Hot Rods using tie rods as suspension links
Discussion in 'The Hokey Ass Message Board' started by Tommy Frantz, Aug 6, 2019.
  1. Tommy Frantz
    Tommy Frantz
    Anybody here ever use tie rods as suspension links instead of heim joints? I have a bunch of class 8 truck tie rods I'd like to use as suspension links...
    Elcohaulic likes this.
  2. 2OLD2FAST
    2OLD2FAST
    from illinois
    LOOK AT PICTURES ..
    gimpyshotrods likes this.
  3. OLDSMAN
    OLDSMAN
    A tie rod end isn’t designed to support any weight. Don’t use them for this purpose if you value your life.
    RonaldR likes this.
  4. alchemy
    alchemy
    I think he means tie rod ends. Yes it is done all the time. The standard 40-48 ends are common on split wishbones, but the slightly bigger ones from 50’s bigger trucks are a good choice too.
  5. Tommy Frantz
    Tommy Frantz
    I mean tie rod ends.
  6. Tommy Frantz
    Tommy Frantz
    My tie rods would be in tension in my application.
  7. by "In Tension" what do you mean? like in a triangulated or parallel four link?
  8. Tommy Frantz
    Tommy Frantz
    Parallel four link. The leaf spring will be the bottom link and the tie rod will be the top link.
  9. 3340
    3340
    Elcohaulic and bschwoeble like this.
  10. Got a photo, I can't visualize this setup. HRP
    Blues4U likes this.
  11. jimgoetz
    jimgoetz
    Are you talking about what most people call " Traction Bars" ?
  12. mgtstumpy
    mgtstumpy
    Load on tie rods - Front are in compression and rear are in extension when being driven. I gather that majority of load is static when car sitting however there would be some load there due to suspension being loaded with weight and cycle slightly when driving?
  13. Atwater Mike
    Atwater Mike
    I made some 'traction Masters' for my '51 Olds coupe...I used '53 Stude tie rod ends, worked great...if a 'little' rigid.
    Fremont drags a month or so later, I came blazing out of the lights, when the dual range hydro (B&M kit) grabbed second, the drivers side front tie rod end came out of the socket, Olds got an instant 'crutch', and over-centered the left traction bar! Wheee!
    Got waaaay outa shape, but back under control...
    I changed the bars to tubing 'eyes', and '50 Ford pickup tapered rubber shock bushings.
    The 'soft' attachments forgave the 'shock' of the B&M shift. Hey! 'SHOCK' mounts!
    Hey Moe, hey Larry! HEY... I was 20. (hard lesson: I used tie rod ends for everything, just like Ivo & Norm)
  14. X-cpe
    X-cpe
    Sounds like 1/4 elliptics as the lower link with tie rod as the upper.
  15. bschwoeble
    bschwoeble
    Sweet. Perfect. If someone wants to build a "Hot Rod", they need to study this picture.
  16. Atwater Mike
    Atwater Mike
    'Textbook example'. Gospel.
    3340 likes this.
  17. Blues4U
    Blues4U
    from So Cal
    I'm sorry, but that makes no sense. The tie rod connects left steering arm to right steering arm, not the axle to the chassis.
  18. X-cpe
    X-cpe
    Part of building a hot rod is re-purposing parts.
    3340, 62rebel and VANDENPLAS like this.
  19. Class 8 tie rod ends are humongous, just saying.
    gimpyshotrods and 3340 like this.
  20. Blues4U
    Blues4U
    from So Cal
    Still doesn't explain what he's trying to accomplish.
  21. squirrel
    do those have about a 7/8" thread size?
    3340 likes this.
  22. 41fred207
    41fred207
    This is my experience using them. Lower rear radius rod mounts of triangulated 4-bar. I found them to be in serious compression dumping the clutch in 2nd after tires were warmed up but on a side note I'm running 33/19.5's. making new brackets now to get through the summer before going double shear this winter
  23. alchemy
    alchemy
    Looks like Fred had a bracket failure, not a rod end failure.
  24. 3340
    3340
  25. 3340
    3340
  26. 3340
    3340
  27. 3340
    3340
    Installed years ago heavy duty 7/8 studs grease regular
  28. 41fred207
    41fred207
    Yes, it was a bracket failure but was just showing the weakness of single shear and that it is in compression when under power.
    3340 likes this.
  29. How are you going to be using these? Suspension components will experience loading in both tension and compression, even in a parallel 4-bar design.
    When driving, both sets of radius rods will experience a compressive load. The rear axle will drive its radius rod forward into the frame. The frame will subsequently drive the front axle's radius rod forward into the axle. This would be a compressive load. When the car is stopped, the loading on the rear radius rods will reverse as the momentum of the car tries to pull the radius rod out of the rear axle. That would be a tensile load.
