Projects DRAG SNAKE "Vintage Terror!"
Discussion in 'The Hokey Ass Message Board' started by Deuced Up!, Oct 13, 2017.
  1. SS327
    SS327
    I'l play. 2750 Cool build by the way!
    Denny
  2. JimSibley
    JimSibley
    2379 and i like it a lot.
  3. enloe
    enloe
    from east , tn.
  4. saltflats
    saltflats
    from Missouri
  5. Nostrebor
    Nostrebor
    2552 :D
    Also, when did you announce that there were Dragsnake shirts? I missed that.
  6. Nostrebor
    Nostrebor
  7. skot71
    skot71
  8. Deuced Up!
    Deuced Up!
    Okay Here is the list so far (makes easier to see where everyone sits)
    DDDenny - 5 lbs (breadbasket) LOL
    Choffman41 - 1028
    Dreamweaver - 2099
    Aldeanfan - 2125
    Finn Jenson - 2300
    Alchemy - 2301
    Hoop - 2345
    Roadster1927 - 2347
    JimSibley - 2379
    57Fargo - 2400
    Offset - 2440
    SR100 - 2466
    Skot71 - 2475
    Enloe - 2535
    Wrenchbender - 2550
    Tickety Boo - 2551
    Nostrebor - 2552
    Milwscruffy - 2555
    Thor1 - 2575
    Peanut1959 - 2590
    Oldolds - 2600
    SS327 - 2750
    64Dodge440 - 2779
    Saltflats - 2780
    Hotrod 1948 - 2800
    Loudbang - 2830
    DFH-GMC - 2833
    GearheadQCE - 2850
  9. oldolds
    oldolds
    2600 plus two pieces of belly button lint!
    Tickety Boo and loudbang like this.
  10. DFH-GMC
    DFH-GMC
    from Texas
    2833
  11. hotrod1948
    hotrod1948
    from Milton, WI
  12. Peanut 1959
    Peanut 1959
    I feel like I'm hearing all these numbers flying out the mouth of an auctioneer!
  13. Thor1
    Thor1
    Okay Randall, I'll play...2,575
  14. hoop
    hoop
  15. Deuced Up!
    Deuced Up!
  16. hoop
    hoop
    I have been here . Just quietly reading this thread.
    I wish I had your energy. Working with your Dad,It doesn`t get any better that.
    HOOP
    Sancho, enloe, chryslerfan55 and 2 others like this.
  17. Deuced Up!
    Deuced Up!
    Well praise the drag racing gods the crazy Boss 302 is finally back in the little hot rod!
    Photo from my front yard last night...seemed apropos. LOL We just live a couple of blocks from the city park so we get a pretty good show in celebration of the 4th!
    I lost count how many times we completely stripped and painted the firewall and footboxes in preparation for this moment. Suffice to say I should own a good chunck of the 3M company by now. But we finally got it to stick (so far). At least we felt confident enough to move forward in the assembly.
    A very nice fit on the driver's side. We popped the plugs in as well just to make sure we had no issues when it came time to do it for real.
    The passenger side was another story. After literally shoe horning this crazy unit in place and fighting to get it locked down to all the neccessary mounts, we found we still had a small clearance issue. I don't even want to talk about how that is possible. But the engine hoist had already been dissasembled (very optimistic of Dad I thought) so no way we are stepping back. It really only missed by a teeny tiny bit so I took out one of my body hammers and started to carefully flatten the rear header tube a bit. It is very hard to see but I actually flattned that area where the header is closest to the footbox. I litterally changed it shape by a 1/2 inch. When I slid the header back in place I actually had about 1/4" clearance. It is so clean and straight that if I hadn't told you, you would never notice, even up close.
    The alternator went back on perfectly (well almost) but the good news, when extended as far as it can go out to tighten up a belt, it still has about an 1" clearance on the engine compartment's down tube and front sides sheet metal. The starter cleared, the steering column cleared, the oil filter had to be rotated but it is on and clears everthing in the area. The transmission clutch lines cleared as did the Radiator and the heavy duty puller fan cleared the rack and pinion unit by 3/4" (which on this car is a freaking 1/4 mile!)...LOL
    The only thing that did not make the cut today was the expansion tank. No way does it clear the hood. But to be honest, I was not happy with it because that is not where it went on a small block Cobra anyway!
