Technical Un-polishing Staineless Steel?
Discussion in 'The Hokey Ass Message Board' started by 5window, Jul 13, 2019.
  1. 5window
    5window
    I have strip of polished stainless (formerly part of a prison mirror blank) about 2' x 28" that I need to bring down to a satin finish. I don't have a lot of scrap to experiment on, so I'd appreciate ideas on how to do this. Directional sanding, random orbit sanding, wet-dry paper,grit size,etc. Opinions appreciated.
  2. pirate
    pirate
    from Alabama
    Scotch Brite either red or green
    Tim likes this.
  3. pitman
    pitman
    Was gonna say. Experiment, find your pref. Grade, and go. Drag all the way across.
    I've used a guide board, to help align passes.
  4. rusty rocket
    rusty rocket
    I was going to say scotch brite also but what about some 1500 grit on a d.a.?
  5. Happydaze
    Happydaze
    Blasting should give you a uniform finish.
    Chris
    deathrowdave likes this.
  6. David Gersic
    David Gersic
    from DeKalb, IL
    I’d go with red Scotchbrite pads. Maybe green, but start with red.
  7. David Gersic
    David Gersic
    from DeKalb, IL
    That’ll be too shiny if he’s looking for “satin”.
  8. 51504bat
    51504bat
    If I remember correctly when the stainless exterior on the Kodak theater in downtown LA was causing extreme sun reflection issues the cure was to Scotch Brite the entire building to cut down on the sun glare.
    pitman likes this.
  9. Hnstray
    Hnstray
    from Quincy, IL
    @5window ......they let you bring home souvenirs?? :eek:............ :D
  10. Lepus
    Lepus
    We use red and grey Scotchbrite at work, I don,t know what the grits are, but the grey is finer, and would be best for a matte finish, using a circular motion. Sand blasting or glass beading one side of a piece of sheet metal will put a curve in it.
  11. rusty rocket
    rusty rocket
    Another thought here, how about some muratic acid wiped from a soft cloth. That might etch the shininess off.
    sport fury likes this.
  12. That will turn it white and most likely streaky, scotchbrite is the best bet
  13. lake_harley
    lake_harley
    I agree with the scotchbrite but will offer another idea for you to consider. I needed to match a "brushed" finish on stainless steel projects at my fabrication business on a couple occasions. One time I used a belt sander with about an 80 or 120 grit belt and was pleased with the results. If a finer finish is desired you might also try the wheels that are used in a die grinder. They have alternating layers of scotchbrite material and sandpaper. It'll take a even, gently touch to not end up with "lines" but they can be touched up with scotchbrite pads. The wheels will just get you there quicker if you have a lot of area to do.
    Good luck.
    Lynn
  14. 5window
    5window
    :) There used to be a guy at Carlisle who had a whole pile of these sheets and sold them for about $10. I used a polished one on my A firewall. Came out pretty good.
    Hnstray likes this.
  15. Doublepumper
    Doublepumper
    from WA-OR, USA
    How about rubbing in some valve grinding compound? Dollop a glob of it on and use your hand to scuff it all around.
  16. David Gersic
    David Gersic
    from DeKalb, IL
    Better yet, put a Roloc on a die grinder and do some engine turning.
