Technical Drilling A New Bolt Pattern
Discussion in 'The Hokey Ass Message Board' started by quick85, Jun 28, 2019.
  1. quick85
    quick85
    **Sorry to have wasted time with this. After posting I checked online and
    there's more than enough info on this. For what I'm seeking it doesn't seem
    to be cost effective.**
    Has anyone tried to have slotted aluminum rims redrilled with a different
    bolt pattern? I should say a new bolt pattern, resulting in a multi-fit rim.
    Before posting here I tried asking at a car building shop in my area and
    got nowhere. Since the front and rear are flat it would seem possible. Any
    help would be appreciated.
    Fordors likes this.
  2. More drilling may weaken the structure depending on the thickness. There must be a spec on this somewhere. Perhaps one of the wheel manufacturers would help.
    quick85 likes this.
  3. Terrible80
    Terrible80
    Didn't they use to make some that way? I'd think any machine shop with a big mill could do it.
    Sent from my LG-TP450 using The H.A.M.B. mobile app
    quick85 likes this.
  4. 2OLD2FAST
    2OLD2FAST
    from illinois
    Open up the slot either inward or outward , 1/8" , they were called uni- lug , special nut and washer....
  5. oldiron 440
    oldiron 440
    Aftermarket axles come with two bolt patterns, why not buy new axles to use the wheels you want?
    quick85 likes this.
  6. X-cpe
    X-cpe
    Here's what I did when I re-drilled my front hubs. I took a piece of 1/8" aluminum and drew 2 concentric circles on it. One for the existing bolt pattern and the other for the new one. I marked the bolt pattern (every 72*) on the old one and did the same on the new one, placing the marks in between the marks on the old one. Next I drilled the holes for the existing bolts so they would just slip over the bolts. For the new bolt holes I just drilled a 1/8" pilot hole. Cut out the center, bolt it down, sharp drill bit, have fun.
    quick85 likes this.
  7. dreracecar
    dreracecar
    from so-cal
    Go right ahead, as long as the mounting face is flat, there is/should be no issues. The only thing you sacrifice is the looks because of the extra holes but you can countersink the back side and screw in extra lug nuts for the 10 bolt custom look
    quick85 likes this.
  8. quick85
    quick85
    I appreciate each response. I welcome ideas and experience. The wheels are our standard
    five slot aluminum mags. Having the five extra holes doesn't bother me, it works fine for
    Weld Drag Lites, and I could bounce from Chevy to Ford. My real concern about getting
    it done is having it done precisely so there's no problem with balance. Again, thank you.
  9. dreracecar
    dreracecar
    from so-cal
    If you were closer, My mill is programed to do bolt patterns
    quick85 and Atwater Mike like this.
  10. AngleDrive
    AngleDrive
    from Florida
    I bought a drill jig to change bolt pattern off a Hamb member several years ago. Worked perfect. Trouble is I don't remember who he is.
    quick85 likes this.
  11. http://www.rottenleonard.com/Menu.html
    gimpyshotrods and quick85 like this.
  12. AngleDrive
    AngleDrive
    from Florida
    Ya, thats him!
    gimpyshotrods likes this.
  13. oldiron 440
    oldiron 440
    The difference between a forged wheel having two bolt patterns and a cast wheel having two is one for the engineers.
    quick85 likes this.
  14. AngleDrive
    AngleDrive
    from Florida
    Just to clarify I changed the bolt pattern on the axles not wheels, much safer than on an aluminum wheel.
  15. A rotary index table on a mill will do it with precision. Dreracecar would be the best. CNC accuracy is hard to beat.I'm sure you found this out. :)
    quick85 likes this.