    I hopped in this evening to make sure "I STILL CLEARED!" LOL ....and all seems to still fit nicely.
    cactus1, Sancho, Offset and 9 others like this.
  18. Deuced Up!
    Deuced Up!
    Our poor dash has been through it. As you can see it has had several edits the last one (you might remember) was when we moved the tach up to the dash.
    This afternoon I took my daughter to a local material store and they had quite the upholstry section. Before I knew it, I had my late afternoon planned.
    Of course the guage holes have been in place for a while but I still needed a hole marked and cut for the switch panel.
    After recently finishing the firewall and putting the dash in place it was obvious the space between them for the wiring harness is fairly limited. Originally I was not going cut the glove box door out. However it would be handy to use that area for the fuse box. So no time like the present, we went ahead and cut the hole out etc.
    I found this killer molding foam there as well and decided to pad the dash with it. We simply glued it to the dash and then cut out the holes.
    It really worked well and gave the entire dash a nice clean rounded, soft lookl
    Just before it totally set up, we cut out the outline of the plate from our switches. This way it will pull itself down inside the padding.
    It fit perfectly so now all we have to do is apply the adheasive to the foam and vinyl material and then stretch it in place etc.
    It went on really well. No wrinkles or tunneling. I was very happy with it until I slid the guages in place for a test fit. It looked really nice except for the lower small guage. When I was trimming its hole out, I had cut the hole at an angle and it showed around the outside of the gauge rim.
    At the same time, my daughter said it looked a bit plain anyway. So to fix both issues we created an over lay in sort of a "V" shape. This allowed us to cover up the mistake and give the dash some character.
    It looks really good sitting on the patio table, so good we simply had to take it to the shop and install it.
    And for right now the guages are just sitting in there. I have to do some triming on the hold down pieces to make them fit. When ever they go on the gauges will be pulled down a bit into the foam and give it more of a padded look as well.
  19. DDDenny
    Boy that dash looks gooood!
    I forget what you're planning for header coating.
  20. Gammz
    Gammz
    from Lincoln Ne
  21. Deuced Up!
    Deuced Up!
    Thanks boys. I was a bit frustrated after finishing it the first round and having one gauge hole screw the entire thing up. But my daughter was right, it did need something so it didn't look so plain. AND I learned something from that first round: That second layer I only cut and "x" of each hole and shoved the gauges in (something I was going to do the first time but then second guessed myself when it came time to cut. Happy accidents I suppose!
    Good timing on the header question DDD as that is our next little project. You know I learned a lot about high performance headers on the Austin. Some of you might remember the "white" ceramic coat debacle. Long story short I had them ceramic coated white and they looked like someone had spray painted them with watered down white paint of some kind. Found out white ceramic is very hard to get right. Then we had to have the next company blast all the coating off in order to just start again with a polished looking color. But that was not what I wanted. So I took them back and just painted them white with the high heat header paint. That all just melted off the first time we started. By the time I was satified the rings were seated, the paint was gone. We tried a couple of different brands of high heat header spray and got decent coverage but was never happy. Then we started actually driving the car with the fenders on it and it was an inferno in there. We had to do something so I finally tried wrapping them with the Titanium (and lava rock dusted) header wrap. It was like magic. It cut the heat down like crazy. SO. That is my plan. I like the look of the wrap (something about gives me an old school feel) and I know it really works!
  22. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    My brother-in-law is a master carpenter. He taught me that a real craftsman is the one that can hide his mistakes and make it look like it was the original plan.
  23. Deuced Up!
    Deuced Up!
  24. Deuced Up!
    Deuced Up!
    Stumbled into a good deal today. Our local mom and pops performance parts store is going out of business. Sad. One of my good friend owns it. Anyway I was in there today and he is starting to clear stuff out. Snagged a red top Omni for the Cobra. Saved almost $60.00 over JEGS or Summit. Going to miss that place though).
    Sent from my SM-G970U using The H.A.M.B. mobile app
  25. saltflats
    saltflats
    from Missouri
    Put that thing on a tender.
    loudbang and enloe like this.
  26. Deuced Up!
    Deuced Up!
    Not sure about you there James...you mean you take a car battery on dates with you?!!! LMAO!
  27. Peanut 1959
    Peanut 1959
    I met a girl on "tender" once...she really amped me up!
    loudbang, chryslerfan55 and saltflats like this.
  28. Thor1
    Thor1
    Oh man, that's bad...REALLY bad!:confused:o_O:rolleyes:
