Drain pan is leaking .This is the 3rd time I have replaced it Pan perfectly level at bolt holes ,checked on granite flat surface / perfect, not sprung, not leaking at the transmission & kick down connections ,always use a quality gasket ,torque the bolts and stager as I tighten. For sure- leaking at the gasket. Any suggestions ? What is the best ( gasket) for this application ? Thx Gene
There are about a dozen places above the pan that can leak on a TH350. Some of them are pretty hard to see. Here's a partial list of things to check. Yeah, it's long. shifter shaft seal shifter shaft worn accumulator cover O ring governor cover O ring speedo gear worn speedo gear sleeve inner seal speedo gear sleeve O ring front pump seal front pump O ring front pump bolt washers kickdown cable housing kickdown cable O ring dipstick tube O ring dipstick tube cracked cooler line nut loose cooler line fitting washer rear extension housing O ring line pressure plug
Most of the new metal pans are pretty thin and weak hence the bolts pull through the gasket easily. I've gone to using only a quality aluminum pan like TCI.
Yikes squirrel. I guess I have a lot of things to look at . Nothings easy when building these old cars. One step forward and 5 steps backward.
