Customs I just picked up a 1946 Oldsmobile project
Discussion in 'The Hokey Ass Message Board' started by Binger, Aug 11, 2019.
  1. Binger
    Binger
    from wyoming
    IMG_2302.jpg IMG_2309.JPG IMG_2304.jpg IMG_2303.jpg IMG_2300.jpg I just picked up this solid 1946 Oldsmobile project. This car lived in a garage across the street for the last couple of years. The chance to buy it came up and I jumped at it. Not sure of the Plans yet. Leaning towards a mild custom. Lower a couple of inches and make it able to drive highway speeds. Might not be the easiest with the stock straight eight that is in there. So I will probably be looking for a motor trans swap. I really am digging the great body lines on this car. I definitely want to paint it as I don't like the "patina" look. Many cars deserve to be saved but this one I think is a little too far gone.
  2. A Boner
    A Boner
    A friend made his early 50's Buick straight eight freeway friendly with an automatic overdrive transmission.
    Stogy likes this.
  3. tubman
    tubman
    That car looks extremely solid. No rust in the usual places (that I can see), and the trim on the drivers side looks real good. That puts you ahead of the game.
    As to highway friendly, I don't know much about Oldsmobile straight eights except they are 257 cubic inches. I have a 255 merc in my '51 Ford with no overdrive and 3.55 gears, and it will cruise all day at 65. I can't believe that Olds is much heavier than the Ford, and it looks more aerodynamic. I would think a little head work, a better ignition, and upgraded carburation would make that a decent highway cruiser.
    BTW, Hydra-matic or stick?
    Stogy, loudbang and Binger like this.
  4. hotrodharry2
    hotrodharry2
    from Michigan
    I have a couple of books for '48 Oldsmobile, 1 is body parts and the other is chassis. They are old, worn & dirty. If you'd like them, pm me. I'd donate them to your cause if they'd be of any help. I googled 48 Oldsmobile images and they look close to yours.
    Stogy, loudbang, Binger and 1 other person like this.
  5. scrap metal 48
    scrap metal 48
    Cool project.. I like your plan.. I really like the fastback look....
    Stogy and loudbang like this.
  6. Binger
    Binger
    from wyoming
    The car is an automatic Hydromatic drive. I will see if the engine runs and then decide what to do for engine and so on. Here is a few more pictures!
    IMG_2313.jpg IMG_2314.jpg IMG_2319.jpg IMG_2318.jpg IMG_2315.jpg IMG_2316.jpg
  7. The potential's there..just add motivation, time and dollars.
    Good luck!
  8. Peanut 1959
    Peanut 1959
    Though you aren't "preserving" it, you ARE saving it! Looking forward to following your progress.
    Stogy, mgtstumpy, loudbang and 2 others like this.
  9. Binger
    Binger
    from wyoming
    One more of the engine.
  10. krylon32
    krylon32
    from Nebraska
    1. Central Nebraska H.A.M.B.
    Saved one of those from the crusher many years ago, still sitting in my storage building and will probably be there when I die?
  11. Fortunateson
    Fortunateson
    I'll follow along as I have a '47 Buick Sedanette I'll have to get to one of these days.
    Stogy, loudbang and osage orange like this.
  12. tubman
    tubman
    BTW, I agree with you on the "patina thing".
    Stogy, loudbang, osage orange and 2 others like this.
  13. rtp
    rtp
    When you go to pull the wheels remember the driver side lugs are left hand thread .
    Sent from my VS987 using The H.A.M.B. mobile app
    Stogy, Jalopy Joker, loudbang and 3 others like this.
  14. rtp
    rtp
    Found a little gas leak .pulling the tank.
    This is a 48 66 series . had it since 1978.
    Can't help with st8 . but can help with putting in a later old's v8 and auto,if interested. 0809191227_HDR.jpeg
  15. Atwater Mike
    Atwater Mike
    1957: At 15 years of age, I worked at the best garage in town. Boss told me to 'snap the head off that '46 Olds, get ready to give it a valve job'.
    At 90 lbs. soaking wet, when I lifted the head off the block, I was severely 'over-centered'. Went over the fender head first into the engine room...
    Boss's partner pulled me out by the feet, and I never let go of the head! Whew!
    Stogy, Chief 64, 302GMC and 5 others like this.
  16. OLDSMAN
    OLDSMAN
    That’s a fantastic car to start with. A mild custom would be my way to go with the car
    Stogy, Binger and osage orange like this.
