Technical POWER BRAKE PEDAL
Discussion in 'The Hokey Ass Message Board' started by da dodge brother, Jul 6, 2019.
  1. da dodge brother
    da dodge brother
    from wisconsin
    I am installing power brakes in my 1955 Dodge. It seems that the brake pedal arm for the power brake set up is longer than the standard one. Is it, or do I just need to relocate the standard one somehow? Any idea where to get a different pedal set up??? Just need the brake pedal arm ... Thanks
  2. slim39
    slim39
    from pa
    I think you should use the orginal power brake arm. It was made for that system and if you change it that might change the pivot point and the mechanical advantage designed in the system. Good Luck. Slim
  3. Doublepumper
    Doublepumper
    from WA-OR, USA
  4. Don’t over think it. Determine the new length required and make the original arm longer to match.
