Projects United Pacific 5W Deuce Build
Discussion in 'The Hokey Ass Message Board' started by Groovy, Feb 18, 2017.
  1. It will "work", but it won't "giddy-up" like a hot rod should. And your OD will be practically useless below 95 on the highway. You want your cruising RPM to be at the low end of when the motor is making power so you can accelerate within the power band if necessary. Again, plug your numbers into the formula I posted earlier. I currently run the same .63 OD that you have, and I run either a 30.5 inch tall 700-16 or a 29.5 inch tall cheater slick with a 4.11 rear gear. I started out with a 3.50 gear but swapped it out for some much needed grunt.
    MPH x Rear Gear Ratio x 336 / Tire Height x Overdrive = Cruise RPM
    65 x 3.50 x 336 / 30.5 x .63 = 1,578 RPM
    65 x 4.11 x 336 / 30.5 x .63 = 1,854 RPM
    65 x 3.50 x 336 / 29.5 x .63 = 1,632 RPM
    65 x 4.11 x 336 / 29.5 x .63 = 1,916 RPM
    For comparison, here's your combo assuming a 750-16 (31 inch tall) rear tire:
    65 x 3.23 x 336 / 31 x .63 = 1,433 RPM
    95 x 3.23 x 336 / 31 x .63 = 2,095 RPM
    65 x 3.23 x 336 / 31 x 1.00 (no OD) = 2,275 RPM
    Stogy, loudbang and tb33anda3rd like this.
  2. Groovy
    Groovy
    I knew when I chose the gearing that it wouldn't have the punch. I admit I drive rather civilized and don't like driving hard. Don't even like spinning the tires.
  3. 32fenderless
    32fenderless
    Did the trans shop ask you what size your rear tires were when they said the combination would work?
  4. Groovy
    Groovy
    Yes I gave him a size of 29 inch.
  5. Groovy
    Groovy
    Side exhaust is slowly getting finished... IMG_1854.JPG IMG_1851.JPG IMG_1855.JPG IMG_1852.JPG IMG_1857.JPG IMG_1859.JPG IMG_1861.JPG IMG_1863.JPG IMG_1862.JPG
  6. Groovy
    Groovy
    brEad and loudbang like this.
  7. Glad to hear about your experiences, it seems the pursuit of a low RMP in 5th gear is often to the detriment of the driveability and performance of the engine. I hope the OP can find a suitable solution.
    Sent from my SM-A520F using The H.A.M.B. mobile app
  8. Groovy
    Groovy
    IMG_2162.JPG Front axle seam has been smoothed out... IMG_2160.JPG IMG_2161.JPG
    alfin32, loudbang and DeLuxe 32 like this.
  9. Groovy
    Groovy
    Today used the die grinder to give the blended area some texture to make the surface look like a cast finish... IMG_2168.JPG IMG_2169.JPG IMG_2163.JPG
    alfin32, akoutlaw, Stogy and 2 others like this.
  10. My 32 has a tremec 3550. 3.50 gears and 29" tires. I run 68 mph most of the time at 1750 rpm. Under regular driving, I never have a problem. If I have to really pass someone, I'll put it in 4th. This is a 302 Ford and the truck weights 3300 lbs.
  11. Groovy
    Groovy
    Headers are all together. Next is to TIG all the seams... IMG_2181.JPG IMG_2182.JPG IMG_2183.JPG
    brEad, Stogy and loudbang like this.
  12. Groovy
    Groovy
    All the front suspension is painted Volvo Gray... IMG_2191.JPG IMG_2192.JPG IMG_2193.JPG IMG_2194.JPG IMG_2195.JPG IMG_2196.JPG
    alfin32, brEad, loudbang and 2 others like this.
  13. Groovy
    Groovy
    IMG_2396.JPG IMG_2395.JPG IMG_2398.JPG IMG_2397.JPG IMG_2394.JPG Final fitting is done and ready to take body off chassis to start final prime and paint.
    The 39 guy, alfin32, brEad and 2 others like this.
  14. Groovy
    Groovy
    Frame is ready for finish welding and brake and fuel lines are fully fitted. IMG_2455.JPG IMG_2456.JPG IMG_2457.JPG IMG_2458.JPG IMG_2459.JPG IMG_2454.JPG
    The 39 guy, teach'm, alfin32 and 3 others like this.
  15. Groovy
    Groovy
    Finally body filler is finished and frame is ready to get the epoxy primer sanded in preparation for a high solids primer... IMG_2477.JPG IMG_2476.JPG IMG_2475.JPG IMG_2474.JPG IMG_2473.JPG IMG_2472.JPG IMG_2471.JPG IMG_2470.JPG
    The 39 guy, alfin32 and brEad like this.
  16. Groovy
    Groovy
  17. Groovy
    Groovy
    Carb throttle bracket is tacked together and chassis rotisserie is mostly finished. IMG_2512.JPG IMG_2513.JPG IMG_2514.JPG IMG_2511.JPG IMG_2505.JPG IMG_2507.JPG
    akoutlaw, brEad and loudbang like this.
  18. Groovy
    Groovy
    Frame rotisserie is finished. IMG_2516.JPG IMG_2517.JPG IMG_2518.JPG IMG_2519.JPG
  19. That looks very serviceable. Nice work on the rotisserie.
  20. Groovy
    Groovy
  21. Groovy
    Groovy
    Urethane primer applied... IMG_2541.JPG IMG_2542.JPG IMG_2543.JPG IMG_2544.JPG IMG_2545.JPG IMG_2550.JPG IMG_2549.JPG IMG_2538.JPG IMG_2539.JPG IMG_2547.JPG
    Just Gary, alfin32, loudbang and 2 others like this.
  22. flynbrian48
    flynbrian48
    Wow. Your attention to detail is incredible, I wish I had your patience. Great, great job.
  23. Groovy
    Groovy
    I painted these parts to get an idea how the paint lays down and to check the color before I lay it on the frame... IMG_2636.JPG IMG_2637.JPG IMG_2638.JPG
  24. panhead_pete
    panhead_pete
    Very very nice!
    kidcampbell71 and loudbang like this.
  25. loudbang
    Good stuff I like shiny new paint. :)
  26. Fortunateson
    Fortunateson
  27. Groovy
    Groovy
    It was -2 in the sun. After painting I bring the parts inside immediately. Great thing about painting outside in the winter is less dust. I have a paint booth procured to do the frame.
  28. Groovy
    Groovy
    Points Dist. has been cleaned and rebuilt. Throttle / spring perch is painted and valve covers & air cleaner have arrived IMG_2656.JPG IMG_2660.JPG IMG_2662.JPG IMG_2663.JPG IMG_2666.JPG IMG_2665.JPG IMG_2664.JPG ...
  29. Groovy
    Groovy
    Engine is de-bured, sanded and primed. IMG_2885.JPG IMG_2883.JPG IMG_2887.JPG IMG_2888.JPG
  30. Groovy
    Groovy
    Engine and accessories are painted. IMG_2893.JPG IMG_2894.JPG IMG_2895.JPG IMG_2896.JPG IMG_2898.JPG IMG_2890.JPG IMG_2897.JPG
