Hot Rods The No Frame Model A Modified
Discussion in 'The Hokey Ass Message Board' started by rottenleonard, Sep 22, 2017.
  1. rottenleonard
    rottenleonard
    I called Dustin at Pohl Spring wined a little and he pulled a rabit out of his hat. Sneeking us in front of his workload fabbing me up a new main leaf to make the car a lot more drivable. I like low cars just as much as the next guy, but I really like drivable cars better. It will still come down a little once the body is on and you get a couple potatoe fed farm boys in there.
    I could write a book an all the sketchy ways to work with a Model A rear spring. The first one I messed with 20 years ago nearly took my head off as I had no idea they were pre loaded. I about shit myself when I drove out the shackle and that S.O.B. stood up.....
    Next up the wiring was fully completed
    I know you going to miss the yellow and orange plug wires
    chryslerfan55, Jet96, Stogy and 8 others like this.
  2. rottenleonard
    rottenleonard
    Time to learn about these SU carbs, some say they are great, some say not so much....
    Sure ain't much to them
    Cleaned up and because I don't have time to I decided i had better get out the polishing wheels
    Re installed
  3. Tim
    Tim
    from KCMO
    Lookin good!
  4. 1-SHOT
    1-SHOT
    from Denton
    I see that you raised it up to clear any horse turds on the street.
  5. rottenleonard
    rottenleonard
    So the car is together at least as good as it's going to be. The SU's were both flooding terribly. I spent a day and a half messing with the seats, and float arms. Putting the gravity bowl off the NW vintage dragster. Finally i even grabbed the ugly harley carb out of desperation.
    Gawd I hate that setup, so I started digging on the internet and ran accross this
    Ok one more look at the SU's
    Yep those assumed vacuum ports are bowl vents.......F-ME!
    Take those caps off I stuck on there they work perfect:rolleyes: learned that one the hard way.
    Next teething issue the 2 piece Mallory cap I love so much is leaking or shorted, good spark on the coil wire random spark on the plug wires.
    So I called some friends for parts, one pulled the distributor out of his stocker but that required the stock ignition switch and model A coil. Another had a smaller Mallory dual point in pieces that saved the day! Thanks Aaron!
    I now have it together and the car is running decently. Loading up this morning for Bonneville.
  6. 1-SHOT
    1-SHOT
    from Denton
    Glad you got your S/U fixed. That's how e learn is from our mistakes. It's the simplest things that give us the most problems. Anxious to see some B'ville pictures. Frank
    chryslerfan55 and rottenleonard like this.
  7. rottenleonard
    rottenleonard
  8. 1-SHOT
    1-SHOT
    from Denton
    Well done. Thanks for the ride. Frank
    kidcampbell71 likes this.
  9. rottenleonard
    rottenleonard
  10. captainjunk#2
    captainjunk#2
    a very cool lil car
  11. Good luck, be safe ... and kick some ass !!
  12. Nostrebor
    Nostrebor
    So much awesome in one thread.
    Looking forward to the adventures on the salt! Assuming the board remembers to send me notifications.:mad:
  13. 1-SHOT
    1-SHOT
    from Denton
    Was that a bar stool racer in the shop?
  14. rottenleonard
    rottenleonard
    Lil'Alb, mgtstumpy, Stogy and 7 others like this.
  15. AHotRod
    AHotRod
    A true Hot Rod Leonard, very well done.
  16. 1-SHOT
    1-SHOT
    from Denton
    Leonard you made it Congratulations.
  17. rottenleonard
    rottenleonard
  18. King ford
    King ford
    from 08302
    Greetings again Leonard!....where did you get your fuel tank?...what was it originally for...( I've been following your thread but don't remember if you said so ...and DAMN it's a pretty long thread!)
  19. rottenleonard
    rottenleonard
    Its a reproduction model T tank.
  20. Stogy
    Stogy
    ERguitar likes this.
  21. King ford
    King ford
    from 08302
    Thanks for the info Leonard!..DAMN SHARP CAR....
  22. Blues4U
    Blues4U
    from So Cal
    That black 3 window coupe with the 70 B/M on the side, that's a local guy. His Instagram handle is rockabillyjesus, and he also has a beautiful custom Zephyr coupe.
  23. rottenleonard
    rottenleonard
    Maybe, found a lot of people this week. Been having a blast. Worked threw a couple problems with the car. Found that some things are better than expected. Some things need some work. The car seems to be well received, that feels great. Having a great time despite the rain delay.
    20190810_202545.jpg 20190810_170637.jpg 20190809_182934.jpg 20190810_091739.jpg 20190810_121508.jpg 20190810_122634.jpg 20190811_092338.jpg 20190810_092059.jpg 20190811_170636.jpg 20190811_171826.jpg 20190810_092620(0).jpg 20190811_170700.jpg 20190811_164941.jpg 20190811_171833.jpg 20190811_165052.jpg 20190811_165016.jpg
  24. drtrcrV-8
    drtrcrV-8
    How does the car handle? Do you feel that you will need to change the springs(or shocks) any, & if so, how much? Any other changes/updates you are considering for this "build"? I love it, but I know every "1st time" needs a little "tweaking" of some sort.
    Stogy likes this.
  25. Blues4U
    Blues4U
    from So Cal
    Looks like it flooded out. The ol' spark plugs on the range trick....
  26. rottenleonard
    rottenleonard
    Yeah there is some stuff that's way better than I thought it would be, the brakes I just grabbed a couple of Wilwood Master cylinders random sized off the shelf for a starting point. I don't think it could work any better. The car stops fast and straight. You can slide all four if you want to , but the front will lock up before the rear. Brake pressure is perfect. As for the ride on smooth the roads the car handles beautiful. You can let go of the steering wheel and it will drive straight as an arrow without any weird vibrations. How ever on bumpy roads and to no surprise that unsprung weight ratio really shows its ugly head. The rear spring still need some work as it's way too soft and sagged down as the weekend went on. And I will have to do a lot of work to lighten up the axles that I knew would be the case. Once we got the ignition and the SU's sorted out the carburetors perform very well and I have not tuned on them a whole lot so I am at this point thrilled with the SU carbs.
    brEad, Stogy, Blues4U and 3 others like this.
  27. rottenleonard
    rottenleonard
  28. Well deserved RL :rolleyes:....awesome!
    Stogy likes this.
  29. Stogy
    Stogy
