Hot Rods Save of the day!!(single seater)
Discussion in 'The Hokey Ass Message Board' started by rusty rocket, Mar 14, 2017.
  1. Nice job, much better lookin' 4 sure. Happy 4th Rocket!
  2. Blues4U
    Blues4U
    from So Cal
    I did the same thing with the aluminum radiator in my A pickup, black is much better than shiny aluminum.
    Stogy likes this.
  3. rusty rocket
    rusty rocket
    Thanks, rite back at cha!
  4. Shadow Creek
    Shadow Creek
    That’s some nice aluminum work. I have a question on the radiator.. since you moved the upper neck above the filler are you going to put a fill cap in the upper hose so you don’t get an air pocket?
    Stogy likes this.
  5. rusty rocket
    rusty rocket
    Yeah I think I will have to.
    Stogy likes this.
  6. Shadow Creek
    Shadow Creek
    I figured it was probably something you had already thought of but I asked anyways. This build is so cool, I always look forward to the updates. Keep up the good work.
    Stogy and Peanut 1959 like this.
  7. rusty rocket
    rusty rocket
    So awhile back i was tinkering around on a light on the headrest part of the car. The head rest was made from a 46 chevy p.u. Headlight that I cut down. I had an idea to take the parking light section a chunk out of it and turn it around so it faces the back of the car. I have a l.e.d light/ brake that i can hide inside so it gets the light a bit higher so folks can see it.
    Whats you guys thoughts on looks? To me it sort of takes away the drop of the headrest but it also has a funky art deco look. image.jpg image.jpg image.jpg image.jpg
  8. rusty rocket
    rusty rocket
  9. Wayne67vert
    Wayne67vert
    What if you were to mold just the lens part into the rear tip of the headrest?
  10. rusty rocket
    rusty rocket
    All the wrong contours to do that.
  11. Stogy
    Stogy
    Me Likey...:D...Your a crafty Man @rusty rocket...now can you get that lens Red?
  12. rusty rocket
    rusty rocket
    No but i have some translucent red paint I can airbrush on the inside of the lens.
    Stogy likes this.
  13. enjenjo
    enjenjo
    from swanton oh
    The difference is not the year, but which plant stamped the fenders. As dies were repaired, they often came out a bit different. As long as they fit the body, and since no one could see both sides at once, and Ford was a cheap car, and people were desperate for a new car at the time, they were painted and drove out the door. I had a 48 here one time, with all original parts that had the rear wheel openings nearly 2" different.
    Stogy likes this.
  14. enjenjo
    enjenjo
    from swanton oh
    I've milled up to .100" of of those heads with no problems.
    Stogy likes this.
  15. rwrj
    rwrj
    from SW Ga
    I like it with the tail light. Looks good and serves a purpose.
    brad2v and Stogy like this.
  16. rusty rocket
    rusty rocket
    Thanks, I value your opinion.
    Greenblade and Stogy like this.
  17. I like the tail light, also. After seeing it with the tail light it looks a little bare without it. I love this build.
  18. Peanut 1959
    Peanut 1959
    I definitely like it "with". And a sneaky CHMSL is a really bright idea...pun intended!
    Stogy likes this.
  19. enjenjo
    enjenjo
    from swanton oh
    How about combining one of the marker lights you tried earlier with the fender light you have.
  20. plym_46
    plym_46
    from central NY
  21. brad2v
    brad2v
    My .02, I like it.
  22. atch
    atch
    Well; I guess I'm the odd ball here but I like it better without. But opinions are like...
  23. rusty rocket
    rusty rocket
    Oh man i get the a#%hole thing! I get called that all the time!
  24. Blues4U
    Blues4U
    from So Cal
    I think it looks cleaner without, but I love the cleverness of adding the light there.
  25. rusty rocket
    rusty rocket
    I like the look with out also, but I'm leaning towards putting it on more on the safety side.
  26. Fabber McGee
    Fabber McGee
    Put a bright s.o.b. of an led in the lower light and you'll be seen after dark just as well as any motorcycle. Haha, I doubt you'll have any problems getting noticed during the daylight hours.
  27. I love this car! Every time I see it, it reminds me of a hopped up bumper car! So unique and creative.
    Atwater Mike and Stogy like this.
  28. rusty rocket
    rusty rocket
    Just got my drive shaft back from a frind that is a leather worker. He made me a kool ass trunnion joint boot to keep the grease in. image.jpg image.jpg image.jpg
  29. plym_46
    plym_46
    from central NY
    Double needle baseball stitch??
    Stogy likes this.
  30. rusty rocket
    rusty rocket
    Oh yes! And it has a small leather flap inside,under the stitch that keeps the grease from the baseball stitch.
    Okie Pete, brad2v, plym_46 and 4 others like this.
