Speedway SBC Front Engine Mount??
Discussion in 'The Hokey Ass Message Board' started by qzjrd5, Jan 17, 2006.
  1. Splitbudaba
    Splitbudaba
    C5846AC7-03D1-4859-8AC6-58B5A1CC89CE.jpeg 0AC0A720-FB0C-4CF5-A46C-2F114A2B0838.jpeg
    Yep! Helped with steering box clearance!
    Tman and 40ragtopdown like this.
  2. lake_harley
    lake_harley
    I had the same question and saw that wayne-o replied that he used 1/4". I was thinking 3/16" might do. There's a lot of depth in the cradle web plus they usually have a 90 degree flange to resist twisting. In searching the internet I came across a listing for a Hurst style mount from Vern Tardel that mentioned his were cut from 1/8" steel. It didn't mention if it would clear a mechanical pump so I sent a question to ask if it would and also to double check the thickness of the metal. Haven't received a reply yet since I just sent it today.
    Lynn
  3. NoRust
    NoRust
    From Speedway Motors, Part # 91602046, (new) fuel pump can be disassembled to index the inlet/outlet area. Plus the rated output PSI is 6. Edelbrock carbs need 6 PSI, while Holley carbs need 7 PSI. I have seen this fuel pump to work correctly with either of these 4 barrel carbs, thus without the need to install a fuel pressure regulator. I am also using a Hurst front mount.
    Splitbudaba likes this.
