Technical Removing mesh from Hilborn MFI 6A nozzles
Discussion in 'Traditional Hot Rods' started by jugheadjones, Sep 3, 2019.
  1. jugheadjones
    jugheadjones
    Hi all,
    Would removing the mesh from inside my Hilborn 6A nozzles cause any flow issues, or have any negative effects? I’m assuming it’ll increase flow.
    Here’s a pic for reference. [​IMG]
    Many thanks.
  2. Pete Eastwood
    Pete Eastwood
    from california
    I believe the mesh helps atomize the fuel. if you want to increase the flow , raise the fuel pressure or go with a bigger nozzle.
    kidcampbell71, 427 sleeper and Deuces like this.
  3. RichFox
    RichFox
    Of course the mesh is meant to catch trash before it plugs the nozzle. If you want more flow, why don't you get bigger nozzles? Or if that's your thing, drill yours.
  4. jugheadjones
    jugheadjones
    I’m trying to clean my nozzles and if I remove the mesh I’ll be able to clean them so much easier. I don’t want to increase or decrease flow, just wondering if I remove mesh (for cleaning purposes), will this effect anything?
  5. dreracecar
    dreracecar
    from so-cal
    Enderle nozzles do not run screens, a lot of dirt track racers remove them for ease of maintence and to eliminate them plugging. most small trash just blows thru the orifice, anything bigger and plugging the nozzle, you need to up you maintence game. The deflector tip break up the stream enough for atomazion , straight thru would need screens
    jugheadjones likes this.
  6. dreracecar
    dreracecar
    from so-cal
    What type of fuel?????
  7. jugheadjones
    jugheadjones
  8. jugheadjones
    jugheadjones
    Thank you!
  9. jugheadjones
    jugheadjones
    I can’t see how you’d replace the mesh without separating the 2 piece nozzle that’s been soldered.
  10. dreracecar
    dreracecar
    from so-cal
    100_2765.JPG Do yourself a favor and switch to enderle nozzles and holders, the holders stay with the manifold and does not wear out the threads, The nozzles easily are removed for cleaning and/or changing the nozzle area and they are cheap @$7.00 ea, vs $30 for Hilborns. Hilborn plays with fuel pressure to tune, Enderle is a both nozzle area and pump pressure. FYI Holley Ind just bought Hilborn, how that's going to affect the racers IDK
  11. dreracecar
    dreracecar
    from so-cal
    If you have to run Hilborns with the screens, Harbor Freight sells a "sonic cleaner" that does a pretty good job of getting them real clean
    Deuces and jugheadjones like this.
  12. jugheadjones
    jugheadjones
    That’s a massive difference in cost re nozzles. Definitely worth looking at indeed. I’ll get it running with the Hilborn nozzles first and look at swapping them out.
    I think I’ll remove the screens altogether. A nightmare to clean otherwise. Especially going forward.
    Interesting to see what happens to Hilborn with the acquisition of Holley.
    Thanks for your help.
  13. dreracecar
    dreracecar
    from so-cal
  14. jugheadjones
    jugheadjones
  15. RichFox
    RichFox
    It's not a big deal to unsolder the tips and then put them back. Propane torch works fine. When I was making the injection mainafold for my Dodge I decided I wanted to point the slot differently than they were. In that case I just heated them and rotated them without removing them. But then I decided to use brass JIC fittings. Drill them for the Hilborn tip and after that I could use regular AN fittings instead of the Hilborn thread. Worked OK. So I made some tips of my own. Never tried them. Looked good. Would have neede some time with a flow bench to see how I did.
  16. jimmy six
    jimmy six
    A good filter will help a lot....with 80% the holes in the nozzles are big enough to let just about anything through them and you don't need any screens.....:rolleyes:
  17. jugheadjones
    jugheadjones
    I like it!
  18. jugheadjones
    jugheadjones
    When I have some spare time I’d like to separate one and have a look. A fun little excuse to loose some time
