Technical Vintage bead roller opinion wanted.
Discussion in 'The Hokey Ass Message Board' started by Kage, Jun 24, 2019.
  1. Kage
    Kage
    from Delano, TN
    I have an opportunity to pick up one of the below machines. They were technically not bead rollers. The Ingels Elbow double sided machine was used to to form duct work elbows.
    They both have a 7/8 shaft...but only a have a 15 to 16 throat depth... I would have to add a motor, speed control, and a foot control.
    After buying the machine, the 1hp motor and controls, I would be in to the whole setup for around 700-800.
    I would like to get opinions from the forum...pros...cons. I know I can get into an Eastwood elite bead roller powered for around 650. The Miller Brothers and Baielgh bead rollers with power would be around 1250.
    I do like the thought of saving vintage equipment...I know it’s built to last.
    I look forward to reading what you guys have to say.
    0656F6A4-1E0C-4829-83DD-304D5F16BB10.jpeg FE1BF207-61A0-4F9D-BB90-F396399D7DF9.jpeg 1089B37A-35F6-4FC1-A66E-1E90A3F3C5AC.jpeg D000366D-6353-49EE-9B45-0F2574754F9E.jpeg
    tomkelly88 likes this.
  2. Burkedore
    Burkedore
    Those look like nice machines. If it were me they would already be in the back of my truck.
    Three Widow's Garage and Kage like this.
  3. flamedabone
    flamedabone
    WOW! That thing is cool. You need it.
    -Abone.
    Kage likes this.
  4. Certainly Cool, but you maybe limited with your work by the throat depth.
  5. lostone
    lostone
    from kansas
    If I'm after a true working tool and not a mantle piece to walk around and stare at I'd buy the new piece complete with motor setup.
    The above is a cool piece but you can buy something newer with motor, deeper throat and takes up a lot less space.
    Don't get me wrong, I like the old stuff. In fact I picked up an old ammco 2000 brake shoe grinder as a winter project but it's not something I have plans for other than a working art piece.
  6. samurai mike
    samurai mike
    I wouldn't even have to think about it!
    Kage likes this.
  7. 1932tub
    1932tub
    The machines that you mention do not even come close to a machine like this in quality, the throat depth is not a handicap you can work from both sides of the sheet. If I had the chance that machine would be in the back of my truck so fast it would make your eyes water.
    Kage likes this.
  8. manyolcars
    manyolcars
  9. The biggest thing is do you have a source or the ability to make rolls to fit a 7/8" shaft as most of the aftermarket ones like Mittler Bros are 3/4". Would get pretty costly to have to have someone make custom rolls every time you need a new profile.
  10. hotrod428
    hotrod428
    I have the twin to the second machine. I shit canned the cast iron base fabricated a new base and put a DC variable speed on it. Its very versatile with the 3 powered heads. I will take some pics and put them on here later.
  11. hotrod428
    hotrod428
    I also extended the throat on one side. I bought this at an auction about 25 years ago, I was the only bidder paid $10
    IMG_20190626_163336189.jpg IMG_20190626_163336189.jpg IMG_20190626_163356529.jpg IMG_20190626_163356529.jpg IMG_20190626_163356529.jpg
    RICH B likes this.