  16. I think most re-drill hubs/rotors and axles instead of the wheels. If you dont mind the extra holes drilling the wheels will save a bunch of other work. For example,when Dad and I started built the Valiant we found it had the 5 on 4" bolt pattern there is little after market support for. We added front brakes (ask me later about the previous owner running with rear 9" drums and NO front brakes) we opted for disks with the 4.5" pattern. Instead of re-drilling the rear axles for a bigger bolt pattern we purchased Moser axles with the larger 4.5" pattern. We still had to have the drums re-drilled and center register enlarged for the new axle. I may take a different approach depending if your working with a completed car or a project car.
    quick85 likes this.
  17. Ericnova72
    Ericnova72
    from Michigan
    This is actually only half correct. The wheels with the single lug holes slotted by 1/8" were called Dual-Fit, and need no funky washer or lug nut, just a standard mag shank lug nut and mag washer. These fit with the outboard half moon side of the lug shank fitting tight to the outboard half of the slot on the larger half of the pattern, and with the inboard half moon of the lug shank against the inboard half of the slot on the smaller bolt pattern. Good only for pattern changes 1/4" different, like 4-1/2" Ford/AMC/Dodge-to-4-3/4" GM, or 4-3/4" to 5.0" .I've got both Western and Ansen slots like this.
    Uni-Lug were typically a bigger slot, with an washer inset into a counterbore in the surface, and fit 3 different bolt patterns like 4-1/2 on the small side, 4-3/4" in the center, and 5" on the outboard end of the slot. Some used just the washer for locating, some also a centered hole or offset hole metal slug that was fitted into the lug holes from the backside to align with whatever pattern you needed to fit.
    I've seen ET, US-Indy and Ansen slot mags like this, and Cragar SS, Keystone Klassic also used this system. True Uni-Lug like this also has a bad reputation for working loose and snapping lug studs off, resulting in severe tire vibration/shake/wobble or worse yet sending the wheel flying off(Ask my little Bro about that with ET slots :mad:)
    Slotting the existing holes 1/8" on a mill is an easy task and you avoid both Uni-Lug washer ugliness or having another set of unused holes showing. Ideal way to go if you ask me.
    I've been 120MPH at the dragstrip on dual fits aluminum slots(Western Wheel Corp) for over 25 years with zero problems
    quick85 and Fordors like this.
  18. quick85
    quick85
    Again, thanks for the info. You guys have given me info that I'm sure will help
    others as well. I used a set of Uni-Lug ET wheels on a Chevy van during the
    great van scare of the '70s with no problem during a hell of a lot of driving but
    I really prefer not to use the Uni-Lug washers. I really hadn't considered possible
    problems with drilling out five more holes on a cast aluminum rim. I assumed
    that big flat expanse would be strong enough.
  19. dreracecar
    dreracecar
    from so-cal
    As stated, as long as the back side surface is flat and solid, there is no compromise in strength, some wheels had pockets between the holes to reduce the amount of alu. used in the casting process and such, one should never redrill those. Quite common practice on Cast Mag Halibrand wheels used in drag racing
    quick85 likes this.
  20. oldiron 440
    oldiron 440
    Halibrand has always been a premium wheel and if it was drilled that way new its because it was designed to be. Drilling an old aluminum wheel is just asking for trouble. I will say I would have a problem using a 40 or 50 year old aluminum wheel in the first place especially when you can buy a new one. usm-u10115006135_ml.jpg
    I bought these for the Fairlane last year 15x5 and 15x8 for less than 450.
    quick85 likes this.
  21. kruzin karl
    kruzin karl
    I bought the piece from rotten Leonard, worked out well, but I did hubs, wouldn't do it on a cast wheel. I think that having the holes on the rim precisely elongated, as someone else suggested, would be much safer.
    quick85 likes this.
  22. KenC
    KenC
    Yep. I had my grandson do a set of wheels for me. All it takes is locating on the table. Most CNC mills have a hole circle program as a standard program. He just had to select diameter/radius, degrees between holes(that machine uses that instead of hole count), insert proper tool and go.
    quick85 likes this.
  23. ramblin dan
    ramblin dan
    Made a bolt pattern check wheel and used these when I machined for the holes.
    quick85 likes this.
