DIYGUY
    from West, TX
    I like dark posts too.
    scotty t likes this.
  11. little red 50
    little red 50
    The gauges came with an aluminum insert for the original bezel.
  12. Hdonlybob
    Hdonlybob
    Definitely the second picture..paint the pillars..
    And yes cool car.. :)
    Good luck
  13. dark posts. i am a fan of the side skirts....
  14. Terrible80
    Terrible80
    DIYGUY and scotty t like this.
  15. oldfordnutt
    oldfordnutt
    from Modesto,Ca
    I had a 54 back in the day, treated it to a mild custom treatment painted all green. Did not like two tone.
  16. Seth_McK
    Seth_McK
    I appreciate the feedback from everyone, anyone have a line on a good single stage surf green?
    Got my baby moons from Mikes Hubcaps today!
    quick85 likes this.
  17. Jalopy Joker
    Jalopy Joker
    Baby Moons look good - take off the bumper guards for a smoother look.
    quick85 likes this.
  18. Seth_McK
    Seth_McK
    That’s this weekends plan, will 0000 steel-wool work for brightening the stainless and chrome?
  19. atomickustom
    atomickustom
    SOS pads for the chrome. They wont help the stainless unless there is a layer of scunge built up on it. Polishing compound for the stainless.
    I don't know if you care about "stock" but they came from the factory with the dark green in metallic and the light seafoam had no metallic at all. (Original colors on my '53 210 and a '54 Pontiac I used to have)
  20. dan31
    dan31
    I'd leave the pillars the body color,if you paint them to match the roof it become a "T" and cuts the car in half making the car look short and squatty .The trick with 53.54's is to make them look longer and lower ,imo. Cool car.
    Seth_McK and Jalopy Joker like this.
  21. Seth_McK
    Seth_McK
    I dig the green metallic, not looking to change that. I wanted to hear if adding metal flake to the Surf green would mess the look up and that seems to be the general consensus.
    Atomickustom, thanks for the info on the chrome/stainless!
    Dan31, never looked at it that way... makes sense.
  22. Casey Riley
    Casey Riley
    from Minnesota
    Definitely dark green on the pillar.
  23. verde742
    verde742
    don't use SOS pads on chrome , use AJAX or BO NAMEE
    scratches the bumper, hastening rust..
    Chrome is like clear, brightens the Nickel under it
  24. low budget
    low budget
    from Central Ky
    I need to try this sometime, I have always used SOS pads with great results, but someone in every thread will say SOS pads will scratch the chrome??? I have never witnessed SOS pads making a rusty part look worse or even saw where its made scratches....maybe I cant see good, I dont know???
  25. madfish
    madfish
  26. wvenfield
    wvenfield
    You asked opinions. I'd never put modern gauges in an old car. They almost always look out of place and one of the coolest things about an old car is the gauges. I also like the B pillars body colored but the two tone looks great.
    Surfcityrocker and Seth_McK like this.
  27. Seth_McK
    Seth_McK
    madfish likes this.
  28. Hdonlybob
    Hdonlybob
    ON EDIT from my original post.
    Went to a car show today and saw this one...similar to yours... Pillars are painted roof color on this one....
  29. low budget
    low budget
    from Central Ky
    I think a set of 15x6 reverse dish cragars would look good with current paint.
  30. I like the pillars body color.
    I have had Dolphin gauges for 15 years in an OT Cutlass. They have worked well for me. I have the 4 in one, speedometer and tachometer.
