1969 Bronco rear axle . 58" axle flange to flange ( 52" backing plate to backing plate). 5 1/2" bolt pattern , 10" by 2 1/2 " brakes. Small bearing and sure to be 28 spline axles. Axles turn smooth as silk and chunk is smooth also ( ratio unknown). All brakes parts except the cables and 1 drum. Housing is not pitted will clean up nice. Will disassemble to ship if you don't want the chunk. $500 plus the ride or pick up 20 miles south oh Memphis Tn. Thanks Bill .
