1934 Ford Roadster steel car. Can you identify if this is a true Roadster door or a coupe turned into a roadster I was always told if the door is too thick it was a coupe turned into a roadster
Pictures of the whole car may be more helpful, although with the knowledge on here you will still probably get your answer.