  17. e1956v
    e1956v
    Alliance Vendor
    Here's one that belongs to a customer of mine. Just for a little inspiration. I know it's a Buick but their kissing cousins.
    Sent from my SAMSUNG-SM-G890A using The H.A.M.B. mobile app
  18. winduptoy
    winduptoy
    Nice score John! I see why you snatched it up.... the review committee assembled now to put them to work.
    Well by the looks of the trunk you may have already
  19. Binger
    Binger
    from wyoming
    Thanks for the Heads up. I have a '61 Dodge Lancer wagon that has the same left hand threads on the lugs. I would probably break one off trying to pull one off if I didn't know. The possibility of running a later olds engine in it is pretty appealing. I am excited to get a nice smooth big car for longer road trips. My banger powered A isn't very comfortable after an hour or two on the road.
    I didn't expect this much interest in this car. Does anybody know about the availability of parts like brakes and suspension components? Are they difficult to find? I haven't began looking for parts yet. How are the drum brakes given they are in good repair and adjusted?
  20. Binger
    Binger
    from wyoming
    I had the crew to push the car home. It literally had to come from across the street. maybe about 150 feet total. I ended up with more help than necessary. I think some of them just wanted to see the new project. @winduptoy are you and Rick going to make the Hill Climb in about a month? I hope to see you down there.
  21. winduptoy
    winduptoy
  22. mgtstumpy
    mgtstumpy
    Same body as my Olds 46 sedanette, model 76 (Straight 6) Dynamic Cruiser however spears on your front fenders aren't 46 but 47/48, check your data plate for style as prefix indicates YOM. 76/8 was the intermediate 'B' body, 'A' bodies were 66s with 'C' bodies being 98s. Yours is a 78 (Straight 8). Wrap around rear bumpers give it away as a 'B' body. 'A' and ''C' body parts won't interchange with 'B' body however some may.
    • 1946 - OLDSMOBILE name in an oval recess in the fender molding;
    • 1947 - OLDSMOBILE name in the molding but not in oval recess as per '46; and
    • 1948 - Plain chrome molding without Oldsmobile name.
    1946-1947, triangular emblem with grill blocks and full chrome grill. Rubber gravel shields on rear fenders
    1948, circular emblem with no grill blocks and painted lower grill tray. S/S gravel shields on rear fenders
    Serial:- 76-******
    Style:- 46-3607 1946 - YOM et al, 3607
    OEM Hydramatic emblem with '8' cylinder emblem on trunk
    upload_2019-8-12_16-50-32.png 1946
    upload_2019-8-12_16-28-0.png 1947
    upload_2019-8-12_17-21-17.png 1948
    Some inspiration
    Stogy, 302GMC, scrap metal 48 and 6 others like this.
  23. mgtstumpy
    mgtstumpy
  24. mgtstumpy
    mgtstumpy
  25. Binger
    Binger
    from wyoming
    Thanks @mgtstumpy That information is fantastic! I will have to check my Data plate and figure out what exactly it is. Title says 46 but who knows.
    Stogy, loudbang and mgtstumpy like this.
  26. 40Standard
    40Standard
    from Indy
    for a big ass car, you need a big ass chevy engine with a 400 tranny, good luck on your project
  27. Jalopy Joker
    Jalopy Joker
    yep, Cool body style - obvious that there is a lot of hours & dollars needed to get it right no matter what you do if you keep it
  28. mgtstumpy
    mgtstumpy
    If chance it's a 46 with 47/48 fender spears I've got similar data here. I bought a workshop manual to assist with my car, invaluable and worth it.
    I'm onboard to watch things progress; mine's ten (10) years in the making and finally a lot closer to being finished.
    If there is a 'D' suffix after 47-3607 it's a deluxe, hence the rear seat centre arm rest and other additions.
    Sent from my SM-G973F using The H.A.M.B. mobile app
  29. Atwater Mike
    Atwater Mike
    I have some experience with 455 Oldses; this engine with 400 Turbo Hydro transmission is excellent, package is very 'torquey', ideal for the 'heavier cars'.
    The late 'Doctor Olds' ( Joe Mondello) made a name in SBC head porting/ angle porting/ re-designing, then turned to Oldsmobile performance, in which once again, he excelled. His 'factory' was/ still is located in Paso Robles, CA.
    The Mondello Co. will provide you with the complete book to Oldsmobile Performance, along with a supplement. I recommend it, a better parts source is non-existent.
    Stogy, loudbang, Caprice89 and 3 others like this.
  30. mgtstumpy
    mgtstumpy
    Any progress updates?
    Stogy likes this.
