Technical How to cut small slots in fender well?
Discussion in 'The Hokey Ass Message Board' started by Sporty45, Jun 25, 2019.
  1. Sporty45
    Sporty45
    I had to do some repairs to my fender wells on my 47 Olds and will need to replace the caged fender nuts. I have the hole drilled for them, but don't know how to cut nice small slots for the ears on the nuts. The slots are .100" wide x 1/4" long. Anybody have a good way to do it? These are the kind of nuts I'm talking about.
  2. Casey Riley
    Casey Riley
    from Minnesota
    If it was me, I would carefully use a dremmel with that little 1" cut off wheel. And then shape it with a Nicholsen round pointed swiss file #0
    loudbang, Sporty45 and Just Gary like this.
  3. Kan Kustom and Sporty45 like this.
  4. 49ratfink
    49ratfink
    you have ears on your nuts? that paints an interesting visual.
    Bandit Billy likes this.
  5. Bandit Billy
    Bandit Billy
    Make a pattern out of something non magnetic and use a plasma cutter. You will be done in a few minutes.
    Kan Kustom likes this.
  6. Sporty45
    Sporty45
    I already have die grinders, but they aren't always easy to control on small stuff like what I need. Maybe if I try a small radiac wheel first to kind of put a groove into the metal to guide the bit. Hmmm...
  7. F-ONE
    F-ONE
    from Alabama
    Is that really the type you need?
    Do you have to have those "ears"?
    Would you better cutting those tabs off and riveting or welding (like a spot weld) those?
    Sporty45 and scotty t like this.
  8. x2 :cool:
    Sporty45 likes this.
  9. This is a 'micro' grinder, much easier to control plus you can get very small bits for it. Might be best to drill a series of holes then connect them. Building a drill guide fixture would be a huge help too if you have to do more than a few of them. If you have the bolt holes drilled, you could bolt the fixture into place.
  10. 19Fordy
    19Fordy
    Mark where you want the slot to be.
    Then drill a small hole on each end of the marked out slot.
    Then slice cut it with a small cut of wheel.
    QUESTION: If you know where you want the cage nuts to be located,
    why not cut off the tabs and weld the cage nuts in place. That way no water seeps in.
    Black_Sheep, Sporty45 and Just Gary like this.
  11. Terrible80
    Terrible80
  12. Terrible80
    Terrible80
    Black_Sheep and loudbang like this.
  13. Would a broach cutting tool/bit work? , they cut square holes. HRP
  14. Use a rotary file and a Dremel tool. @.100 if you used a .125 rotary file you would be fine.
  15. Sporty45
    Sporty45
    They are the type that are in there now, and I'm trying to keep the same thing in there. I have thought about just welding them, but would like to keep the original look. Just me I guess!
  16. Sporty45
    Sporty45
    The slots are pretty small. I'd actually have to cut past where I need it in order for the wheel to cut completely through the drilled holes. I guess I could just weld the groove that extends past the cut out slot afterwards.
    And I'm trying to keep it like original :D
  17. Sporty45
    Sporty45
  18. Sporty45
    Sporty45
    I don't think there is one small enough. That idea is a good one though!
  19. saltflats
    saltflats
    from Missouri
    Drill two holes at the end of where you want the slots then take a sharp chisel modified for the slot and cut out the center between the drilled holes.
  20. papajohn
    papajohn
    Sharpen a small screw driver, and bang it thru where you want the slot while someone backs it up with a hunk of 2x4
    Casey Riley and Sporty45 like this.
  21. Sporty45
    Sporty45
    Good ideas here! This would be so much easier if it was just a piece of sheet metal on the bench, but twisting myself up under the wheel well to do this is a PIA! :eek:
  22. Sporty45
    Sporty45
    Well, I gave the small drill and file method a try and it worked out pretty good! I found a drill bit that measured .100" and drilled a couple holes at the end of the slot, then got my die grinder with a very small radiac wheel and scored most of the metal away between the drilled holes, then attacked it with a small file. One pic shows the rusted out piece of metal I used as a template. Sprayed the wheel wells with some epoxy primer and called it done.Thanks for tips guys :cool: IMG_20190626_101229125.jpg IMG_20190626_101545477.jpg IMG_20190626_101805132.jpg IMG_20190626_101844225.jpg IMG_20190626_104812242.jpg
    Casey Riley and saltflats like this.
  23. Bert Kollar
    Bert Kollar
    I would just cut the tabs off and spot weld them on
  24. Sporty45
    Sporty45
    Thanks, but I didn't want to do that :rolleyes:
  25. You did it about how I was thinking. Anything cut, drilled and stacked on like that, I like to use some of that black putty stuff (I forget the name) for windshields and firewall grommet/wire sealing. It doesn't dry up or wick out and can be painted right over, plus there are no voids to trap water.
    I picked that up from a neighbor who is a dent removal pro and when he has to drill holes to access the back sides, he uses the black stuff with the plugs to make 'em watertight and rustproof.
    Sporty45 and Kan Kustom like this.
