Technical Crower cam #M4807 specifications?
Discussion in 'The Hokey Ass Message Board' started by Richard/SIA, Jul 28, 2019.
  1. Richard/SIA
    Richard/SIA
    from No. Nevada
    Also marked with X20F
    It's from a 225 "Odd-Fire" Buick V6 I am freshening for use in a custom 50's - 60's sports racer type car build.
    No luck finding anything at the Crower site.
    I will be freshening the engine so need the cam specs as I will probably have to get custom pistons.
    The old ones are fine but are slightly dished, I hope to up compression with flat tops.
    Also have just a bit more cylinder ridge than I am comfortable with for re-using the old pistons.
    And before the usual suggestions that I go with a 231 or SBC, this is to be a very vintage vibe build and this engine had a LOT of trick work done to it.
    Can post pics if anyone is interested.
  2. sdluck
    sdluck
    Try contacting Crower
  3. Richard/SIA
    Richard/SIA
    from No. Nevada
    I've already emailed them but judging from several other post here I do not expect much help from them.
  4. Richard/SIA
    Richard/SIA
    from No. Nevada
    Yep, I reached Sargent Schultz, "I know nothing!"
    So still looking for someone with an old catalog to help me out.
