Is there someone around the New Braunfels / Austin / San Antonio area that would like to take a couple of hours on a Saturday afternoon to teach me what I'm doing wrong when I spot weld sheetmetal? i watch all the different threads and builds that make it look so easy. I'm sure its a simple trick, but I am not getting it. VOH
Sorry, i said spot welds, but stitch welds is a better description. I’m talking about butt welds for patch panels. Sent from my iPhone using The H.A.M.B. mobile app
Seems to be blowing thru a lot. Seems to be high welds, so it’s hard to blend in. Sent from my iPhone using The H.A.M.B. mobile app
It sounds like the welder is set to high. Start on the lowest setting or up one setting. To blend in you will have to grind the bead
A stitch weld usually refers to welds made with a MIG machine with a timer that starts and stops the weld at preset intervals. Sounds like you are manually tack welding butt joints. Blowing through sounds like wide gap or heat setting too high for the gauge of metal. High build could mean heat too low and no penetration or too long on the trigger.
Welding new metal or rust old stuff? Or as is often the case new to old rusty stuff? That can be tricky as the old metal can be really thin.
Rule of thumb I heard years ago is 1 amp per .001" steel thickness. So, 18 Ga is about .049" I think so somewhere around 45-50 amps. I think I'd start a bit lower amps than that and do some practice pieces like suggested above and go from there. Hope this is helpful. Lynn
Stop! If you are welding on the actual car you cherish and love more than anything in the whole world??Start by cutting up some scrap metal pieces the same gauge as your car and then practice a bunch. It is really easy to learn mig welding. You have to start by dialing the machine in properly the wire feed and heat setting have to be just right also the gas has to be flowing properly. The metal should be as close together as possible and likes to be clean. Sometimes also if the shop doors are open a good breeze can carry away the shielding quality of the gas making poor welds. You need to get the FEEL of welding to get competent at it ,then confidently weld on your ride. You do understand the tricks to weld patch panels in without major warping of panels.... right?
